5.11.2 Manner of Counting Electrons
Becke Partition:
In density functional theory calculations, the integration over the total density is evaluated on a molecular grid that is systematically broken up into interlocking multi-center atomic quadrature grids. 92 Becke A. D.
(1988), 88, pp. 2547.
This atomic quadrature scheme is predicated on the definition of atomic cell functions Pa⁢(𝐫), that define smoothed Voronoi polyhedra centered about each atom. These cell functions are products of switching functions that define the atomic cell of atom a, and fall rapidly from ≈1 near the nucleus of a, to ≈0 near any other nucleus. The integration weights provided by this scheme are multiplied into the Lebedev quadrature weights in any practical DFT calculation:
wn⁢(𝐫)=Pn⁢(𝐫)∑mPm⁢(𝐫) (5.70)
In some cases, it may be useful to print out the atomic Becke populations that are defined by these atomic cell functions. Becke population analysis may be requested by setting POP_BECKE to TRUE in the input file.
POP_BECKE
POP_BECKE
       Controls the printing of atomic Becke populations.
       TRUE Print atomic Becke populations. FALSE Do not print atomic Becke populations.
The default quadrature scheme uses atomic cell functions that intersect precisely at bond midpoints. Consequently, the default atomic cell functions will yield physically meaningless atomic populations. However, it is possible to shift the intersect of the atomic cell functions using an atomic radius criterion. 92 Becke A. D.
In shifting the intersect of neighboring atomic cell functions, the point at which the Becke weights begin to fall from ≈1 to ≈0 changes depending on the atomic radius of each atom. While the choice of atomic radius is arbitrary, these atomic cell shifts introduce a physical basis for the partitioning of the underlying atomic quadrature. Two choices for atomic radii exist in Q-Chem for use with Becke weights, namely the empirically derived radii introduced by Bragg and Slater 1213 Slater J. C.
(1964), 41, pp. 3199.
and the ab initio-derived weights due to Pacios. 991 Pacios L. F.
(1995), 16, pp. 133.
BECKE_SHIFT
BECKE_SHIFT
       Controls atomic cell shifting in determination of Becke weights.
       BRAGG_SLATER
       UNSHIFTED Use Becke weighting without atomic size corrections, based on bond midpoints. BRAGG_SLATER Use the empirical radii introduced by Bragg and Slater. UNIVERSAL_DENSITY Use the ab initio radii introduced by Pacios.
       If interested in the partitioning of the default atomic quadrature, use UNSHIFTED. If using for physical interpretation, choose BRAGG_SLATER or UNIVERSAL_DENSITY. All cDFT calculations and calculations where POP_BECKE = TRUE will default to BRAGG_SLATER radii, otherwise the default grid is UNSHIFTED.
Fragment-Based Hirshfeld Partition:
A much less arbitrary scheme with which to count electrons comes from the fragment-based Hirshfeld partition. 1114 Řezáč J., de la Lande A.
(2015), 11, pp. 528.
, 536 Herbert J. M., Carter-Fenk K.
(2021), 125, pp. 1243.
The fragment-based Hirshfeld (FBH) partition uses weights constructed from isolated fragment densities in the form,
wn⁢(𝐫)=ρn⁢(𝐫)∑mρm⁢(𝐫), (5.71)
where ρn⁢(𝐫) is the density of the isolated fragment, n. Note that unlike the atomic Becke partition, the FBH partition is not constructed from linear combinations of atomic weights, but is instead built from whole fragment densities. The FBH partition comes directly from the densities of the isolated fragments, which are not as arbitrary as the choosing the effective atomic radii in the Becke partition. In order to apply FBH partitioning, one must define fragments within the $molecule section to host the constraints, but the input for the $cdft section remains unchanged and still applies constraints on a per-atom basis.
CDFT_POP
CDFT_POP
       Sets the charge partitioning scheme for cDFT or cDFT-CI jobs.
       BECKE
       BECKE Linear combination of atomic Becke functions FBH Fragment-based Hirshfeld partition
