1.3 Q-Chem Features
1.3.9 New Features in Q-Chem 5.0
    Enhancements to the coupled-cluster package:
      Analytic gradients for Cholesky-decomposed CCSD and EOM-CCSD; efficiency improvement for canonical CCSD and EOM-CCSD gradients (Xintian Feng, Evgeny Epifanovsky).
      CAP-EOM-CCSD analytic gradients (Zsuzsanna Koczor-Benda, Thomas Jagau) and Dyson orbitals for metastable states (Thomas Jagau, Anna Krylov), Section 7.10.9).
      CAP-EOM-MP2 method (Alexander Kunitsa, Ksenia Bravaya).
      Evaluation of polarizabilities using CCSD and EOM-CCSD (EE and SF) wave functions using full derivative formulation (Kaushik Nanda and Anna Krylov), Section 7.10.20.8).
      Evaluation of ⟨S^2⟩ for EOM-CCSD wave functions (Xintian Feng).
      Evaluation of NACs for EOM-CCSD wave functions (Shirin Faraji, Anna Krylov, Evgeny Epifanovsky, Xintian Feng), Section 7.10.20.5).
      Efficiency improvement and new multicore-parallel code for (T) correction (Ilya Kaliman).
      New coupled-cluster based methods for core states (Anna Krylov).
    New capabilities for implicit solvation modeling:
      Equilibrium PCM capabilities for computing vertical excitation, ionization, and electron attachment energies at EOM-CC and MP2 levels (Section 11.2).
      State-specific equilibrium and non-equilibrium solvation for all orders and variants of ADC (Jan Mewes, Andreas Dreuw) , Section 7.11.10.
      Poisson equation boundary conditions allowing use of an arbitrary, anisotropic dielectric function ε⁢(𝐫), with full treatment of volume polarization (Marc Coons, John Herbert), Section 11.2.11.
      Composite Model for Implicit Representation of Solvent (CMIRS), an accurate model for free energies of solvation (Zhi-Qiang You, John Herbert), Section 11.2.7.
    New density functionals (Narbe Mardirossian and Martin Head-Gordon), Section 5.3):
      GGA functionals: BEEF-vdW, HLE16, KT1, KT2, KT3, rVV10
      Meta-GGA functionals: B97M-rV, BLOC, mBEEF, oTPSS, TM
      Hybrids: CAM-QTP(00), CAM-QTP(01), HSE-HJS, LC-ωPBE08, MN15, rCAM-B3LYP, WC04, WP04
      Double hybrids: B2GP-PLYP, DSD-PBEB95-D3, DSD-PBEP86-D3, DSD-PBEPBE-D3, LS1DH-PBE, PBE-QIDH, PTPSS-D3, PWPB95-D3
      Grimme’s PBEh-3c “low-cost” composite method
      rVV10 non-local correlation functional
    Additional DFT developments:
      New forms of DFT-D3 (J. Witte; Section 5.7.2).
      New standard integration grids, SG-2 and SG-3 (Saswata Dasgupta, John Herbert), Section 5.5.3.
      More efficient propagator algorithms for time-dependent Kohn-Sham calculations, also known as “real-time” TDDFT (Ying Zhu, John Herbert), Section 7.4).
    New integral package for for computing effective core potential (ECP) integrals (Simon McKenzie, Evgeny Epifanovsky), Section 8.10.2).
      More efficient analytic algorithms for energies and first derivatives.
      Support for arbitrary projector angular momentum.
      Support up to h angular momentum in the basis set.
    Analytic derivative couplings for the ab initio Frenkel-Davydov exciton model (Adrian Morrison, John Herbert); Section 12.13).
    New ALMO-based energy decomposition analysis (EDA) methods:
      The second-generation ALMO-EDA methods for DFT (Paul Horn, Yuezhi Mao, Martin Head-Gordon); Section 12.6.
      The extension of ALMO-EDA to RIMP2 theory (Jonathan Thirman, Martin Head-Gordon); Section 12.7.1.
      The “adiabatic" EDA method for decomposing changes in molecular properties (Yuezhi Mao, Paul Horn, MartinHead-Gordon); Section 12.7.3.
    Wave function correlation capabilities:
      Coupled cluster valence bond (CCVB) method for describing open-shell molecules with strong spin correlations (David Small, Martin Head-Gordon); Section 6.18.3.
      Implementation of coupled-cluster valence bond with singles and doubles (CCVB-SD) for closed-shell species (Joonho Lee, David Small, Martin Head-Gordon); Section 6.13.4.
Note:  Several important changes in Q-Chem’s default settings have occurred since version 4.4. • Core electrons are now frozen by default in most post-Hartree-Fock calculations; see Section 6.2. • The keywords for calculation of SOCs and NACs were renamed for consistency between different methods. • Some newer density functionals now use either the SG-2 or SG-3 quadrature grid by default, whereas all functionals used SG-1 by default in v. 4.4. Table 5.3 lists the default grid for various classes of functionals.
