In addition to the normal TDDFT job controls variables described in Section 7.3.5, there are several others to request TDDFT(MI). Note that only single-point energies (not gradients) are available for this method.
TDDFT_MI
TDDFT_MI
Perform an TDDFT(MI) calculation
Do not perform an TDDFT(MI) calculation
False
MI_ACTIVE_FRAGMENT
MI_ACTIVE_FRAGMENT
Sets the active fragment
NO DEFAULT
Specify the fragment on which the TDDFT calculation is to be performed, for LEA-TDDFT(MI).
MI_LEA
MI_LEA
Controls the LEA-TDDFT(MI) methods
NO DEFAULT
The LEA0 method
The LEA-Q method
The LEAc method
