10.2 Wave Function Analysis
10.2.8 Basic Excited-State Analysis of CIS and TDDFT Wave Functions
For CIS, TDHF, and TDDFT excited-state calculations, we have already mentioned that Mulliken population analysis of the excited-state electron densities may be requested by setting POP_MULLIKEN = -1, and multipole moments of the excited-state densities will be generated if CIS_MOMENTS = TRUE. Another useful decomposition for excited states is to separate the excitation into “particle” and “hole” components, which can then be analyzed separately.966 To do this, we define a density matrix for the excited electron,
𝐃a⁢belec=∑i(𝐗+𝐘)a⁢i†⁢(𝐗+𝐘)i⁢b (10.14)
𝐃i⁢jhole=∑a(𝐗+𝐘)i⁢a⁢(𝐗+𝐘)a⁢j† (10.15)
The quantities 𝐗 and 𝐘 are the transition density matrices, i.e., the components of the TDDFT eigenvector.290 The indices i and j denote MOs that occupied in the ground state, whereas a and b index virtual MOs. Note also that 𝐃e⁢l⁢e⁢c+𝐃h⁢o⁢l⁢e=Δ⁢𝐏, the difference between the ground- and excited-state density matrices.
Upon transforming 𝐃elec and 𝐃hole into the AO basis, one can write
Δ⁢q=∑μ(𝐃elec⁢𝐒)μ⁢μ=-∑μ(𝐃hole⁢𝐒)μ⁢μ (10.16)
where Δ⁢q is the total charge that is transferred from the occupied space to the virtual space. For a CIS calculation, or for TDDFT within the Tamm-Dancoff approximation,471 Δ⁢q=-1. For full TDDFT calculations, Δ⁢q may be slightly different than -1.
Comparison of Eq. (10.16) to Eq. (10.3) suggests that the quantities (𝐃elec⁢𝐒) and (𝐃hole⁢𝐒) are amenable to population analyses of precisely the same sort used to analyze the ground-state density matrix. In particular, (𝐃elec⁢𝐒)μ⁢μ represents the μth AO’s contribution to the excited electron, while (𝐃hole⁢𝐒)μ⁢μ is a contribution to the hole. The sum of these quantities,
Δ⁢qμ=(𝐃elec⁢𝐒)μ⁢μ+(𝐃hole⁢𝐒)μ⁢μ (10.17)
represents the contribution to Δ⁢q arising from the μth AO. For the particle/hole density matrices, both Mulliken and Löwdin population analyses available, and are requested by setting CIS_MULLIKEN = TRUE.
CIS_MULLIKEN
CIS_MULLIKEN
       Controls Mulliken and Löwdin population analyses for excited-state particle and hole density matrices.
       FALSE Do not perform particle/hole population analysis. TRUE Perform both Mulliken and Löwdin analysis of the particle and hole density matrices for each excited state.
Although the excited-state analysis features described in this section require very little computational effort, they are turned off by default, because they can generate a large amount of output, especially if a large number of excited states are requested. They can be turned on individually, or collectively by setting CIS_AMPL_ANAL = TRUE. This collective option also requests the calculation of natural transition orbitals (NTOs), which were introduced in Section 7.14.3. (NTOs can also be requested without excited-state population analysis. Some practical aspects of calculating and visualizing NTOs are discussed below, in Section 10.5.3.)
CIS_AMPL_ANAL
CIS_AMPL_ANAL
       Perform additional analysis of CIS and TDDFT excitation amplitudes, including generation of natural transition orbitals, excited-state multipole moments, and Mulliken analysis of the excited state densities and particle/hole density matrices.
       TRUE Perform additional amplitude analysis. FALSE Do not perform additional analysis.
CIS_AMPL_PRINT
CIS_AMPL_PRINT
       15
       n Print if |xi⁢a| or |yi⁢a| is larger than 0.1×n.
