7.9.6 CIS(D) Job Control and Examples
The legacy CIS(D) algorithm in Q-Chem is handled by the CCMAN/CCMAN2 modules of Q-Chem’s and shares many of the $rem options. RI-CIS(D), SOS-CIS(D), and SOS-CIS(D0) do not depend on the coupled-cluster routines. Users who will not use this legacy CIS(D) method may skip to Section 7.9.7.
As with all post-HF calculations, it is important to ensure there are sufficient resources available for the necessary integral calculations and transformations. For CIS(D), these resources are controlled using the $rem variables CC_MEMORY, MEM_STATIC and MEM_TOTAL (see Section 6.12.11).
EE_STATES
EE_STATES
       INTEGER/INTEGER ARRAY
EE_SINGLETS
EE_SINGLETS
EE_TRIPLETS
EE_TRIPLETS
SF_STATES
SF_STATES
CC_STATE_TO_OPT
CC_STATE_TO_OPT
       INTEGER ARRAY
Example 7.57  CIS(D) excitation energy calculation for ozone at the experimental ground state geometry C2⁢v
   O  1  RE
   O  2  RE  1  A
   RE = 1.272
   A  = 116.8
   METHOD           CIS(D)
   BASIS            6-31G*
   N_FROZEN_CORE    3            use frozen core
   EE_SINGLETS      [2,2,2,2]    find 2 lowest singlets in each irrep.
   EE_TRIPLETS      [2,2,2,2]    find 2 lowest triplets in each irrep.
   CCMAN2           false
Example 7.58  CIS(D) geometry optimization for the lowest triplet state of water. The symmetry is automatically turned off for finite difference calculations
   o
   h  1  r
   h  1  r  2  a
   r  0.95
   a  104.0
   JOBTYPE            opt
   BASIS              3-21g
   METHOD             cis(d)
Example 7.59  CIS(D) excitation energy and transition property calculation (between all states) for ozone at the experimental ground state geometry C2⁢v
   O  1  RE
   O  2  RE  1  A
   RE = 1.272
   A  = 116.8
   BASIS              6-31G*
   METHOD             CIS(D)
   CC_TRANS_PROP      1
   CCMAN2             FALSE
