12.6 Job Control for Locally-Projected SCF Methods
12.6.1 Overview
FRGM_METHOD
FRGM_METHOD
       Specifies a locally-projected method.
       STOLL Locally-projected SCF equations of Stoll are solved. GIA Locally-projected SCF equations of Gianinetti are solved. NOSCF_RS Single Roothaan-step correction to the FRAGMO initial guess. NOSCF_ARS Approximate single Roothaan-step correction to the FRAGMO initial guess. NOSCF_DRS Double Roothaan-step correction to the FRAGMO initial guess. NOSCF_RS_FOCK Non-converged SCF energy of the single Roothaan-step MOs.
       STOLL and GIA are for variational optimization of the ALMOs. NOSCF options are for computationally fast corrections of the FRAGMO initial guess.
FRGM_LPCORR
FRGM_LPCORR
       Specifies a correction method performed after the locally-projected equations are converged.
       ARS Approximate Roothaan-step perturbative correction. RS Single Roothaan-step perturbative correction. EXACT_SCF Full SCF variational correction. ARS_EXACT_SCF Both ARS and EXACT_SCF in a single job. RS_EXACT_SCF Both RS and EXACT_SCF in a single job.
       For large basis sets use ARS, use RS if ARS fails.
SCF_PRINT_FRGM
SCF_PRINT_FRGM
       Controls the output of Q-Chem jobs on isolated fragments.
       TRUE The output is printed to the parent job output file. FALSE The output is not printed.
       Use TRUE if details about isolated fragments are important.
EDA_BSSE
EDA_BSSE
       Calculates the BSSE correction when performing the energy decomposition analysis.
       TRUE/FALSE
       Set to TRUE unless a very large basis set is used.
EDA_COVP
EDA_COVP
       Perform COVP analysis when evaluating the RS or ARS charge-transfer correction. COVP analysis is currently implemented only for systems of two fragments.
       TRUE/FALSE
       Set to TRUE to perform COVP analysis in an EDA or SCF MI(RS) job.
EDA_PRINT_COVP
EDA_PRINT_COVP
       Replace the final MOs with the CVOP orbitals in the end of the run.
       TRUE/FALSE
       Set to TRUE to print COVP orbitals instead of conventional MOs.
NVO_LIN_MAX_ITE
NVO_LIN_MAX_ITE
       Maximum number of iterations in the preconditioned conjugate gradient solver of the single-excitation amplitude equations.
       30
       n User–defined number of iterations.
NVO_LIN_CONVERGENCE
NVO_LIN_CONVERGENCE
       Target error factor in the preconditioned conjugate gradient solver of the single-excitation amplitude equations.
       3
       n User–defined number.
       Solution of the single-excitation amplitude equations is considered converged if the maximum residual is less than 10-n multiplied by the current DIIS error. For the ARS correction, n is automatically set to 1 since the locally-projected DIIS error is normally several orders of magnitude smaller than the full DIIS error.
NVO_METHOD
NVO_METHOD
       Sets method to be used to converge solution of the single-excitation amplitude equations.
       9
       This is an experimental option. Use the default.
NVO_UVV_PRECISION
NVO_UVV_PRECISION
       Controls convergence of the Taylor series when calculating the Uv⁢v block from the single-excitation amplitudes. Series is considered converged when the maximum element of the term is less than 10-n.
       11
       NVO_UVV_PRECISION must be the same as or larger than THRESH.
NVO_UVV_MAXPWR
NVO_UVV_MAXPWR
       Controls convergence of the Taylor series when calculating the Uv⁢v block from the single-excitation amplitudes. If the series is not converged at the nth term, more expensive direct inversion is used to calculate the Uv⁢v block.
       10
NVO_TRUNCATE_DIST
NVO_TRUNCATE_DIST
       Specifies which atomic blocks of the Fock matrix are used to construct the preconditioner.
       -1
       n>0 If distance between a pair of atoms is more than n Ångstroms do not include the atomic block. -2 Do not use distance threshold, use NVO_TRUNCATE_PRECOND instead. -1 Include all blocks. 0 Include diagonal blocks only.
       This option does not affect the final result. However, it affects the rate of the PCG algorithm convergence. For small systems, use the default.
       Specifies which atomic blocks of the Fock matrix are used to construct the preconditioner. This variable is used only if NVO_TRUNCATE_DIST is set to -2.
       n If the maximum element in an atomic block is less than 10-n do not include the block.
       Use the default. Increasing n improves convergence of the PCG algorithm but overall may slow down calculations.
