1.3 Q-Chem Features
1.3.3 New Features in Q-Chem 6.1
1.3.3.1 Features in 6.1.1
    Changes to default behavior:
      Set TDKS = FALSE in fragment REM variable ($rem_frgm) section (John Herbert)
      Remove redundant CIS_ and SET_ variables (John Herbert)
      Update the XDM damping parameters and added variables for user control (John Herbert)
      Formatted printing of SCF energy (John Herbert)
    General features and improvements:
      Add ability to print CHELPG grid points and weights (John Herbert)
      Add Fock matrix correction for RI-JK kernels (Xintian Feng)
      Increase precision for orbital energies printout, allowing 1s energies to be obtained for heavy elements (John Herbert)
    Density functional theory and self-consistent field:
      Add XYG3, XYGJ-OS to the list of available methods (Yuezhi Mao)
      Disable double-hybrids and post-HF methods with CDFT (Yuezhi Mao)
      Improved error catching in TRNSS LR-TDDFT code for core-level excitations (John Herbert)
      Maximum Overlap Method for ROKS Calculations (Kevin Carter-Fenk, Martin Head-Gordon)
      Fixed issues with:
        unclear value of natoms_mol1 in XDM user interface (John Herbert)
        kappa value printing in XDM10 (John Herbert)
    Correlated methods:
      Added hyperfine coupling code to calculate couplings between singlet/triplet excited CIS states (Samuel May, Joseph Subotnik)
      Improved MOM functionality in the ccman2 Davidson solver (Florian Matz, Quyen Nguyen, Thomas-C. Jagau)
      Support for TDDFT/TDA-SOC overlaps and external magnetic fields (Yanze Wu, Joseph Subotnik)
      Acceleration for TDDFT/TDA-SOC derivative coupling calculations, especially for time-reversal cases (Yanze Wu, Joseph Subotnik)
      Added triplet support for CIS/TDDFT overlaps (Yanze Wu, Joseph Subotnik)
      Added correct header label for NOONs in CAS-SCF calculation output (John Herbert)
      Implemented stochastic resolution of indentity approximation to CC2 model (sRI-CC2) for ground-state and excited state energy calculations (Chongxiao Zhao, Wenjie Dou, and Joonho Lee)
      Fixed issues with:
        typo in SOC output labels (“ms=1" changed to “ms=-1") (Yanze Wu, Joseph Subotnik)
        acceptor-donor order dependence in RAS-FCD and RAS-FED (Aaditya Manjanath, Chao-Ping Hsu)
    Molecular dynamics, non-adiabatic dynamics, embedding, and solvation:
      Enable SMx debug printing (John Herbert)
      Improve error catching for incorrect PCM inputs (John Herbert)
      Fixed issues with:
        error handling for Td_CEq_NonEq in PCM with SF-TDDFT calculations (John Herbert)
        printing bug in PCM (Kuan-Yu Liu)
    Fragment and energy decomposition analysis:
      Change the fragment index convention in non-perturbative PolA/CTA to start from 1 (Yuezhi Mao)
    Miscellaneous:
      Disable analytic nuclear Hessian for ROKS jobs (Yuezhi Mao)
      Formatted printing for TDDFT with truncated subspace (John Herbert)
      Replace term “Energy Transfer" with "Polarization Energy" in non-perturbative PolA/CTA (Yuezhi Mao)
      Replace term “Charge Transfer" with "On-Fragment Charge Shift" in non-perturbative PolA/CTA (Yuezhi Mao)
      TDDFT formatted print for core-level excitations (John Herbert)
1.3.3.2 Features in 6.1.0
      Renamed SASF_RPA to SASF_CIS
      Renamed TDDFT_PCM to TDDFT_LR_PCM (John Herbert)
      Renamed SYMMETRY to INTEGRAL_SYMMETRY and made INTEGRAL_SYMMETRY default to FALSE
      Added POINT_GROUP_SYMMETRY
      Add ENABLE_ARCHIVE keyword to control writing of archive files (Eric Berquist, Peter McLaughlin)
      Implemented gauge-independent atomic orbital (GIAO) basis for SCF calculations (Jonathan Wong, Brad Ganoe, Tim Neudecker, Adam Rettig, Xiao Liu, Joonho Lee)
      Implemented the GIAO complex calculations for DFT jobs (Jiashu Liang)
      Implemented on-the-fly SQC and Ehrenfest nonadiabatic dynamics algorithms using restricted CIS and TDDFT/TDA (Justin Talbot, Stephen J. Cotton, Martin Head-Gordon)
      Implemented slater transition method and transition potential method for calculating core-level binding energies and X-ray absorption spectra (Subrata Jana, John Herbert)
      Generated data for vibronic decomposition analysis (Kuan-Yu Liu, Peter McLaughlin, Andrew Gilbert)
      Enabled state following with libopt3
      Changed transition state geometry optimization default to new optimizer (Peter McLaughlin)
      Implemented new initial model Hessian for geometry optimization (Peter McLaughlin)
      Enabled new plots section format for ESP cube plots (Yuezhi Mao)
      Added vibrational circular dichroism (VCD) spectroscopy (Yu Zhang, Kuan-Yu Liu, Eric Berquist, Evgeny Epifanovsky)
      Added RRHO print-out (Abdul Aldossary, Alistair Sterling, Tim Schramm)
      Added computation of MO overlaps at displaced geometries (John Herbert)
      Resolved issues with:
        performance of B97M-V gradients
        NEO-epc19 deuterium mass being passed incorrectly (Zhen (Coraline) Tao, Mathew Chow, Sharon Hammes-Schiffer)
        NEO-epc19 gradients (Zhen (Coraline) Tao, Mathew Chow, Sharon Hammes-Schiffer)
        NEO-epc172 Hessian and multiple proton NEO Hessian (Zhen (Coraline) Tao, Mathew Chow, Sharon Hammes-Schiffer)
        missing STEP constraint in RHF jobs (Kevin Carter-Fenk)
        Gaussian blur failing to work with ECP (John Herbert)
        many-body expansion job failure above fourth order
      Enabled spin-orbit NTO analysis for TDDFT and SF-TDDFT (Saikiran Kotaru)
      Implemented electron-affinity time-dependent density functional theory (Kevin Carter-Fenk, Juan Arias-Martinez, Leonardo Cunha)
      Enabled projection-based embedding with ECPs (Valentina Parravicini, Thomas Jagau)
      Added a memory check before SCF for DFT jobs
      Improved EA-TDDFT/STEX job control (Kevin Carter-Fenk)
      Added SPADE localization capabilities and initial guess functionality in EA-TDDFT/STEX jobs (Kevin Carter-Fenk)
        TDA excited state frequencies crash
        double counting in VV10 calculations
        meta-GGA TDDFT analytical frequency
    Correlated methods:
      Added ability to obtain partial widths for CCSD calculations on core-vacant states (Florian Matz, Thomas Jagau)
      Implemented RI-CC2-EOM-SF, EA, and IP (Garrette Paran, Thomas Jagau, Cansu Utku)
      Implemented CCSDT (Prashant Uday Manohar, Manisha)
      Enable the use of new plots section format for the excited-state analysis of ADC jobs (Yuezhi Mao)
      Correct coefficient of EOM-CC 2PA cross section with circular polarization (Kaushik Nanda)
      Add Dalton solver for damped CC equations to speed up convergence (Kaushik Nanda)
      Allow user-defined active and inactive frozen-core orbitals for fc-CVS-EOM-CC calculations (Kaushik Nanda)
        Failure of iFCI when using GEN_SCFMAN
        Failure when calculating CC transition properties from the initial CCSD state when both CVS-EOM-EE-CCSD and CVS-EOM-IP-CCSD states are requested together (Kaushik Nanda)
      Implemented PCM contribution for nuclear-electronic orbital (NEO) method (NEO) (Mathew Chow, Sharon Hammes-Schiffer)
      Disabled N=14 PCM discretization grid (John Herbert)
      New and improved state-specific (SS)-PCM-TDDFT (Thomas Froitzheim, John Herbert, Jan-Michael Mewes, Stefan Grimme)
      Print clearer errors for incorrect PEqS input formatting (John Herbert)
        SMD gradient with IEF-PCM electrostatics (John Herbert)
        SS(V)PE and IEF-PCM gradients in NEO calculations (Mathew Chow, Sharon Hammes-Schiffer)
        AIMD crash with DACF calculations (J. A. Gyamfi, Thomas C. Jagau)
        Failure of frozen energy gradient calculations with implicit solvent when IDERIV = 0 (Yuezhi Mao)
      Implemented decomposition of molecular polarizability using the iterative Hirshfeld scheme (Yihan Shao, Yuezhi Mao)
      Implemented force decomposition analysis (Abdulrahman Aldossary, Yuezhi Mao, Marti Gimferrer)
      Added POL and NOCV analysis for EDA2 (Hengyuan Shen)
      Enabled calculation of non-perturbative PolA/CTA with ALMO-EDA2 (Hengyuan Shen, Yuezhi Mao)
      Added pre- and post-processing scripts for XSAPT (Montgomery Gray, John Herbert)
        schema-related crash for FSSH jobs (Yuezhi Mao, Justin Talbot)
        error in MO SAPT calculation of Eelst(1) and Eexch(1) (Montgomery Gary, John Herbert)
    Miscellaneous:
      Disabled SMD for MECP (John Herbert)
      Added ability to define solvent dielectric constants in PCM using solvent name (John Herbert)
      Added warning for BrianQC jobs if the feature is not supported GEN_SCFMAN = FALSE
      Remove an outdated warning about use of ECPs with Gaussian blurring (John Herbert)
      Enabled comments in all input sections (John Herbert)
      Fixed memory leak for X2C with ROHF orbitals (Kevin Carter-Fenk)
      Allow input parser to interpret 1 as TRUE (Eric Berquist)
