HFPC/DFPC calculations are controlled with the following $rem. HFPT turns on the HFPC/DFPC approximation. Note that HFPT_BASIS specifies the secondary basis set.
HFPT
HFPT
Activates HFPC/DFPC calculation.
Single-point energy only
Use Dual-Basis to capture large-basis effects at smaller basis cost. See
reference for recommended basis set, functional, and grid pairings.
HFPT_BASIS
HFPT_BASIS
Specifies the secondary basis in a HFPC/DFPC calculation.
See reference for recommended basis set, functional, and grid pairings.
DFPT_XC_GRID
DFPT_XC_GRID
Specifies the secondary grid in a HFPC/DFPC calculation.
DFPT_EXCHANGE
DFPT_EXCHANGE
Specifies the secondary functional in a HFPC/DFPC calculation.
