7.7 Non-Orthogonal Configuration Interaction with Single Substitutions (NOCIS) and Static Exchange (STEX)
7.7.1 NOCIS
The motivation for NOCIS843, 844, 842 is the desire to improve on CIS while still maintaining a reasonably low computational scaling. It does so by including orbital relaxation, which CIS neglects altogether, and the non-orthogonal interaction between multiple core-hole references, such as the O 1⁢s orbitals in O2.
A brief overview of the NOCIS algorithm is as follows: after a ground-state orbital optimization, a Maximum Overlap Method (MOM)361 is done for an ionization from each localized core orbital of interest. This introduces orbital relaxation, and also renders the excited states non-orthogonal to the ground state. The Hamiltonian, overlap, and total spin squared matrices are constructed using the Slater-Condon rules for matrix elements between determinants which share a common set of orbitals and NOCI for the remaining matrix elements1120. Finally, the generalized eigenvalue problem is solved.
