5.4 Basic DFT Job Control
5.4.1 Overview
Basic SCF job control was described in Section 4.3 in the context of Hartree-Fock theory and is largely the same for DFT. The keywords METHOD and BASIS are required, although for DFT the former could be substituted by specifying EXCHANGE and CORRELATION instead.
METHOD
METHOD
       No default
       NAME Use METHOD = NAME, where NAME is either HF for Hartree-Fock theory or else one of the DFT methods listed in Section 5.3.5.
EXCHANGE
EXCHANGE
       Specifies the exchange functional (or most exchange-correlation functionals for backwards compatibility).
       No default
       NAME Use EXCHANGE = NAME, where NAME is either: 1) One of the exchange functionals listed in Section 5.3.3 2) One of the XC functionals listed in Section 5.3.5 that is not marked with an asterisk. 3) GEN, for a user-defined functional (see Section 5.3.7).
       In general, consult the literature to guide your selection. Our recommendations are indicated in bold in Sections 5.3.5 and  5.3.3.
CORRELATION
CORRELATION
       Specifies the correlation functional.
       NAME Use CORRELATION = NAME, where NAME is one of the correlation functionals listed in Section 5.3.4.
       In general, consult the literature to guide your selection. Our recommendations are indicated in bold in Section 5.3.4.
The following $rem variables are related to the choice of the quadrature grid required to integrate the XC part of the functional, which does not appear in Hartree-Fock theory. DFT quadrature grids are described in Section 5.5.
FAST_XC
FAST_XC
       Controls direct variable thresholds to accelerate exchange-correlation (XC) in DFT.
       TRUE Turn FAST_XC on. FALSE Do not use FAST_XC.
       Caution: FAST_XC improves the speed of a DFT calculation, but may occasionally cause the SCF calculation to diverge.
XC_GRID
XC_GRID
       0 Use SG-0 for H, C, N, and O; SG-1 for all other atoms. n Use SG-n for all atoms, n=1,2, or 3 X⁢Y A string of two six-digit integers X and Y, where X is the number of radial points and Y is the number of angular points where possible numbers of Lebedev angular points, which must be an allowed value from Table 5.2 in Section 5.5. -X⁢Y Similar format for Gauss-Legendre grids, with the six-digit integer X corresponding to the number of radial points and the six-digit integer Y providing the number of Gauss-Legendre angular points, Y=2⁢N2.
NL_GRID
NL_GRID
       Specifies the grid to use for non-local correlation.
       Same as for XC_GRID
       Use the default unless computational cost becomes prohibitive, in which case SG-0 may be used. XC_GRID should generally be finer than NL_GRID.
XC_SMART_GRID
XC_SMART_GRID
       Uses SG-0 (where available) for early SCF cycles, and switches to the (larger) target grid specified by XC_GRID for final cycles of the SCF.
       TRUE (or 1) Use the smaller grid for the initial cycles. FALSE (or 0) Use the target grid for all SCF cycles.
       The use of the smart grid can save some time on initial SCF cycles.
