6.6.3 OpenMP Implementation of RI-MP2
An OpenMP RI-MP2 energy algorithm is used by default in Q-Chem 4.1 onward. This can be invoked by using CORR = PRIMP2 for older versions, but note that in 4.01 and below, only RHF/RI-MP2 was supported. Now UHF/RI-MP2 and ROHF/RI-MP2 is supported, and the formation of the ‘B’ matrices as well as three center integrals are parallelized. This algorithm uses the remaining memory from the MEM_TOTAL allocation for all computation, which can drastically reduce hard drive reads in the formation of t-amplitudes. Since Q-Chem 5.2, RI-MP2 can be invoked by using method=mp2 and proper auxiliary basis using AUX_BASIS_CORR. In case of double-hybrid, adding AUX_BASIS_CORR will simply invoke RI-MP2.
Example 6.4  Example of OpenMP-parallel RI-MP2 job.
   C1
   H1  C1    1.077260
   H2  C1    1.077260  H1  131.608240
   EXCHANGE           HF
   CORRELATION        pRIMP2
   BASIS              cc-pVTZ
   AUX_BASIS          rimp2-cc-pVTZ
   PURECART           11111
   SYMMETRY           false
   THRESH             12
   SCF_CONVERGENCE    8
   MAX_SUB_FILE_NUM   128
   !TIME_MP2          true
