1.1 About This Manual
1.1.2 Chapter Summaries
Ch. 1:
General overview of Q-Chem’s features, contributors, and contact information.
Ch. 2:
Procedures to install, test, and run Q-Chem on your machine.
Ch. 3:
Overview of the Q-Chem command-line input.
Ch. 4:
Running ground-state self-consistent field calculations.
Ch. 5:
Details specific to running density functional theory (DFT) calculations.
Ch. 6:
Running post-Hartree-Fock correlated wave function calculations for ground states.
Ch. 7:
Running calculations for excited states and open-shell species.
Ch. 8:
Using Q-Chem’s built-in basis sets, or specifying a user-defined basis set.
Ch. 9:
Using Q-Chem’s effective core potential capabilities.
Ch. 10:
Options available for exploring potential energy surfaces, such as determining critical points (transition states and local minima on a single surface, or minimum-energy crossing points between surfaces) as well as ab initio molecular dynamics.
Ch. 11:
Molecular properties and a posteriori wave function analysis.
Ch. 12:
Methods for molecules in complex environments, including implicit solvation models, QM/MM models, the Effective Fragment Potential, and density embedding.
Ch. 13:
Fragment-based approaches for efficient calculations on large systems, calculation of non-covalent interactions, and energy decomposition analysis.
App. A:
Overview of the Optimize package used for determining molecular geometry critical points.
App. B:
Overview of the AOInts library, which contains some of the fastest two-electron integral code currently available.
App. C:
Quick-reference section containing an alphabetized list of job control variables.
