To perform a GMBE(1) calculation, set GMBE_INT =
TRUE in the $rem section. The level of theory applied to the
fragments will correspond to the method specified in the $rem section. Researchers utilizing
Q-Chem’s GMBE implementation are requested to cite
Refs.
      69
           (2023),
           159,
           pp. 074107.
 and
      1123
           (2012),
           137,
           pp. 064113.
The following keywords control the GMBE calculation in Q-Chem. They should be specified in the $rem section of the input file.
GMBE_INT
GMBE_INT
Perform a GMBE Calculation.
Perform GMBE.
Do not perform GMBE.
GMBE_METHOD
GMBE_METHOD
Specify whether to perform an energy-based GMBE (GMBE-EB) or a density matrix-based GMBE (GMBE-DM).
Perform GMBE-EB.
Perform GMBE-DM.
GMBE_ALGO
GMBE_ALGO
Specify the cutoff distance criterion used to determine the primitive fragments.
Minimum distance
Heavy-atoms distance
GMBE_PRIMARY
GMBE_PRIMARY
Specify the primary cutoff distance used to determine the primitive fragments.
The input for GMBE_PRIMARY is the desired cutoff distance in Å, multiplied by 1000.
For example, to use a 2.00 Å cutoff distance, set GMBE_PRIMARY to 2000.
Similarly, if GMBE_PRIMARY = 3500, the cutoff distance will be 3.5 Å.
3000
The desired cutoff is  = 1000, where  is the cutoff distance in Å.
GMBE_MAX_PRIM_CARD
GMBE_MAX_PRIM_CARD
Set the maximum cardinality for the primitive fragments.
5
 represents the maximum cardinality of the primitive fragments.
MBEDM_PURE
MBEDM_PURE
Perform McWeeny purification
         902
           Rev. Mod. Phys.
           (1960),
           32,
           pp. 335.
 for GMBE density matrix.
Perform McWeeney purification on the GMBE density matrix.
Do not perform McWeeney purification on the GMBE density matrix.
GMBE_DM_GUESS_ONLY
GMBE_DM_GUESS_ONLY
Evaluate the total energy of the system directly using GMBE-DM density matrix.
Enabling this option skips SCF iterations, preventing further convergence to the supersystem result.
Do not perform SCF iterations and directly evaluate the total energy of the system using the GMBE-DM density matrix.
Perform SCF iterations with the GMBE-DM density matrix as the initial guess.
GMBE_PRINT_LEVEL
GMBE_PRINT_LEVEL
Control the level of details printed in the output file
Minimal output
Detailed output
Example 12.47 Example of a GMBE(1)-EB calculation for a water hexamer.
$rem GEN_SCFMAN FALSE SYM_IGNORE TRUE METHOD B3LYP BASIS def2-TZVPPD THRESH 14 SCF_CONVERGENCE 7 MAX_SCF_CYCLES 200 MEM_TOTAL 8000 MEM_STATIC 4000 AO2MO_DISK 5000 GMBE_INT TRUE ! Perform GMBE GMBE_METHOD 1 ! 1 = energy-based, 2 = density matrix-based GMBE_ALGO 1 GMBE_PRIMARY 2000 GMBE_MAX_PRIM_CARD 5 GMBE_PRINT_LEVEL 1 !1 = minimal output, 2 = detailed output $end $molecule 0 1 -- 0 1 O -1.126149 -1.748387 -0.423240 H -0.234788 -1.493897 -0.661862 H -1.062789 -2.681331 -0.218819 -- 0 1 O -0.254210 1.611495 -1.293845 H -1.001520 1.163510 -1.690129 H -0.153399 2.411746 -1.809248 -- 0 1 O 1.694541 -0.226287 1.705739 H 0.785920 0.073487 1.677909 H 2.047134 0.150917 2.511706 -- 0 1 O -0.864533 0.522472 1.218817 H -0.694120 1.093542 0.469789 H -1.131418 -0.310426 0.829702 -- 0 1 O -2.312727 0.054310 -2.138177 H -2.002512 -0.686744 -1.617757 H -3.266931 0.004778 -2.081349 -- 0 1 O 1.292355 -0.704768 -0.977342 H 1.642300 -0.601085 -0.092386 H 0.948122 0.159656 -1.202018 $end
Example 12.48 Example of generating an initial guess density matrix using a GMBE(1)-DM calculation for a water hexamer.
$rem GEN_SCFMAN FALSE SYM_IGNORE TRUE METHOD B3LYP BASIS def2-TZVPPD THRESH 14 SCF_CONVERGENCE 7 MAX_SCF_CYCLES 200 MEM_TOTAL 4000 MEM_STATIC 4000 ao2mo_disk 5000 GMBE_INT TRUE ! Perform GMBE GMBE_METHOD 2 ! 1 = energy-based, 2 = density matrix-based GMBE_ALGO 1 GMBE_PRIMARY 2000 GMBE_MAX_PRIM_CARD 5 GMBE_DM_GUESS_ONLY FALSE ! Perform SCF iterations with the GMBE-DM initial guess GMBE_PRINT_LEVEL 1 ! 1 = minimal output, 2 = detailed output MBEDM_PURE TRUE ! Perform purification $end $molecule 0 1 -- 0 1 O -1.126149 -1.748387 -0.423240 H -0.234788 -1.493897 -0.661862 H -1.062789 -2.681331 -0.218819 -- 0 1 O -0.254210 1.611495 -1.293845 H -1.001520 1.163510 -1.690129 H -0.153399 2.411746 -1.809248 -- 0 1 O 1.694541 -0.226287 1.705739 H 0.785920 0.073487 1.677909 H 2.047134 0.150917 2.511706 -- 0 1 O -0.864533 0.522472 1.218817 H -0.694120 1.093542 0.469789 H -1.131418 -0.310426 0.829702 -- 0 1 O -2.312727 0.054310 -2.138177 H -2.002512 -0.686744 -1.617757 H -3.266931 0.004778 -2.081349 -- 0 1 O 1.292355 -0.704768 -0.977342 H 1.642300 -0.601085 -0.092386 H 0.948122 0.159656 -1.202018 $end
