5.8 Empirical Corrections for Basis Set Superposition Error
5.8.1 Overview
This section describes DFT-C,1227 an empirical correction for basis set superposition error (BSSE) in DFT calculations that is an adaptation of Grimme’s geometrical counterpoise (gCP) correction.596 Unlike the traditional Boys-Bernardi counterpoise correction (Section 8.9),124 the cost of the DFT-C correction is essentially zero (on the scale of a DFT calculation), and the latter provides an estimate of both inter- and intramolecular BSSE. The form of this correction is
EDFT-C=σ⁢∑AatomscA⁢∑B≠AatomsgA⁢B∗DFT-C⁢(RA⁢B)⁢hA⁢B∗⁢({A,B,…}) (5.54)
where gA⁢B∗DFT-C is a damped, pairwise BSSE correction,
gA⁢B∗DFT-C⁢(RA⁢B)=d⁢(RA⁢B)⁢fA⁢B∗DFT-C⁢(RA⁢B)+[1-d⁢(RA⁢B)]⁢fA⁢B∗DFT-C⁢(Rcov,A⁢B). (5.55)
The quantity
fA⁢B∗DFT-C⁢(RA⁢B)=cA⁢B⁢exp⁡(-αA⁢B⁢RA⁢B2+βA⁢B⁢RA⁢B) (5.56)
is the undamped pairwise BSSE and
d⁢(RA⁢B)=11+k1,A⁢B⁢(RA⁢B/R0,A⁢B)-k2,A⁢B (5.57)
is a damping function. The quantity hA⁢B∗⁢({A,B,…}) is a many-body correction to the two-body BSSE correction, given by
hA⁢B∗⁢({A,B,…})=[1+∑C≠A,BNCvirtNBvirt⁢terfc⁡(RA⁢C,RA⁢B)⁢terfc⁡(RB⁢C,RA⁢B)]-1 (5.58)
where
terfc⁡(x,y)=1-12⁢[erf⁢(x+y)+erf⁢(x-y)]. (5.59)
The parameters cA, cA⁢B, αA⁢B, and βA⁢B are basis-set-dependent, and the overall scaling parameter σ is loosely method-dependent. All of these parameters are set internally based on the method and basis $rem specifications.
Note:  Currently, only the def2-SVPD basis set is supported for use with DFT-C.
The DFT-C correction is governed by the following $rem variable:
DFT_C
DFT_C
       Controls whether the DFT-C empirical BSSE correction should be added.
       FALSE (or 0) Do not apply the DFT-C correction TRUE (or 1) Apply the DFT-C correction
The DFT-C method can be applied to any local, GGA, or meta-GGA density functional, as in the following example.
Example 5.15  Geometry optimization of the methane dimer using B97M-V-C/def2-SVPD, i.e., the B97M-V functional with the DFT-C BSSE correction in the def2-SVPD basis set.
   C   0.000000  -0.000140   1.859161
   H  -0.888551   0.513060   1.494685
   H   0.888551   0.513060   1.494685
   H   0.000000  -1.026339   1.494868
   H   0.000000   0.000089   2.948284
   C   0.000000   0.000140  -1.859161
   H   0.000000  -0.000089  -2.948284
   H  -0.888551  -0.513060  -1.494685
   H   0.888551  -0.513060  -1.494685
   H   0.000000   1.026339  -1.494868
   JOBTYPE            opt
   BASIS              def2-SVPD
   METHOD             b97m-v
   DFT_C              true
