9.4 Constrained Optimization
9.4.2 Geometry Optimization with General Constraints
interatomic distances
stre   atom1   atom2   value
angles
Values in degrees, 0≤v⁢a⁢l⁢u⁢e≤180; atom2 is the middle atom of the bend:
out-of-plane-bends
Values in degrees, -180≤v⁢a⁢l⁢u⁢e≤180 atom2; angle between atom4 and the atom1–atom2–atom3 plane:
dihedral angles
Values in degrees, -180≤v⁢a⁢l⁢u⁢e≤180; angle the plane atom1–atom2–atom3 makes with the plane atom2–atom3–atom4:
coplanar bends
Values in degrees, -180≤v⁢a⁢l⁢u⁢e≤180; bending of atom1–atom2–atom3 in the plane atom2–atom3–atom4:
perpendicular bends
Values in degrees, -180≤v⁢a⁢l⁢u⁢e≤180; bending of atom1–atom2–atom3 perpendicular to the plane atom2–atom3–atom4:
Example 9.11  Methanol geometry optimization with constraints in bond length and bond angles.
   C   0.14192   0.33268   0.00000
   O   0.14192  -1.08832   0.00000
   H   1.18699   0.65619   0.00000
   H  -0.34843   0.74268   0.88786
   H  -0.34843   0.74268  -0.88786
   H  -0.77395  -1.38590   0.00000
   JOBTYPE           opt
   METHOD            hf
   BASIS             3-21g
   GEOM_OPT_PRINT    6
$opt
   CONSTRAINT
   stre  1  6  1.8
   bend  2  1  4  110.0
   bend  2  1  5  110.0
   ENDCONSTRAINT
