11.5.9 Input keywords
EFP_COORD_XYZ
EFP_COORD_XYZ
       Use coordinates of three atoms instead of Euler angles to specify position and orientation of the fragments
       TRUE FALSE
       TRUE FALSE
EFP_ENABLE_LINKS
EFP_ENABLE_LINKS
       TRUE FALSE
EFP
EFP
       TRUE FALSE
EFP_FRAGMENTS_ONLY
EFP_FRAGMENTS_ONLY
       FALSE QM part is present
       TRUE Only MM part is present: all fragments are treated by EFP FALSE QM part is present: do QM/MM EFP calculation
EFP_INPUT
EFP_INPUT
       FALSE Dummy atom (e.g., He) in $molecule section should be present
       TRUE A format without dummy atom in $molecule section FALSE A format with dummy atom in $molecule section
FEFP_EFP
FEFP_EFP
       Specifies that fEFP_EFP calculation is requested to compute the total interaction energies between a ligand (the last fragment in the $efp_fragments section) and the protein (represented by fEFP)
       OFF
       OFF disables fEFP LA enables fEFP with the Link Atom (HLA or CLA) scheme (only electrostatics and polarization) MFCC enables fEFP with MFCC (only electrostatics)
       The keyword should be invoked if EFP/fEFP is requested (interaction energy calculations). This keyword has to be employed with EFP_FRAGMENT_ONLY = TRUE. To switch on/off electrostatics or polarzation interactions, the usual EFP controls are employed.
FEFP_QM
FEFP_QM
       Specifies that fEFP_QM calculation is requested to perform a QM/fEFPcompute computation. The fEFP part is a fractionated macromolecule.
       OFF
       OFF disables fEFP_QM and performs a QM/EFP calculation LA enables fEFP_QM with the Link Atom scheme
       The keyword should be invoked if QM/fEFP is requested. This keyword has to be employed with efp_fragment_only false. Only electrostatics is available.
EFP_ELEC
EFP_ELEC
       TRUE switch on electrostatics FALSE switch off electrostatics
EFP_POL
EFP_POL
       TRUE switch on polarization FALSE switch off polarization
EFP_DISP
EFP_DISP
       TRUE switch on dispersion FALSE switch off dispersion
EFP_EXREP
EFP_EXREP
       TRUE switch on exchange repulsion FALSE switch off exchange repulsion
EFP_QM_ELEC
EFP_QM_ELEC
       TRUE switch on QM-EFP electrostatics FALSE switch off QM-EFP electrostatics
EFP_QM_POL
EFP_QM_POL
       Controls QM-EFP polarization
       TRUE switch on QM-EFP polarization FALSE switch off QM-EFP polarization
EFP_QM_DISP
EFP_QM_DISP
       Controls QM-EFP dispersion
       TRUE switch on QM-EFP dispersion FALSE switch off QM-EFP dispersion
EFP_QM_EXREP
EFP_QM_EXREP
       TRUE switch on QM-EFP exchange-repulsion FALSE switch off QM-EFP exchange-repulsion
EFP_ELEC_DAMP
EFP_ELEC_DAMP
       0 switch off electrostatic screening 1 use overlap-based damping correction 2 use exponential damping correction if screening parameters are provided in the EFP potential
EFP_DISP_DAMP
EFP_DISP_DAMP
       0 switch off dispersion screening 1 use Tang-Toennies screening, with fixed parameter b=1.5 2 use overlap-based damping
EFP_POL_DAMP
EFP_POL_DAMP
       0 switch off polarization screening 1 use Tang-Toennies screening
EFP_QM_ELEC_DAMP
EFP_QM_ELEC_DAMP
       0 switch off electrostatic screening 1 use overlap based damping correction
