9.8 Nonadiabatic Couplings and Optimization of Minimum-Energy Crossing Points
9.8.5 State-Tracking Algorithm
For optimizing excited-state geometries and other applications, it can be important to find and follow electronically excited states of a particular character as the geometry changes. Various state-tracking procedures have been proposed for such cases. 488 Harabuchi Y. et al.
(2014), 118, pp. 11987.
, 239 Closser K. D., Gessner O., Head-Gordon M.
(2014), 140, pp. 134306.
, 1435 Zhang X., Herbert J. M.
(2015), 143, pp. 234107.
One such algorithm, based on the overlap of the attachment/detachment densities at successive steps, in available in Q-Chem (see Section 7.14.2). 239 Closser K. D., Gessner O., Head-Gordon M.
Using the densities avoids any issues that may be introduced by sign changes in the orbitals or configuration-interaction coefficients.
Two parameters are used to influence the choice of the electronic surface. One (γE) controls the energy window for states included in the search, and the other (γS) controls how well the states must overlap in order to be considered of the same character. These can be set by the user or generated automatically based on the magnitude of the nuclear displacement. The energy window is defined relative to the estimated energy for the current step (i.e., Eest±γE), which in turn is based on the energy, gradient and nuclear displacement of previous steps. This estimated energy is specific to the type of calculation (e.g., geometry optimization).
The similarity metric for the overlap is defined as
𝒮=1-12⁢(||Δ⁢𝐀||+||Δ⁢𝐃||) (9.57)
where Δ⁢𝐀=𝐀t+1-𝐀t is the difference in attachment density matrices (Eq. (7.159)) and Δ⁢𝐃=𝐃t+1-𝐃t is the difference in detachment density matrices (Eq. (7.157)), at successive steps. Equation (9.57) uses the matrix spectral norm,
||𝐌||=(λmax⁢𝐌†⁢𝐌)1/2 (9.58)
where λmax is the largest eigenvalue of 𝐌.
The selected state always satisfies one of the following
  1. 1.
    It is the only state in the window defined by γE.
  2. 2.
    It is the state with the largest overlap, provided at least one state has 𝒮≥γS.
  3. 3.
    It is the nearest state energetically if all states in the window have 𝒮<γS, or if there are no states in the energy window.
State-following can currently be used with CIS or TDDFT excited states and is initiated with the $rem variable STATE_FOLLOW. It can be used with geometry optimization, ab initio molecular dynamics, 239 Closser K. D., Gessner O., Head-Gordon M.
or with the freezing/growing-string method. The desired state is specified using CIS_STATE_DERIV for optimization or dynamics, or using SET_STATE_REACTANT and SET_STATE_PRODUCT for the freezing- or growing-string methods. The results for geometry optimizations can be affected by the step size (GEOM_OPT_DMAX), and using a step size smaller than the default value can provide better results. Also, it is often challenging to converge the strings in freezing/growing-string calculations.
STATE_FOLLOW
STATE_FOLLOW
       Turns on state following.
       FALSE Do not use state-following. TRUE Use state-following.
FOLLOW_ENERGY
FOLLOW_ENERGY
       Adjusts the energy window for near states
       0 Use dynamic thresholds, based on energy difference between steps. n Search over selected state Eest±n×10-6⁢Eh.
       Use a wider energy window to follow a state diabatically, smaller window to remain on the adiabatic state most of the time.
FOLLOW_OVERLAP
FOLLOW_OVERLAP
       Adjusts the threshold for states of similar character.
       0 Use dynamic thresholds, based on energy difference between steps. n Percentage overlap for previous step and current step.
       Use a higher value to require states have higher degree of similarity to be considered the same (more often selected based on energy).
