9.10 Ab Initio Path Integrals
9.10.2 Job Control and Examples
PIMC_NBEADSPERATOM
PIMC_NBEADSPERATOM
       Number of path integral time slices (“beads”) used on each atom of a PIMC simulation.
       1 Perform classical Boltzmann sampling. >1 Perform quantum-mechanical path integral sampling.
       This variable controls the inherent convergence of the path integral simulation. The one-bead limit represents classical sampling and the infinite-bead limit represents exact quantum-mechanical sampling. Using 32 beads is reasonably converged for room-temperature simulations of molecular systems.
PIMC_TEMP
PIMC_TEMP
       Temperature, in Kelvin (K), of path integral simulations.
       User-specified number of Kelvin for PIMC or classical MC simulations.
PIMC_MCMAX
PIMC_MCMAX
       Number of Monte Carlo steps to sample.
       User-specified number of steps to sample.
       This variable dictates the statistical convergence of MC/PIMC simulations. For converged simulations at least 105 steps is recommended.
PIMC_WARMUP_MCMAX
PIMC_WARMUP_MCMAX
       Number of Monte Carlo steps to sample during an equilibration period of MC/PIMC simulations.
       Use this variable to equilibrate the molecule/ring polymer before collecting production statistics. Usually a short run of roughly 10% of PIMC_MCMAX is sufficient.
PIMC_MOVETYPE
PIMC_MOVETYPE
       Selects the type of displacements used in MC/PIMC simulations.
       0 Cartesian displacements of all beads, with occasional (1%) center-of-mass moves. 1 Normal-mode displacements of all modes, with occasional (1%) center-of-mass moves. 2 Levy flights without center-of-mass moves.
       Except for classical sampling (MC) or small bead-number quantum sampling (PIMC), Levy flights should be used. For Cartesian and normal-mode moves, the maximum displacement is adjusted during the warm-up run to the desired acceptance rate (controlled by PIMC_ACCEPT_RATE). For Levy flights, the acceptance is solely controlled by PIMC_SNIP_LENGTH.
PIMC_ACCEPT_RATE
PIMC_ACCEPT_RATE
       Acceptance rate for MC/PIMC simulations when Cartesian or normal-mode displacements are used.
       0<n<100 User-specified rate, given as a whole-number percentage.
       Choose acceptance rate to maximize sampling efficiency, which is typically signified by the mean-square displacement (printed in the job output). Note that the maximum displacement is adjusted during the warm-up run to achieve roughly this acceptance rate.
PIMC_SNIP_LENGTH
PIMC_SNIP_LENGTH
       Number of “beads” to use in the Levy flight movement of the ring polymer.
       3≤n≤PIMC_NBEADSPERATOM User-specified length of snippet.
       Choose the snip length to maximize sampling efficiency. The efficiency can be estimated by the mean-square displacement between configurations, printed at the end of the output file. This efficiency will typically, however, be a trade-off between the mean-square displacement (length of statistical correlations) and the number of beads moved. Only the moved beads require recomputing the potential, i.e., a call to Q-Chem for the electronic energy. (Note that the endpoints of the snippet remain fixed during a single move, so n-2 beads are actually moved for a snip length of n. For 1 or 2 beads in the simulation, Cartesian moves should be used instead.)
Example 9.37  Path integral Monte Carlo simulation of H2 at room temperature
The number of Monte Carlo steps is deliberately set low, more typical
values would be:
   PIMC_WARMUP_MCMAX    10000   !Equilibration run
   PIMC_MCMAX           100000  !Production run
   H
   H 1 0.75
   JOBTYPE              pimc
   METHOD               hf
   BASIS                sto-3g
   PIMC_TEMP            298
   PIMC_NBEADSPERATOM   32
   PIMC_WARMUP_MCMAX    100     !Equilibration run
   PIMC_MCMAX           1000    !Production run
   PIMC_MOVETYPE        2         !Levy flights
   PIMC_SNIP_LENGTH     10        !Moves 8 beads per MC step (10-endpts)
Example 9.38  Classical Monte Carlo simulation of a water molecule at 500K
values would be:
   H
   O 1 1.0
   H 2 1.0 1 104.5
   JOBTYPE              pimc
   METHOD               rimp2
   BASIS                cc-pvdz
   AUX_BASIS            rimp2-cc-pvdz
   PIMC_TEMP            500
   PIMC_NBEADSPERATOM   1       !1 bead is classical sampling
   PIMC_MOVETYPE        0       !Cartesian displacements (ok for 1 bead)
   PIMC_ACCEPT_RATE     40      !During warm-up, adjusts step size to 40% acceptance
