9.4 Application of Pressure
9.4.1 Introduction
Q-Chem features a number of methods to apply pressure to a chemical system during a geometry optimization or an AIMD simulation.1070 The following methods are implemented:
Hydrostatic Compression Force Field (HCFF)1067 Section 9.4.2
eXtended Hydrostatic Compression Force Field (X-HCFF)1069 Section 9.4.3
Gaussians On Surface Tesserae Simulate HYdrostatic Pressure (GOSTSHYP)997 Section 9.4.4
To invoke one of these methods, set DISTORT = TRUE in the $rem section. By setting the $rem variable scf_final_print = 1, the energy contribution due to pressure is printed in the output.
DISTORT
DISTORT
       Specifies whether to apply pressure or external force to a chemical system
       False
       False Do not use pressure or force True Use pressure or force
       Set to true to apply pressure or force.
The parameters of the jobs are set via options specified in the $distort input section. The format of the $distort section is analogous to the $rem section:
$distort
  <Keyword>  <parameter/option>
Note:  The following job control variables belong only in the $distort  section. Do not place them in the $rem section.
Model
       Specifies which model is used to distort the molecule.
INPUT SECTION: $distort
       HCFF Hydrostatic Compression Force Field1067 XHCFF eXtended Hydrostatic Compression Force Field1069 GOSTSHYP Gaussians On Surface Tesserae Simulate HYdrostatic Pressure997 EFEI External Force is Explicitly Included (Section 9.5)
       Please refer to the following subsections for recommendations on which model to use.
Pressure
       Specifies the pressure (in MPa) used to compress the molecule.
       DOUBLE
       User defined
NPoints_Heavy
       Specifies the number of tessellation points per non-hydrogen atom.
       110
       User defined
       Use the default.
NPoints_Hydrogen
       Specifies the number of tessellation points per hydrogen atom.
       110
       User defined
       Use the default.
Scaling
       Specifies the scaling factor of the atomic van der Waals radii used in the tessellation of the molecular surface, which is used in the pressure models.
       DOUBLE
       1.2
       User defined
       Increase when modeling a chemical complex to make sure that the complex is placed inside a single cavity.997 A value of 1.0 was suggested to be used in the X-HCFF model.1069
Gostshyp_Mem
       Specifies the amount of memory, the gostshyp model is allowed to allocate in MB.
       66% of MEM_TOTAL
       User defined
       Set larger than expected gostshyp memory usage. As a rule of thumb gostshyp will need 5⋅NB⁢a⁢s⁢i⁢s2⋅Nt⁢e⁢s⁢s Bytes memory.
screener
       Enables/disables Integral screening for gostshyp calculations.
       BOOL
       true
       true Enable integral screening for gostshyp false Disable integral screening for gostshyp
       Use default. Disabling integral screening will lead to much higher memory usage and severe performance drops.
