7.2.3 CIS Methods with Extended Excitation Manifolds
A variety of CIS-like methods have been proposed that add a limited number of double excitations to the CIS excitation space, in order to overcome certain deficiencies of CIS without incurring the prohibitive 𝒪⁢(N6) cost of a method such as CISD or CCSD that includes the full complement of double excitations. These “extended” CIS methods are discussed in this section, starting with the original excited CIS (XCIS) procedure of Maurice and Head-Gordon. 862 Maurice D., Head-Gordon M.
J. Phys. Chem.
(1996), 100, pp. 6131.
7.2.3.1 Extended CIS (XCIS)
The motivation for XCIS stems from the fact that ROCIS and UCIS are less effective for radicals than CIS is for closed shell molecules. Using the attachment/detachment density analysis procedure, 499 Head-Gordon M. et al.
J. Phys. Chem.
(1995), 99, pp. 14261.
, 532 Herbert J. M.
(2024), 26, pp. 3755.
the failing of ROCIS and UCIS methodologies for the nitromethyl radical was traced to the neglect of a particular class of double substitution which involves the simultaneous promotion of an α spin electron from the singly occupied orbital and the promotion of a β spin electron into the singly occupied orbital. The spin-adapted configurations
|Ψ~ia⁢(1)⟩=16⁢(|Ψi¯a¯⟩-|Ψia⟩)+26⁢|Ψp⁢i¯a⁢p¯⟩ (7.12)
are of crucial importance. (Here, a,b,c,… are virtual orbitals; i,j,k,… are occupied orbitals; and p,q,r,… are singly-occupied orbitals.) It is quite likely that similar excitations are also very significant in other radicals of interest.
The XCIS proposal, a more satisfactory generalization of CIS to open shell molecules, is to simultaneously include a restricted class of double substitutions similar to those in Eq. (7.12). To illustrate this, consider the resulting orbital spaces of an ROHF calculation: doubly occupied (d), singly occupied (s) and virtual (v). From this starting point we can distinguish three types of single excitations of the same multiplicity as the ground state: d→s, s→v and d→v. Thus, the spin-adapted ROCIS wave function is
|ΨROCIS⟩=12⁢∑i⁢ad⁢vaia⁢(|Ψia⟩+|Ψi¯a¯⟩)+∑p⁢as⁢vapa⁢|Ψpa⟩+∑i⁢pd⁢sai¯p¯⁢|Ψi¯p¯⟩ (7.13)
The extension of CIS theory to incorporate higher excitations maintains the ROHF as the ground state reference and adds terms to the ROCIS wave function similar to that of Eq. (7.13), as well as those where the double excitation occurs through different orbitals in the α and β space:
|ΨXCIS⟩=12⁢∑i⁢ad⁢vaia⁢(|Ψia⟩+|Ψi¯a¯⟩)+∑p⁢as⁢vapa⁢|Ψpa⟩+∑i⁢pd⁢sai¯p¯⁢|Ψi¯p¯⟩+∑i⁢a⁢pd⁢v⁢sa~ia⁢(p)⁢|Ψ~ia⁢(p)⟩+∑i⁢a,p≠qd⁢v,s⁢sap⁢i¯a⁢q¯⁢|Ψp⁢i¯a⁢q¯⟩ (7.14)
XCIS is defined only from a restricted open shell Hartree-Fock ground state reference, as it would be difficult to uniquely define singly occupied orbitals in a UHF wave function. In addition, β unoccupied orbitals, through which the spin-flip double excitation proceeds, may not match the half-occupied α orbitals in either character or even symmetry.
For molecules with closed shell ground states, both the HF ground and CIS excited states emerge from diagonalization of the Hamiltonian in the space of the HF reference and singly excited substituted configuration state functions. The XCIS case is different because the restricted class of double excitations included could mix with the ground state and lower its energy. This mixing is avoided to maintain the size consistency of the ground state energy.
With the inclusion of the restricted set of doubles excitations in the excited states, but not in the ground state, it could be expected that some fraction of the correlation energy be recovered, resulting in anomalously low excited state energies. However, the fraction of the total number of doubles excitations included in the XCIS wave function is very small and those introduced cannot account for the pair correlation of any pair of electrons. Thus, the XCIS procedure can be considered one that neglects electron correlation.
The computational cost of XCIS is approximately four times greater than CIS and ROCIS, and its accuracy for open shell molecules is generally comparable to that of the CIS method for closed shell molecules. In general, it achieves qualitative agreement with experiment. XCIS is available for doublet and quartet excited states beginning from a doublet ROHF treatment of the ground state, for excitation energies only.
Example 7.4  An XCIS calculation of excited states of an unsaturated radical, the phenyl radical, for which double substitutions make considerable contributions to low-lying excited states.
   C6H5 phenyl radical C2v symmetry MP2(full)/6-31G* = -230.7777459
   c1
   x1  c1  1.0
   c2  c1  rc2  x1  90.0
   x2  c2  1.0  c1  90.0  x1    0.0
   c3  c1  rc3  x1  90.0  c2    tc3
   c4  c1  rc3  x1  90.0  c2   -tc3
   c5  c3  rc5  c1   ac5  x1  -90.0
   c6  c4  rc5  c1   ac5  x1   90.0
   h1  c2  rh1  x2  90.0  c1  180.0
   h2  c3  rh2  c1   ah2  x1   90.0
   h3  c4  rh2  c1   ah2  x1  -90.0
   h4  c5  rh4  c3   ah4  c1  180.0
   h5  c6  rh4  c4   ah4  c1  180.0
   rh1  =    1.08574
   rh2  =    1.08534
   rc2  =    2.67299
   rc3  =    1.35450
   rh4  =    1.08722
   rc5  =    1.37290
   tc3  =   62.85
   ah2  =  122.16
   ah4  =  119.52
   ac5  =  116.45
   BASIS            =  6-31+G*
   EXCHANGE         =  hf
   MEM_STATIC       =  80
   INTSBUFFERSIZE   =  15000000
   SCF_CONVERGENCE  =  8
   CIS_N_ROOTS      =  5
   XCIS             =  true
7.2.3.2 Spin-Flip Extended CIS (SF-XCIS)
Spin-flip extended CIS (SF-XCIS) 185 Casanova D., Head-Gordon M.
(2008), 129, pp. 064104.
is a spin-complete extension of the spin-flip single excitation configuration interaction (SF-CIS) method. 689 Krylov A. I.
(2002), 350, pp. 522.
The method includes all configurations in which no more than one virtual level of the high spin triplet reference becomes occupied and no more than one doubly occupied level becomes vacant.
SF-XCIS is defined only from a restricted open shell Hartree-Fock triplet ground state reference. The final SF-XCIS wave functions correspond to spin-pure MS=0 (singlet or triplet) states. The fully balanced treatment of the half-occupied reference orbitals makes it very suitable for applications with two strongly correlated electrons, such as single bond dissociation, systems with important diradical character or the study of excited states with significant double excitation character.
The computational cost of SF-XCIS scales in the same way with molecule size as CIS itself, with a pre-factor 13 times larger.
Example 7.5  A SF-XCIS calculation of ground and excited states of trimethylenemethane (TMM) diradical, for which double substitutions make considerable contributions to low-lying excited states.
   C
   C 1 CC1
   C 1 CC2   2 A2
   C 1 CC2   2 A2    3 180.0
   H 2 C2H   1 C2CH  3 0.0
   H 2 C2H   1 C2CH  4 0.0
   H 3 C3Hu  1 C3CHu 2 0.0
   H 3 C3Hd  1 C3CHd 4 0.0
   H 4 C3Hu  1 C3CHu 2 0.0
   H 4 C3Hd  1 C3CHd 3 0.0
   CC1    = 1.35
   CC2    = 1.47
   C2H    = 1.083
   C3Hu   = 1.08
   C3Hd   = 1.08
   C2CH   = 121.2
   C3CHu  = 120.3
   C3CHd  = 121.3
   A2     = 121.0
  UNRESTRICTED    = false   SF-XCIS runs from ROHF triplet reference
  EXCHANGE        = HF
  BASIS           = 6-31G*
  SCF_CONVERGENCE = 10
  SCF_ALGORITHM   = DM
  MAX_SCF_CYCLES  = 100
  SPIN_FLIP_XCIS  = true    Do SF-XCIS
  CIS_N_ROOTS     = 3
  CIS_SINGLETS    = true    Do singlets
  CIS_TRIPLETS    = true    Do triplets
7.2.3.3 Spin-Adapted Spin-Flip CIS
Spin-Adapted Spin-Flip CIS (SA-SF-CIS) 1435 Zhang X., Herbert J. M.
(2015), 143, pp. 234107.
Unlike SF-XCIS, SA-SF-CIS only includes the minimal set of electronic configurations needed to remove the spin contamination in the conventional SF-CIS method. The target SA-SF-CIS states have spin eigenvalues one less than the reference ROHF state, i.e., if singlet states (S=0) are targeted then the reference state should be a triplet (S=1), or if doublet states (S=1/2) are targeted then the reference state should be a quartet (S=3/2). The SA-SF-CIS approach uses a tensor equation-of-motion formalism, 1435 Zhang X., Herbert J. M.
such that the dimension of the CI vectors in SA-SF-CIS remains exactly the same as that in conventional SF-CIS. A DFT correction to SA-SF-CIS (i.e., SA-SF-TDDFT) can be added. 1435 Zhang X., Herbert J. M.
As with other SF-TDDFT methods, 1436 Zhang X., Herbert J. M.
(2021), 155, pp. 124111.
the BH&HLYP functional has become something of a de facto standard choice. 525 Herbert J. M. et al.
Acc. Chem. Res.
(2016), 49, pp. 931.
Example 7.6  An SA-SF-DFT calculation of singlet ground and excited states of ethylene.
 C
 C    1    B1
 H    1    B2    2    A1
 H    1    B3    2    A2    3    D1
 H    2    B4    1    A3    3    D2
 H    2    B5    1    A4    3    D3
   B1       1.32808942
   B2       1.08687297
   B3       1.08687297
   B4       1.08687297
   B5       1.08687297
   A1     121.62604150
   A2     121.62604150
   A3     121.62604150
   A4     121.62604150
   D1     180.00000000
   D2       0.00000000
   D3     180.00000000
   EXCHANGE       bhhlyp
   BASIS          cc-pvtz
   BASIS2         sto-3g
   UNRESTRICTED   false
   CIS_N_ROOTS    5
   SASF_CIS       1
   CIS_TRIPLETS   false
