Incremental DFT (IncDFT) uses the difference density and functional values to improve the performance of the DFT quadrature procedure by providing a better screening of negligible values. Using this option will yield improved efficiency at each successive iteration due to more effective screening.
INCDFT
INCDFT
Toggles the use of the IncDFT procedure for DFT energy calculations.
Do not use IncDFT
Use IncDFT
Turning this option on can lead to faster SCF calculations, particularly
towards the end of the SCF. Please note that for some systems use of this
option may lead to convergence problems.
INCDFT_DENDIFF_THRESH
Sets the threshold for screening density matrix values in the IncDFT procedure.
SCF_CONVERGENCE + 3
Corresponding to a threshold of .
If the default value causes convergence problems, set this value higher to
tighten the threshold.
INCDFT_GRIDDIFF_THRESH
Sets the threshold for screening functional values in the IncDFT procedure
SCF_CONVERGENCE + 3
INCDFT_DENDIFF_VARTHRESH
Sets the lower bound for the variable threshold for screening density matrix
values in the IncDFT procedure. The threshold will begin at this value and
then vary depending on the error in the current SCF iteration until the value
specified by INCDFT_DENDIFF_THRESH is reached. This means this
value must be set lower than INCDFT_DENDIFF_THRESH.
Variable threshold is not used.
to tighten accuracy. If this fails, set to 0 and use a static threshold.
INCDFT_GRIDDIFF_VARTHRESH
Sets the lower bound for the variable threshold for screening the functional
specified by INCDFT_GRIDDIFF_THRESH is reached. This means that
this value must be set lower than INCDFT_GRIDDIFF_THRESH.
