Active space specification and convergence details are controlled by the $rem variables described in Section 6.19.3. During the course of an ASCI calculation, a file named wf_data is created in the scratch directory containing information on the determinants and weights in the ASCI wavefunction.
ASCI_DIAG
ASCI_DIAG
Specifies the diagonalization procedure.
Davidson solver
Eigen sparse matrix solver
Use 2 for best trade-off of speed and memory usage. If memory usage becomes to great, switch to 1.
ASCI_NDETS
ASCI_NDETS
Specifies the number of determinants to include in the ASCI wavefunction.
N
for a wavefunction with N determinants
Typical ASCI expansions range from 50,000 to 2,000,000 determinants depending on active space size, complexity of problem, and desired accuracy
ASCI_CDETS
ASCI_CDETS
Specifies the number of determinants to search over during ASCI wavefunction growth steps.
-5
N>0
search from the top N determinants
N<0
search from the top determinants whose cumulative weight in the wavefunction corresponds to 1-2N
Using a dynamically determined value (N<0) gives better results.
ASCI_USE_NAT_ORBS
ASCI_USE_NAT_ORBS
Specifies whether rotation to a natural orbital basis should be carried out between growth steps.
rotate to a natural orbital basis between growth wavefunction growth steps
do not rotate to a natural orbital basis
Natural orbital rotations significantly improve the compactness and therefore accuracy of the ASCI wavefunction.
ASCI_DAVIDSON_GUESS
ASCI_DAVIDSON_GUESS
Specifies the truncated CI guess used for ASCI’s Davidson solver.
N
Order of the truncated CI to solve explicitly ASCI Davidson guess.
Accurate excited states and rapid convergence of the ground state benefit from a good zero-order guess for the low energy spectrum. The default is often sufficient.
ASCI_SKIP_PT2
ASCI_SKIP_PT2
Specifies whether ASCI PT2 correction should be calculated.
compute ASCI PT2 contribution
do not compute ASCI PT2 contribution
The PT2 correction is essential to obtaining converged ASCI energies.
ASCI_RESTART
ASCI_RESTART
Specifies whether to initialize the ASCI wavefunction with the wf_data file.
read CI coefficients from the wf_data file
do not read the CI coefficients from disk
ASCI_SPIN_PURIFY
ASCI_SPIN_PURIFY
Indicates whether or not the ASCI wavefunction should be augmented with missing
determinants to ensure a spin-pure state.
augment the wavefunction with determinants to ensure a spin eigenstate
do not augment the wavefunction
Example 6.48 CASCI calculation for the lowest triplet (Ms=1) state of N2. The adaptive sampling method is employed to tackle a large active space (14e, 32o). The PT2 correction is performed on top of the ASCI wavefunction.
$molecule 0 1 N 0.0 0.0 0.0 N 0.0 0.0 1.8 $end $rem EXCHANGE hf BASIS cc-pvtz CAS_METHOD 1 !1 for CAS-CI, 2 for CASSCF CAS_M_S 2 !M_s value*2 (2: triplet) ASCI_DIAG 2 !Arma Sparse=0, Davidson=1, Eigen Sparse=2 CAS_N_ELEC 14 !N_elec CAS_N_ORB 32 !N_orb CAS_N_ROOTS 1 !N_roots CAS_SOLVER 2 !2=ASCI, 1=Olsen, 0=naive ASCI_NDETS 28000 !Number of ASCI Determinants THRESH 14 MAX_SCF_CYCLES 400 SCF_CONVERGENCE 8 MEM_TOTAL 4000 MEM_STATIC 1000 ROSCF true SYMMETRY false SYM_IGNORE true SCF_ALGORITHM diis_gdm $end
Example 6.49 ASCI-SCF (using adaptive sapling for CAS) calculation for the ground state of N2 with a large active space (14e, 32o). The PT2 correction is not performed in this case.
$molecule 0 1 N 0.0 0.0 0.0 N 0.0 0.0 1.8 $end $rem EXCHANGE hf BASIS cc-pvtz CAS_METHOD 2 !1 for CAS-CI, 2 for CASSCF CAS_M_S 0 !M_s value*2 ASCI_DIAG 2 !Arma Sparse=0, Davidson=1, Eigen Sparse=2 CAS_N_ELEC 14 !N_elec CAS_N_ORB 32 !N_orb CAS_N_ROOTS 1 !N_roots CAS_SOLVER 2 !2=ASCI, 1=Olsen, 0=naive ASCI_NDETS 28000 !Number of ASCI Determinants ASCI_SKIP_PT2 1 THRESH 14 MAX_SCF_CYCLES 400 SCF_CONVERGENCE 6 MEM_TOTAL 4000 MEM_STATIC 1000 SYMMETRY false SYM_IGNORE true SCF_ALGORITHM diis_gdm $end
