12.12 The Many-Body Expansion Method
12.12.2 Job Control
A MBE(n) calculation is requested by setting MANY_BODY_INT = TRUE in the $rem section. The level of theory used for the fragments will be whatever is specified in the $rem section. Researchers who use Q-Chem’s MBE code are asked to cite Ref.  1127 Richard R. M., Lao K. U., Herbert J. M.
(2014), 141, pp. 014108.
, 744 Lao K. U. et al.
(2016), 144, pp. 164105.
. In addition, please cite Ref.  1125 Richard R. M., Lao K. U., Herbert J. M.
J. Phys. Chem. Lett.
(2013), 4, pp. 2674.
for the MBCP(n) method.
MANY_BODY_INT
MANY_BODY_INT
       Perform a MBE calculation.
       TRUE Perform a MBE calculation. FALSE Do not perform a MBE calculation.
Additional MBE-specific options, such as the order of the expansion (n), are specified in a $mbe input section, as described below.
Order
       Specifies the order of the many-body expansion.
INPUT SECTION: $mbe
       n Perform an MBE(n) calculation.
       Orders n≤5 are available.
Embed
       Specifies the embedding method for EE-MBE(n).
INPUT SECTION: $mbe
       None Do not use embedding. Charges Use atomic point charges. Density Full Coulomb embedding using monomer densities.
       Use of atomic point charges requires a $mbe_charges section to specify the charges.
Q-Chem’s implementation of EE-MBE(n) with atomic point charges is designed to use with a $mbe_charges input section to specify fixed embedding charges. (Use of these charges is intended to accelerate convergence of the MBE by capturing many-body polarization effects and thus making the higher-order n-body terms smaller, although three- and four-body terms remain non-negligible even with embedding charges. 1128 Richard R. M., Lao K. U., Herbert J. M.
Acc. Chem. Res.
(2014), 47, pp. 2828.
, 818 Liu K.-Y., Herbert J. M.
(2017), 147, pp. 161729.
) The format of the $mbe_charges section is simply a list of charges in the same order as the atoms in the $molecule section. An example is provided below.
Many-body counterpoise corrections are requested with two keywords in the $mbe input section: BSSE_Type and BSSE_Order. These have only been implemented up to n=3, as the n=2 terms make by far the most significant contribution. 818 Liu K.-Y., Herbert J. M.
BSSE_Order
       Perform a many-body counterpoise correction of the MBCP(n) or VMFC(n) variety.
INPUT SECTION: $mbe
       0 Do not perform a counterpoise correction. n Perform a counterpoise correction truncated at order n.
       Orders n≤3 are available. Use the keyword BSSE_Type to choose between MBCP and VMFC.
BSSE_Type
       Select the type of many-body counterpoise correction, MBCP(n) or VMFC(n).
INPUT SECTION: $mbe
       MBCP
       MBCP Use MBCP(n). VMFC Use VMFC(n).
       The two methods are equivalent for n=2 but different for n≥3. MBCP(n) contains fewer terms but generally provides comparable results as compared to the formally more complete VMFC(n) approach.
Example 12.45  Example showing a EE-MBE(3) calculation using TIP3P charges.
   O -1.126149 -1.748387 -0.423240
   H -0.234788 -1.493897 -0.661862
   H -1.062789 -2.681331 -0.218819
   O -0.254210 1.611495 -1.293845
   H -1.001520 1.163510 -1.690129
   H -0.153399 2.411746 -1.809248
   O 1.694541 -0.226287 1.705739
   H 0.785920 0.073487 1.677909
   H 2.047134 0.150917 2.511706
   O -0.864533 0.522472 1.218817
   H -0.694120 1.093542 0.469789
   H -1.131418 -0.310426 0.829702
point_group_symmetry False
   METHOD            B3LYP
   BASIS             cc-pVDZ
   MANY_BODY_INT     true
   THRESH            14
   SCF_CONVERGENCE   7
$mbe
  order 3
  embed charges
$mbe_charges
  -0.834
   0.417
   0.417
  -0.834
   0.417
   0.417
  -0.834
   0.417
   0.417
  -0.834
   0.417
   0.417
Example 12.46  Example of a MBCP(3) calculation.
   MANY_BODY_INT     TRUE
   METHOD            B3LYP
   BASIS             cc-pVDZ
   THRESH            12
   SCF_CONVERGENCE   6
$mbe
  BSSE_Order 3
  BSSE_Type MBCP ! this is the default
