4.3 Basic SCF Job Control
4.3.2 Job Control
The following two $rem variables must be specified in order to run HF calculations:
METHOD
METHOD
       No default
       NAME Use METHOD = NAME, where NAME is one of the following: HF for Hartree-Fock theory; one of the DFT methods listed in Section 5.3.5.; one of the correlated methods listed in Sections 7.10,  7.11, and  7.9;
BASIS
BASIS
       Specifies the basis sets to be used.
       No default basis set
       General, Gen User defined ($basis keyword required). Symbol Use standard basis sets as per Chapter 8. Mixed Use a mixture of basis sets (see Chapter 8).
In addition, the following $rem variables can be used to customize the SCF calculation:
GEN_SCFMAN
GEN_SCFMAN
       Use GEN_SCFMAN for the present SCF calculation.
       FALSE Use the previous SCF code. TRUE Use GEN_SCFMAN.
       Set to FALSE in cases where features not yet supported by GEN_SCFMAN are needed.
PRINT_ORBITALS
PRINT_ORBITALS
       Prints orbital coefficients with atom labels in analysis part of output.
       INTEGER/LOGICAL
       FALSE Do not print any orbitals. TRUE Prints occupied orbitals plus 5 virtual orbitals. NVIRT Number of virtual orbitals to print.
       Use true unless more virtual orbitals are desired.
SCF_CONVERGENCE
SCF_CONVERGENCE
       SCF is considered converged when the wave function error is less that 10-SCF⁢_⁢CONVERGENCE. Adjust the value of THRESH at the same time. (Starting with Q-Chem 3.0, the DIIS error is measured by the maximum error rather than the RMS error as in earlier versions.)
       5 For single point energy calculations (including BSSE and XSAPT jobs) 7 For job types NMR, STATPOLAR, DYNPOLAR, HYPERPOLAR, and ISSC 8 For most other job types, including geometry optimization, transition-state search, vibrational analysis, CIS/TDDFT calculations, correlated wavefunction methods, energy decomposition analysis (EDA2), etc.
       User-defined
UNRESTRICTED
UNRESTRICTED
       FALSE Closed-shell systems. TRUE Open-shell systems.
       FALSE Constrain the spatial part of the alpha and beta orbitals to be the same. TRUE Do not Constrain the spatial part of the alpha and beta orbitals.
       Use the default unless ROHF is desired. Note that for unrestricted calculations on systems with an even number of electrons it is usually necessary to break α/β symmetry in the initial guess, by using SCF_GUESS_MIX or providing $occupied information (see Section 4.4 on initial guesses).
The calculations using other more special orbital types are controlled by the following $rem variables (they are not effective if GEN_SCFMAN = FALSE):
OS_ROSCF
OS_ROSCF
       Run an open-shell singlet ROSCF calculation with GEN_SCFMAN.
       TRUE OS_ROSCF calculation is performed. FALSE Do not run OS_ROSCF (it will run a close-shell RSCF calculation instead).
       Set to TRUE if desired.
GHF
GHF
       Run a generalized Hartree-Fock calculation with GEN_SCFMAN.
       TRUE Run a GHF calculation. FALSE Do not use GHF.
COMPLEX
COMPLEX
       Run an SCF calculation with complex MOs using GEN_SCFMAN.
       TRUE Use complex orbitals. FALSE Use real orbitals.
COMPLEX_MIX
COMPLEX_MIX
       Mix a certain percentage of the real part of the HOMO to the imaginary part of the LUMO.
       0–100 The mix angle = π⋅COMPLEX_MIX/100.
       It may help find the stable complex solution (similar idea as SCF_GUESS_MIX).
Example 4.1  Restricted open-shell singlet ROSCF calculation for the first excited state of formaldehyde using GEN_SCFMAN. The first job provides the guess orbitals through a restricted SCF calculation.
   H -0.940372  0.000000  1.268098
   H  0.940372  0.000000  1.268098
   C  0.000000  0.000000  0.682557
   O  0.000000  0.000000 -0.518752
   GEN_SCFMAN        true
   METHOD            wb97x-d
   BASIS             def2-svpd
   THRESH            14
   SCF_CONVERGENCE   9
   SYM_IGNORE        true
   JOBTYPE           sp
   METHOD            wb97x-d
   BASIS             def2-svpd
   GEN_SCFMAN        true
   OS_ROSCF          true
   THRESH            14
   SCF_CONVERGENCE   9
   SCF_ALGORITHM     diis
   SYM_IGNORE        true
   SCF_GUESS         read
