4.7.1 Introduction
The dual-basis approximation 797 Liang W. Z., Head-Gordon M.
(2004), 108, pp. 3206.
, 1246 Steele R. P. et al.
(2006), 125, pp. 074108.
, 1249 Steele R. P. et al.
(2006), 110, pp. 13915.
, 323 DiStasio, Jr. R. A., Steele R. P., Head-Gordon M.
Mol. Phys.
(2007), 105, pp. 2731.
, 1248 Steele R. P., Head-Gordon M.
Mol. Phys.
(2007), 105, pp. 2455.
, 1245 Steele R. P., DiStasio, Jr. R. A., Head-Gordon M.
(2009), 5, pp. 1560.
to self-consistent field (HF or DFT) energies provides an efficient means for obtaining large basis set effects at vastly less cost than a full SCF calculation in a large basis set. First, a full SCF calculation is performed in a chosen small basis (specified by BASIS2). Second, a single SCF-like step in the larger, target basis (specified, as usual, by BASIS) is used to perturbatively approximate the large basis energy. This correction amounts to a first-order approximation in the change in density matrix, after the single large-basis step:
Etotal=Esmall basis+tr⁢[(Δ⁢𝐏)⁢𝐅]large basis. (4.59)
Here 𝐅 (in the large basis) is built from the converged (small basis) density matrix. Thus, only a single Fock build is required in the large basis set. Currently, HF and DFT energies (SP) as well as analytic first derivatives (FORCE or OPT) are available.
Note:  As of version 4.0, first derivatives of unrestricted dual-basis DFT energies—though correct—require a code-efficiency fix. We do not recommend use of these derivatives until this improvement has been made.
Across the G3 set 289 Curtiss L. A. et al.
(1991), 94, pp. 7221.
, 288 Curtiss L. A. et al.
(1998), 109, pp. 7764.
, 287 Curtiss L. A. et al.
(2000), 112, pp. 7374.
of 223 molecules, using cc-pVQZ, dual-basis errors for B3LYP are 0.04 kcal/mol (energy) and 0.03 kcal/mol (atomization energy per bond) and are at least an order of magnitude less than using a smaller basis set alone. These errors are obtained at roughly an order of magnitude savings in cost, relative to the full, target-basis calculation.
