In addition to the standard CIS job controls variables described in Section 7.2.4, there are several additional $rem variables to specify for an ALMO-CIS/ALMO-CIS+CT calculation.
LOCAL_CIS
LOCAL_CIS
Invoke ALMO-CIS/TDA or ALMO-CIS/TDA+CT calculations.
Regular CIS/TDDFT calculations
ALMO-CIS/TDA without RI
ALMO-CIS with RI
Use 2 when running full-spectrum ALMO-CIS calculations (EIGSLV_METH = 0)
Use 1 when running the iterative version of ALMO-CIS/TDA (EIGSLV_METH = 1)
EIGSLV_METH
EIGSLV_METH
Control the method for solving the ALMO-CIS eigen-equation
Explicitly build the Hamiltonian then diagonalize (full-spectrum)
Use the Davidson method (currently only available for restricted cases)
None; use 1 for ALMO-TDA calculations (0 unavailable)
NN_THRESH
NN_THRESH
The distance cutoff for neighboring fragments (between which CT excitation occurs).
Do not include interfragment transitions (ALMO-CIS/TDA)
Include interfragment excitations between pairs of fragments the distances between whom
are smaller than   (ALMO-CIS/TDA+CT)
Example 12.52 ALMO-CIS+CT calculation ( ) for all the states of a helium dimer.
$molecule 0 1 -- 0 1 He 2.8 0. 0. -- 0 1 He 0. 0. 0. $end $rem BASIS gen AUX_BASIS rimp2-cc-pvdz PURECART 1111 METHOD hf FRGM_METHOD stoll CIS_N_ROOTS 8 CIS_TRIPLETS false LOCAL_CIS 2 ! use RI for ALMO-CIS NN_THRESH 10 POINT_GROUP_SYMMETRY false INTEGRAL_SYMMETRY false $end $rem_frgm cis_n_roots 0 $end $basis **** HE 0 S 3 1.000000 3.84216340D+01 2.37660000D-02 5.77803000D+00 1.54679000D-01 1.24177400D+00 4.69630000D-01 S 1 1.000000 2.97964000D-01 1.00000000D+00 SP 1 1.000000 4.80000000D-02 1.00000000D+00 1.00000000D+00 **** $end
Example 12.53 Attachment-detachment density plots for the first two ALMO-CIS states of the formamide-water complex
$molecule 0 1 -- 0 1 C 1.1508059365 0.2982718924 0.0240277739 O 0.3545181649 1.2334803420 -0.0015882208 N 0.8104369587 -1.0072797234 0.0043506838 H 2.2327270535 0.4686363261 0.0666232655 H -0.1675092286 -1.2596328526 -0.0352400180 H 1.5210524537 -1.7122494331 0.0139809901 -- 0 1 O -1.9693273428 -0.2999882700 -0.2293071572 H -1.3827632725 0.4697313642 -0.1375254289 H -2.7470364523 -0.0962178118 0.2907490329 $end $rem basis 6-31+g(d) method hf scf_convergence 8 cis_n_roots 2 cis_triplets false thresh 12 frgm_method stoll local_cis 1 ! no RI when doing iterative ALMO-CIS eigslv_meth 1 ! use iterative solver for ALMO-CIS nn_thresh 0 ! ALMO-CIS without CT correction make_cube_files true plots true point_group_symmetry false integral_symmetry false $end $plots grid_points 50 50 50 attachment_detachment_density 1-2 $end
