9.1.1 Introduction
Molecular potential energy surfaces rely on the Born-Oppenheimer separation of nuclear and electronic motion. Of particular interest are the critical points on these surfaces, i.e. where the gradient of the energy vanishes. Characterization of a critical point requires consideration of the eigenvalues of the Hessian (second derivative matrix) calculated at that point. An equilibrium geometry corresponds to a critical point where the eigenvalues of the Hessian are all positive, whereas a transition-state structure is defined as a first-order saddle point, and therefore has a Hessian with precisely one negative eigenvalue. The latter is a local maximum along the reaction path between the minima corresponding to the reactants and products, and a minimum in all directions perpendicular to this reaction path.
The quality of a geometry optimization algorithm is of major importance; even the fastest integral code in the world will be useless if combined with an inefficient optimization algorithm that requires excessive numbers of steps to converge. Q-Chem is currently transitioning to a new geometry optimization driver, Libopt3, which improves on the older Optimize driver. Details on the difference in capabilities between the two drivers are provided in Table 9.1.
Feature LIBOPT3 OPTIMIZE
Optimization Type:
  Unconstrained ✓ ✓
  Constrained ✗ ✓
Structure Search:
  Equilibrium ✓ ✓
  Transition ✓ ✓
Coordinates:
  Cartesian ✓ ✓
  Z-matrix ✓ ✓
  Redundant Internal ✓ –
  Delocalized Internal ✓ ✓
Optimization Algorithms:
  Gradient Based ✓ –
  Quasi-Newton ✓ ✓
  Newton ✓ –
Step Generation Algorithms:
  Line Search (LS) ✓ –
  Eigenvector Following (EF) ✓ ✓
QM/MM ✗ ✓
GDIIS algorithms ✗ ✓
Hessian-Free Characterization ✗ ✓
Intrinsic Reaction Coordinates (IRC) ✗ ✓
Minimum-Energy Crossing Points (MECPs) ✓ ✓
Harmonic Confiner ✓ ✓
Table 9.1: Differences of available features within the two optimization drivers, as controlled by GEOM_OPT_DRIVER in the $rem section. For unconstrained optimization, the default is GEOM_OPT_DRIVER = LIBOPT3, whereas Q-Chem’s original driver is selected using GEOM_OPT_DRIVER = OPTIMIZE.
The key to optimizing a molecular geometry successfully is to proceed from the starting geometry to the final geometry in as few steps as possible. Four factors influence the path and number of steps:
    starting geometry
    coordinate system
    quality of the Hessian (and gradient)
Q-Chem controls the last three of these, but the starting geometry is solely determined by the user, and the closer it is to the converged geometry, the fewer optimization steps will be required. Decisions regarding the optimization algorithm and the coordinate system are generally made by the Libopt3 and Optimize drivers (i.e., internally, within Q-Chem) to maximize the rate of convergence. Although users may override these choices, caution should be exercised when doing so as changes may significantly impact the computational cost.
Q-Chem provides the capability to optimize a molecule using Cartesian, Z-matrix, redundant internal, or delocalized internal coordinates. The last two of these are generated automatically from the Cartesian coordinates, and delocalized internal coordinates are usually the best choice. These coordinates were developed by Baker et al., 58 Baker J., Kessi A., Delley B.
(1996), 105, pp. 192.
and can be considered as an extension of the natural internal coordinates developed by Pulay et al. 1058 Pulay P. et al.
J. Am. Chem. Soc.
(1979), 101, pp. 2550.
, 368 Fogarasi G. et al.
J. Am. Chem. Soc.
(1992), 114, pp. 8191.
and the redundant optimization method of Pulay and Fogarasi. 1059 Pulay P., Fogarasi G.
(1992), 96, pp. 2856.
The heart of the geometry optimization in Q-Chem (for both minima and transition states) is Baker’s eigenvector-following (EF) algorithm. 59 Baker J.
(1986), 7, pp. 385.
This was developed following the work of Cerjan and Miller, 204 Cerjan C. J., Miller W. H.
(1981), 75, pp. 2800.
and of Simons and co-workers. 1170 Simons J. et al.
J. Phys. Chem.
(1983), 87, pp. 2745.
, 66 Banerjee A. et al.
J. Phys. Chem.
(1985), 89, pp. 52.
The Hessian mode-following option incorporated into this algorithm is capable of locating a transition state by walking uphill from the associated minimum. By following the lowest Hessian mode, the EF algorithm can locate a transition state starting from any reasonable input geometry and Hessian.
An additional option available for minimization is Pulay’s GDIIS algorithm, 268 Csaszar P., Pulay P.
J. Mol. Struct. (Theochem)
(1984), 114, pp. 31.
which is based on the well known DIIS technique for accelerating SCF convergence. 1062 Pulay P.
(1982), 3, pp. 556.
GDIIS must be specifically requested, as the EF algorithm is the default.
Q-Chem incorporates a very accurate and efficient Lagrange multiplier algorithm for constrained optimization. This was originally developed for use with Cartesian coordinates 60 Baker J.
(1992), 13, pp. 240.
, 56 Baker J., Bergeron D.
(1993), 14, pp. 1339.
and can handle constraints that are not necessarily satisfied by the starting geometry. The Lagrange multiplier approach has been modified for use with delocalized internal coordinates 61 Baker J.
(1997), 18, pp. 1079.
which is much more efficient and is now the default within Q-Chem. The Lagrange multiplier code can locate constrained transition states as well as minima.
Another consideration when trying to minimize the total optimization time concerns the quality of the gradient and Hessian. A higher-quality Hessian (i.e., analytical versus approximate) will in many cases lead to faster convergence, in the sense of requiring fewer optimization steps. This is why by default for transition-state optimization with Libopt3 the exact Hessian will be calculated. However, the construction of an analytical Hessian requires significant computational effort and may outweigh the advantage of fewer optimization cycles. Currently available analytical gradients and Hessians are summarized in Table 9.2.
Level of Theory Analytical Maximum Angular Analytical Maximum Angular
(Algorithm) Gradients Momentum Type Hessian Momentum Type
HF/DFT ✓ k ✓ k
ROHF ✓ h ✗
RI-MP2 ✓ h ✗
CCSD ✓ h ✗
CIS/TDDFT (except RO) ✓ h ✓ g
EOM-CCSD ✓ h ✗
ADC(n) ✗ ✗
Table 9.2: Gradients and Hessians currently available for geometry optimizations with maximum angular momentum types for analytical derivative calculations (higher angular momentum are supported when GEN_SCFMAN = TRUE).
Features of Q-Chem’s geometry and transition-state optimization capabilities include:
    Cartesian, Z-matrix or internal coordinate systems
    Eigenvector Following (EF) or GDIIS algorithms
    Constrained optimizations
    Equilibrium structure searches
    Transition structure searches
    Hessian-free characterization of stationary points
    Initial Hessian and Hessian update options
    Reaction pathways using intrinsic reaction coordinates (IRC)
    Optimization of minimum-energy crossing points (MECPs) along conical seams
