5.13.6 CDFT-CI Job Control and Examples
CDFTCI
CDFTCI
CDFTCI_PRINT
CDFTCI_PRINT
CDFT_LAMBDA_MODE
CDFT_LAMBDA_MODE
CDFTCI_SKIP_PROMOLECULES
CDFTCI_SVD_THRESH
CDFTCI_SVD_THRESH
       By default, a symmetric orthogonalization is performed on the CDFT-CI matrix before diagonalization. If the CDFT-CI overlap matrix is nearly singular (i.e., some of the diabatic states are nearly degenerate), then this orthogonalization can lead to numerical instability. When computing 𝐒-1/2, eigenvalues smaller than 10-CDFTCI⁢_⁢SVD⁢_⁢THRESH are discarded.
       4
       n for a threshold of 10-n.
CDFTCI_STOP
CDFTCI_STOP
CDFTCI_RESTART
CDFTCI_RESTART
Example 5.5.32  CDFT-CI calculation of couplings between the anionic GFP chromophore (CHR:1-27) and a tyrosine (TYR:28-43) residue. The two diabatic states are Chro-(MS=0)…Tyr(MS=0) and Chro(MS=1/2)…Tyr-(MS=1/2).
   METHOD           = b3lyp
   BASIS            = cc-pvdz
   SYMMETRY         = off
   SYM_IGNORE       = true
   UNRESTRICTED     = true
   SCF_CONVERGENCE  = 8
   MAX_SCF_CYCLES   = 200
   CDFTCI           = true
   CDFTCI_PRINT     = 2
   CDFT_THRESH      = 7
$cdft
   1.0
   1.0   1   27
   0.0
   1.0   1   27 S
   0.0
   1.0   1   27
  -1.0
   1.0   1   27 S
