1.3 Q-Chem Features
1.3.2 New Features in Q-Chem 6.2
1.3.2.1 Features in 6.2.2
    Changes to keywords and default behavior:
      Rename keyword TdNonEq to Td_CEq_NonEq to clarify that it is specifically for applying the constrained equilibrium principle in nonequilibrium solvation (Haisheng Ren)
      SYM_IGNORE keyword is now correctly set to TRUE if NO_REORIENT=TRUE was requested (John Herbert)
      Increased default printing threshold (CIS_AMPL_PRINT) to 15 for AIMD jobs with state analysis (Goran Giudetti, Anna I. Krylov)
    General features and improvements:
      Increase maximum number of atoms and basis functions for NBO to 300 atoms and 3000 basis functions (John Herbert)
      Improve documentation for NBO (John Herbert)
      Re-enabled increasing orbital printing precision via ORBITAL_ENERGY_PREC (John Herbert)
      Resolved issues with:
        Incorrect "current job invalid" failure when JOBTYPE = RAND and JOBTYPE = BH
    Density functional theory and self-consistent field:
      Print properties in TAO-reference systems (Shaozhi Li, Jeng-Da Chai)
        Fix typo in printing of wGDD tuning parameter (John Herbert)
        Incorrect result for M06-2X analytic second derivative calculation for unrestricted systems
        Incorrect result for CIS/TDDFT frequency calculation when NSEG > 1
    Correlated methods:
        Orbital decomposition in MO basis erroneously proceeds for zero Dyson orbital norm in CCMAN2
        Failure of CASSCF geometry optimization jobs with libopt3
        Failure when using a SAD guess for unpaired electron systems in RASCI1
        Incorrect results for EOM-EE-CCSD expectation-value polarizability code with right response vectors
    Fragment and energy decomposition analysis improvements:
      SCF_CONVERGENCE for fragments in EDA calculations is now set to be the same as the parent job (Yuezhi Mao)
1.3.2.2 Features in 6.2.1
    Changes to default behavior:
      Set correct default values of EDA_COVP_THRESH for COVP and NOCV thresholds, when not set by user (Yuezhi Mao)
      Corrected the list of optical dielectric constants defined for SolventName (John Herbert)
      Enable use of = signs in several input sections (John Herbert)
      Enable higher initial angle to be called first in PES scan (Andrew Gilbert)
      Enable NTO analysis for Fast XAS TDDFT calculations
        Failure of some large CPSCF and Hessian jobs due to FileMan error
        Geometry optimizer reports failure to converge on the maximum cycle permitted by GEOM_OPT_MAX_CYCLES, even if that cycle has converged
      Enable generation of CAP-HF electron density cube files (Charlotte Titeca, Thomas Jagau)
      TDDFT analytic frequency OpenMP parallel performance improvements
        Orbital parameterization bug in XES with DFT/CIS (Aniket Mandal, John Herbert)
        Real- and complex-valued molecular orbital cube files in CAP-HF calculations overwrote one another (Charlotte Titeca, Thomas Jagau)
        Bug in diabatic state energies for NEO-MSDFT for range-separated (electronic) functionals (Joseph Dickinson, Eno Paenurk, Sharon Hammes-Schiffer)
        SGM failure for quartet core ion ROHF optimization in 1C-NOCIS (Juanes Arias-Martinez, Martin Head-Gordon)
        Scaling bug in RI-JK nuclear gradient
        Integer overflow bug
        Thread-safety bug in libqints-based multipole and ECP
        Vibrational analysis in libopt3 ignores multipole field
        Vibrational analysis in libopt3 crashes for numerical gradient
        Failure of TDDFT derivative coupling jobs with external charges
        Incorrect D4 dispersion correction for charged species
    Correlated methods:
      Enable setting EOM-CCSD(fT) method
      Added error-catching to ensure user-requested states in XOPT/MECP are consistent with requested CCSD/EOM-CCSD states
        Calling CCSD(dT) (unimplemented) would erroneously perform CCSD(fT)
        Overwriting of Molden files for natural Auger orbitals in resonant Auger decay calculations (Nayanthara Karippara Jayadev, Anna Krylov)
        State following code crash in CIS calculations (Justin Talbot, Juanes Arias-Martinez)
    Molecular dynamics, non-adiabatic dynamics, embedding, and solvation improvements:
        Miscounting of frozen-core orbitals in post-SCF QM/MM calculations using default settings
        Update total energy print in gen_scfman jobs to include all solvent terms (Yuezhi Mao)
      Enable the closed-shell fragments to be frozen in the polarization calculation for fragment spin alignment in EDA2 (Yuezhi Mao)
      Add print for combined alpha and beta result for unrestricted PolA and CTA (Yuezhi Mao)
      Simplify the print-out section of ALMO-EDA with implicit solvent models (Yuezhi Mao)
      Disable orthogonal frozen decomposition when external charges are present (Yuezhi Mao)
        Incorrect print about iterative ALMO-TDA memory requirement (Yuezhi Mao)
        Energy component analysis for SRC functionals (Felix Plasser)
    Miscellaneous:
      Updated text of Q-Chem license documentation
1.3.2.3 Features in 6.2.0
      Set POINT_GROUP_SYMMETRY to FALSE for freq jobs reading guess from previous job to avoid reorientation
      Make NO_REORIENT = 1 and POINT_GROUP_SYMMETRY = 0 the defaults for harmonic confiner jobs
      Make improved initial guess Hessian the default for optimizations (INITIAL_HESSIAN = MODEL)
      Enable RI-K virtual orbital correction by default for occ-RI-K frequency jobs
      NEO Multistate DFT (NEO-MSDFT) (Joseph Dickinson, Qi Yu, Sharon Hammes-Schiffer)
      Added simulation of nuclear-electronic quantum dynamics based on real-time nuclear-electronic orbital (RT-NEO) (Tao E. Li, Mathew Chow, Sharon Hammes-Schiffer)
      Added support for D3 empirical dispersion correction (energies and gradients) and Effective Core Potential (ECP) (energies and gradients) for NEO approach and RT-NEO methods (Mathew Chow, Sharon Hammes-Schiffer)
      Constrained NEO (CNEO) for a single NEO center (Eno Paenurk, Sharon Hammes-Schiffer)
      Addition of SCS-RIMP2 and SOS-OOMP2 to NEO methods (Jonathan Fetherolf, Sharon Hammes-Schiffer)
      Faster NEO-SCF via simultaneous DIIS optimization (Mathew Chow, Sharon Hammes-Schiffer)
      Add atomic multipole moment calculation using IAOs (Alexandra McIsaac, Abdulrahman Aldossary, Martin Head-Gordon)
      Update the list of occasions not allowed for the AUTOSAD -> CORE fallback when atomic jobs fail (Yuezhi Mao)
      New syntax allowing external electric field to follow a bond (Tarek Scheele, Tim Neudecker)
      Real-time extension of TAO-DFT (RT-TAO) (Hung-Yi Tsai, Jeng-Da Chai)
      SCF energy prints now break one-electron terms into kinetic, nuclear attraction and remainder when SCF_FINAL_PRINT is set to TRUE
        Incorrect hydrogen isotope mass when using EPC functionals with NEO (Mathew Chow, Zhen (Coraline) Tao, Sharon Hammes-Schiffer)
        NEO Hessian implementation for range-separated functionals (Eno Paenurk and Sharon Hammes-Schiffer)
        Failure of the READ_REAL guess of complex RHF (Yuezhi Mao)
        Libopt3 misclassification of structure type for near-zero eigenvalues
        “SVD Failed" invalid step error in rare geometry optimization cases
      Implemented DFT/CIS, including a new parameterization for X-ray spectroscopy (Aniket Mandal, John Herbert)
      Addition of new TZVP basis set for DFT/CIS to QCAUX (Aniket Mandal, John Herbert)
      Implemented suppression of open-shell mixing for ROKS calculations (Juanes Arias-Martinez, Martin Head-Gordon)
      Enable negative s8 values for Grimme’s D4 dispersion correction
      Dipole filtering for restricted and unrestricted TDKS (Avik Kumar Ojha, John Herbert)
      Print spatial overlaps of orbitals (intermediate overlaps for occ/virt pairs) (John Herbert)
      Make virtual orbital correction after SCF convergence optional for occ-RI-K
      Enable MakeMeSAD for GEN_SCFMAN
      Add SAD guesses for cc-pV6Z and aug-cc-pV6Z
      Disable AUTOSAD guess for CDFT-CI (John Herbert)
      Disable NTOs for RPA (John Herbert)
        Job control through FDIFF_DER for anharmonic frequency calculations (Yuezhi Mao)
        Anharmonic frequency calculation failure with DFT (Yuezhi Mao)
        Restart initialization for unrestricted TDKS (Hung-Yi Tsai, Jeng-Da Chai)
        Bug in RI related to basis sets that use multishells (note that this does not affect most RI calculations, unless an auxiliary multishell basis is used)
    Correlated methods:
      Added hyperfine coupling code to calculate couplings between singlet/triplet excited CIS states (Samuel May, Joseph Subotnik)
      Generalization of 1C-NOCIS to two-electron open-shell singlets (Juanes Arias-Martinez, Hamlin Wu, Martin Head-Gordon)
      Implemented the ACP-EOMIP-CCSD method to compute partial Auger decay widths (Florian Matz, Thomas Jagau)
      Built-in implementation of calculations of x-secs and pads using Dyson orbitals (Madhubani Mukherjee, Sarai Folkestad, Anna Krylov)
      Natural Auger Orbitals for Auger decay, ICD, and related processes for CVS-EOM methods (Nayanthara K. Jayadev, Anna I. Krylov)
      Added BW-s2 method (Kevin Carter-Fenk, Martin Head-Gordon)
      Stochastic resolution of identity to CC2 (sRI-CC2) for excited state energy calculations (Chongxiao Zhao, Wenjie Dou, Joonho Lee)
      EOM-CCSDT for EE and SF states (Prashant Uday Manohar, Manisha)
        Legacy RI-MP2 code crashes when MEM_STATIC value is too large (Yuezhi Mao)
        Error in calculation of the separable part of the one-particle density matrix with CCSD (Yongbin Kim, Madhubani Mukherjee, Anna Krylov)
      External/embedded potential read (Huseyin Aksu, Barry Dunietz)
      Turn on PCM at the first SCF iteration when SCF_GUESS = READ, allowing faster convergence (Yuezhi Mao)
      Turn on PCM at the first SCF iteration in the 2nd geom opt cycle for FRAGMO and AUTOSAD (Yuezhi Mao)
      Clarified ambiguous output for COSMO (John Herbert)
      Added analytic X-HCFF Hessian (Rahel Weiss, Felix Zeller, AG Neudecker)
        Out-of-bound access error for SMX with ghost atoms
        Undesirable behavior of SOLVENT_METHOD = TRUE invoking Kirkwood model (John Herbert)
        Add missing qarchive files for QM/MM calculations (Xiaoliang Pan, Yihan Shao)
      Add additional printout for libwfa regarding ionic/covalent states (Felix Plasser)
        Occasional crash in non-perturbative CTA (Yuezhi Mao)
    Post-processing features:
      Calculations of g-tensors using ezMagnet (ref: https://doi.org/10.1021/acs.jpca.3c04134)
