12.18 TDDFT for Molecular Interactions
12.18.2 Job Control
In addition to the normal TDDFT job controls variables described in Section 7.3.3, there are several others to request TDDFT(MI). Note that only single-point energies (not gradients) are available for this method.
TDDFT_MI
TDDFT_MI
       Perform an TDDFT(MI) calculation
       FALSE Do not perform an TDDFT(MI) calculation TRUE Perform an TDDFT(MI) calculation
       False
MI_ACTIVE_FRAGMENT
MI_ACTIVE_FRAGMENT
       Sets the active fragment
       NO DEFAULT
       n Specify the fragment on which the TDDFT calculation is to be performed, for LEA-TDDFT(MI).
MI_LEA
MI_LEA
       Controls the LEA-TDDFT(MI) methods
       NO DEFAULT
       0 The LEA0 method 1 The LEA-Q method 2 The LEAc method
