Active space specification and convergence details are controlled by the $rem variables described in Section 6.20.2. During the course of an ASCI calculation, a file named wf_data is created in the scratch directory containing information on the determinants and weights in the ASCI wavefunction.
ASCI_DIAG
ASCI_DIAG
Specifies the diagonalization procedure.
Davidson solver
Eigen sparse matrix solver
Use 2 for best trade-off of speed and memory usage. If memory usage becomes to great, switch to 1.
ASCI_NDETS
ASCI_NDETS
Specifies the number of determinants to include in the ASCI wavefunction.
for a wavefunction with  determinants
Typical ASCI expansions range from 50,000 to 2,000,000 determinants depending on active space size, complexity of problem, and desired accuracy
ASCI_CDETS
ASCI_CDETS
Specifies the number of determinants to search over during ASCI wavefunction growth steps.
-5
search from the top  determinants
search from the top determinants whose cumulative weight in the wavefunction corresponds to
Using a dynamically determined value () gives better results.
ASCI_USE_NAT_ORBS
ASCI_USE_NAT_ORBS
Specifies whether rotation to a natural orbital basis should be carried out between growth steps.
rotate to a natural orbital basis between growth wavefunction growth steps
do not rotate to a natural orbital basis
Natural orbital rotations significantly improve the compactness and therefore accuracy of the ASCI wavefunction.
ASCI_DAVIDSON_GUESS
ASCI_DAVIDSON_GUESS
Specifies the truncated CI guess used for ASCI’s Davidson solver.
Order of the truncated CI to solve explicitly ASCI Davidson guess.
Accurate excited states and rapid convergence of the ground state benefit from a good zero-order guess for the low energy spectrum. The default is often sufficient.
ASCI_SKIP_PT2
ASCI_SKIP_PT2
Specifies whether ASCI PT2 correction should be calculated.
compute ASCI PT2 contribution
do not compute ASCI PT2 contribution
The PT2 correction is essential to obtaining converged ASCI energies.
ASCI_RESTART
ASCI_RESTART
Specifies whether to initialize the ASCI wavefunction with the wf_data file.
read CI coefficients from the wf_data file
do not read the CI coefficients from disk
ASCI_SPIN_PURIFY
ASCI_SPIN_PURIFY
Indicates whether or not the ASCI wavefunction should be augmented with missing
determinants to ensure a spin-pure state.
augment the wavefunction with determinants to ensure a spin eigenstate
do not augment the wavefunction
Example 6.55 CASCI calculation for the lowest triplet () state of N. The adaptive sampling method is employed to tackle a large active space (14e, 32o). The PT2 correction is performed on top of the ASCI wavefunction.
$molecule 0 1 N 0.0 0.0 0.0 N 0.0 0.0 1.8 $end $rem EXCHANGE hf BASIS cc-pvtz CAS_METHOD 1 !1 for CAS-CI, 2 for CASSCF CAS_M_S 2 !M_s value*2 (2: triplet) ASCI_DIAG 2 !Arma Sparse=0, Davidson=1, Eigen Sparse=2 CAS_N_ELEC 14 !N_elec CAS_N_ORB 32 !N_orb CAS_N_ROOTS 1 !N_roots CAS_SOLVER 2 !2=ASCI, 1=Olsen, 0=naive ASCI_NDETS 28000 !Number of ASCI Determinants THRESH 14 MAX_SCF_CYCLES 400 SCF_CONVERGENCE 8 MEM_TOTAL 4000 MEM_STATIC 1000 ROSCF true SCF_ALGORITHM diis_gdm INTEGRAL_SYMMETRY false POINT_GROUP_SYMMETRY false $end
Example 6.56 ASCI-SCF (using adaptive sapling for CAS) calculation for the ground state of N with a large active space (14e, 32o). The PT2 correction is not performed in this case.
$molecule 0 1 N 0.0 0.0 0.0 N 0.0 0.0 1.8 $end $rem EXCHANGE hf BASIS cc-pvtz CAS_METHOD 2 !1 for CAS-CI, 2 for CASSCF CAS_M_S 0 !M_s value*2 ASCI_DIAG 2 !Arma Sparse=0, Davidson=1, Eigen Sparse=2 CAS_N_ELEC 14 !N_elec CAS_N_ORB 32 !N_orb CAS_N_ROOTS 1 !N_roots CAS_SOLVER 2 !2=ASCI, 1=Olsen, 0=naive ASCI_NDETS 28000 !Number of ASCI Determinants ASCI_SKIP_PT2 1 THRESH 14 MAX_SCF_CYCLES 400 SCF_CONVERGENCE 6 MEM_TOTAL 4000 MEM_STATIC 1000 SCF_ALGORITHM diis_gdm INTEGRAL_SYMMETRY false POINT_GROUP_SYMMETRY false $end
