9.4 Constrained Optimization
9.4.5 Dummy Atom Placement in Dihedral Constraints
Bond and dihedral angles cannot be constrained in Cartesian optimizations to exactly 0∘ or ±180∘. This is because the corresponding constraint normals are zero vectors. Also, dihedral constraints near these two limiting values (within, say 20∘) tend to oscillate and are difficult to converge.
These difficulties can be overcome by defining dummy atoms and redefining the constraints with respect to the dummy atoms. For example, a dihedral constraint of 180∘ can be redefined to two constraints of 90∘ with respect to a suitably positioned dummy atom. The same thing can be done with a 180∘ bond angle (long a familiar use in Z-matrix construction).
Typical usage is as shown in Table 9.3. Note that the order of atoms is important to obtain the correct signature on the dihedral angles. For a 0∘ dihedral constraint, atoms J and K should be switched in the definition of the second torsion constraint in Cartesian coordinates.
Internal Coordinates Cartesian Coordinates
$opt $opt
   CONSTRAINT    DUMMY
   tors I J K L 180.0    M 2 I J K
   ENDCONSTRAINT    ENDDUMMY
$end    CONSTRAINT
   tors I J K M 90
   tors M J K L 90
   ENDCONSTRAINT
Table 9.3: Comparison of dihedral angle constraint method for adopted coordinates.
Note:  In almost all cases the above discussion is somewhat academic, as internal coordinates are now best imposed using delocalized internal coordinates and there is no restriction on the constraint values.
