EFP_COORD_XYZ
EFP_COORD_XYZ
Use coordinates of three atoms instead of Euler angles to specify
position and orientation of the fragments
TRUE FALSE
TRUE FALSE
EFP_ENABLE_LINKS
EFP_ENABLE_LINKS
TRUE FALSE
EFP
EFP
TRUE FALSE
EFP_FRAGMENTS_ONLY
EFP_FRAGMENTS_ONLY
QM part is present
Only MM part is present: all fragments are treated by EFP
QM part is present: do QM/MM EFP calculation
EFP_INPUT
EFP_INPUT
Dummy atom (e.g., He) in $molecule section should be present
A format without dummy atom in $molecule section
A format with dummy atom in $molecule section
FEFP_EFP
FEFP_EFP
Specifies that fEFP_EFP calculation is requested to compute the total
interaction energies between a ligand (the last fragment in the
$efp_fragments section) and the protein (represented by fEFP)
OFF
OFF
disables fEFP
LA
enables fEFP with the Link Atom (HLA or CLA) scheme (only
electrostatics and polarization)
MFCC
enables fEFP with MFCC (only
electrostatics)
The keyword should be invoked if EFP/fEFP is requested (interaction
energy calculations). This keyword has to be employed with
EFP_FRAGMENT_ONLY = TRUE. To switch on/off
electrostatics or polarzation interactions, the usual EFP controls are
employed.
FEFP_QM
FEFP_QM
Specifies that fEFP_QM calculation is requested to perform a
QM/fEFPcompute computation. The fEFP part is a fractionated macromolecule.
OFF
OFF
disables fEFP_QM and performs a QM/EFP calculation
LA
enables fEFP_QM with the Link Atom scheme
The keyword should be invoked if QM/fEFP is requested. This keyword has
to be employed with efp_fragment_only false. Only electrostatics is
available.
EFP_ELEC
EFP_ELEC
switch on electrostatics
switch off electrostatics
EFP_POL
EFP_POL
switch on polarization
switch off polarization
EFP_DISP
EFP_DISP
switch on dispersion
switch off dispersion
EFP_EXREP
EFP_EXREP
switch on exchange repulsion
switch off exchange repulsion
EFP_QM_ELEC
EFP_QM_ELEC
switch on QM-EFP electrostatics
switch off QM-EFP electrostatics
EFP_QM_POL
EFP_QM_POL
Controls QM-EFP polarization
switch on QM-EFP polarization
switch off QM-EFP polarization
EFP_QM_DISP
EFP_QM_DISP
Controls QM-EFP dispersion
switch on QM-EFP dispersion
switch off QM-EFP dispersion
EFP_QM_EXREP
EFP_QM_EXREP
switch on QM-EFP exchange-repulsion
switch off QM-EFP exchange-repulsion
EFP_ELEC_DAMP
EFP_ELEC_DAMP
switch off electrostatic screening
use overlap-based damping correction
use exponential damping correction if SCREEN2 screening parameters are provided in the EFP potential
EFP_DISP_DAMP
EFP_DISP_DAMP
switch off dispersion screening
use Tang-Toennies screening, with fixed parameter
EFP_POL_DAMP
EFP_POL_DAMP
switch off polarization screening
EFP_POL_DAMP_TT_VALUE
Controls the value of the fragment–fragment polarization Tang–Toennies screening factor in EFP
600
n
corresponds to n/1000.
Use the default value of 0.6 for this screening factor, which was hard coded in the original EFP implementation.
EFP_QM_ELEC_DAMP
EFP_QM_ELEC_DAMP
use QM-EFP electrostatic damping if SCREEN screening parameters are provided in the EFP potential
EFP_PAIRWISE
EFP_PAIRWISE
Controls QM-EFP pairwise fragment energy decomposition analysis
energy decomposition is turned off
energy decomposition is turned on
EFP_ORDER
EFP_ORDER
the first step of energy decomposition is performed
the second step of energy decomposition is performed
The EFP_PAIRWISE keyword should be turned on to activate the energy decomposition analysis.
