5.7 DFT Methods for van der Waals Interactions
5.7.3 Exchange-Dipole Model (XDM)
5.7.3.1 Theory
Becke and Johnson have proposed an exchange dipole model (XDM) of dispersion. 80 Becke A. D., Johnson E. R.
(2005), 123, pp. 154101.
, 81 Becke A. D., Johnson E. R.
(2005), 122, pp. 154104.
, 82 Becke A. D., Johnson E. R.
(2006), 124, pp. 014104.
, 83 Becke A. D., Johnson E. R.
(2007), 127, pp. 154108.
, 613 Johnson E. R., Becke A. D.
(2005), 123, pp. 024101.
, 614 Johnson E. R., Becke A. D.
(2006), 124, pp. 174104.
The attractive dispersion energy arises in this model via the interaction between the instantaneous dipole moment of the exchange hole in one molecule, and the induced dipole moment in another. This is a conceptually simple yet powerful approach that has been shown to yield very accurate dispersion coefficients without fitting parameters. This allows the calculation of both intermolecular and intramolecular dispersion interactions within a single DFT framework. The implementation and validation of this method in the Q-Chem code is described in Ref.  669 Kong J. et al.
Phys. Rev. A
(2009), 79, pp. 042510.
, with an updated set of damping parameters 958 Otero-de-la-Roza A., Johnson E. R.
(2013), 138, pp. 204109.
added in Q-Chem v. 6.1.1. 448 Gray M., Herbert J. M.
Annu. Rep. Comput. Chem.
(2024), 20, pp. 1.
The dipole moment of the exchange hole function hσ⁢(𝐫,𝐫′) is given at point 𝐫 by
dσ⁢(𝐫)=-𝐫-∫hσ⁢(𝐫,𝐫′)⁢𝐫′⁢𝑑𝐫′, (5.38)
where σ=α,β. This depends on a model of the exchange hole, and the implementation in Q-Chem uses the Becke-Roussel (BR) model. 84 Becke A. D., Roussel M. R.
Phys. Rev. A
(1989), 39, pp. 3761.
In most implementations the BR model, hσ is not available in analytic form and its value must be numerically at each grid point. Q-Chem developed for the first time an analytical expression for this function, 669 Kong J. et al.
Phys. Rev. A
based on non-linear interpolation and spline techniques, which greatly improves efficiency as well as the numerical stability.
Two different damping functions have been used with XDM. One of them relies only the intermolecular C6 coefficient, and its implementation in Q-Chem is denoted as “XDM6”. In this version, the dispersion energy is 80 Becke A. D., Johnson E. R.
EvdWXDM6=∑Aatoms∑B<AatomsEvdW,A⁢B=-∑Aatoms∑B<AatomsC6,A⁢BRA⁢B6+κ⁢C6,A⁢B/EA⁢Bcorr. (5.39)
The term κ⁢C6,A⁢B/EA⁢Bcorr in the denominator prevents short-range divergence. The quantity EA⁢Bcorr is the sum of the absolute values of the correlation energies of the free atoms A and B, whereas κ is a damping parameter that is universal in the sense that it is independent of the choice of functional. 80 Becke A. D., Johnson E. R.
The dispersion coefficients C6,A⁢B is computed according to 80 Becke A. D., Johnson E. R.
C6,i⁢j=⟨dX2⟩A⁢⟨dX2⟩B⁢αA⁢αB⟨dX2⟩A⁢αB+⟨dX2⟩B⁢αA (5.40)
where ⟨dX2⟩A is the square of the exchange-hole dipole moment of atom A, whose effective polarizability (in the molecule) is αA.
The XDM6 scheme can be further generalized to include higher-order dispersion coefficients, 82 Becke A. D., Johnson E. R.
which leads to the “XDM10” model in Q-Chem:
EvdWXDM10=-∑Aatoms∑B<Aatoms(C6,A⁢BRvdW,A⁢B6+RA⁢B6+C8,A⁢BRvdW,A⁢B8+RA⁢B8+C10,A⁢BRvdW,A⁢B10+RA⁢B10). (5.41)
The higher-order dispersion coefficients are computed using higher-order multipole moments of the exchange hole. 614 Johnson E. R., Becke A. D.
The quantity RvdW,A⁢B prevents short-range divergence and is nominally equal to the sum of effective atomic radii for atoms A and B. In practice it is determined from the formula 614 Johnson E. R., Becke A. D.
RvdW,A⁢B=a1⁢Rcrit,A⁢B+a2 (5.42)
with a critical distance
Rcrit,A⁢B=13⁢[(C8,A⁢BC6,A⁢B)1/2+(C10,A⁢BC6,A⁢B)1/4+(C10,A⁢BC8,A⁢B)1/2] (5.43)
and two parameters, a1 and a2. These were originally fitted using Hartree-Fock exchange 614 Johnson E. R., Becke A. D.
but were later optimized for several different exchange-correlation functionals: PW86PBE, PBE, BLYP, B97-1, B3LYP, B3P86, B3PW91, PBE0, BHHLYP, LRC-ωPBE, and CAM-B3LYP. 958 Otero-de-la-Roza A., Johnson E. R.
Parameters for this set of functionals are implemented in Q-Chem. 448 Gray M., Herbert J. M.
(2024), 20, pp. 1.
Note:  For functionals other than the ones specified above, Hartree-Fock values of the parameters a1 and a2 are used, although this may not be optimal.
5.7.3.2 Job Control
As in DFT-D, the van der Waals energy is added as a post-SCF correction. Analytic gradients and Hessians are available for both XDM6 and XDM10. The dispersion correction is requested by setting XDM = TRUE in the $rem section. All other job control variables belong in the $xdm input section, as described below. Of these, only NAtoms_Mol1 is required, as this determined which part of the $molecule section corresponds to monomer A, with the rest corresponding to monomer B. It is required that all atoms for A are grouped together in the $molecule section.
XDM
XDM
       Controls whether to add XDM dispersion to an SCF calculation
       0 Do not apply the XDM scheme. 1 Add XDM dispersion as a correction to the SCF energy (and gradient, if appropriate). 2 Add dispersion as a DFT functional and do full SCF.
       The second (self-consistent) option is only available for XDM6.
NAtomsMol1
       Sets the size of monomer A.
INPUT SECTION: $xdm
       N Monomer A consists of the first N atoms in the $molecule section.
       This is the only required keyword in the $xdm section. The two monomers must be grouped together in the $molecule section; note that Q-Chem’s fragment-based input format does not work with XDM.
Method
       Controls which XDM method to use.
INPUT SECTION: $xdm
       XDM10
       XDM6 Use the C6-only model of Eq. (5.39). XDM10 Use the model that includes C8 and C10, Eq. (5.41).
       The XDM10 is generally more accurate and is now the preferred approach.
Damp_C6_K
       Set the damping parameter κ in Eq. (5.39).
INPUT SECTION: $xdm
       FLOAT
       0.8
       x Set κ=x.
       The default value is taken from Ref. Becke:2005a and is intended to be universal.
Damp_A1
       Sets the parameter a1 in Eq. (5.42).
INPUT SECTION: $xdm
       FLOAT
       Various
       x Set a1=x.
       Functional-specific defaults are available for HF, PW86PBE, PBE, BLYP, B97-1, B3LYP, B3P86, B3PW91, PBE0, BHHLYP, LRC-ωPBE, and CAM-B3LYP, taken from Ref.  958 Otero-de-la-Roza A., Johnson E. R.
. For other functionals, the HF values (Ref.  614 Johnson E. R., Becke A. D.
) are used by default, although Q-Chem will print a warning that this may not be optimal.
Damp_A2
       Sets the parameter a2 in Eq. (5.42).
INPUT SECTION: $xdm
       FLOAT
       Various
       x Set a2=x.
       The same comments apply (regarding functional-specific values) as in the case of Damp_A1.
Print
       Controls the print level for the XDM procedure.
INPUT SECTION: $xdm
       0 No printing. 1 Minimal printing. 2 Debug-level printing.
Use_Elec_Drv
       Specify whether to add the gradient correction to the XDM energy.
INPUT SECTION: $xdm
       TRUE Use the gradient correction. FALSE Do not use the gradient correction.
       This is only valid with Becke’s C6 damping function using the interpolated BR89 model.
Example 5.12  Sample input illustrating a frequency calculation of a vdW complex He⋯N2 using the XDM dispersion correction.
   He 0.000000  0.00000   3.800000
   N  0.000000  0.000000  0.546986
   N  0.000000  0.000000 -0.546986
   JOBTYPE             FREQ
   IDERIV              2
   EXCHANGE            B3LYP
   INCDFT              0
   SCF_CONVERGENCE     8
   BASIS               6-31G*
   XDM                 TRUE
$xdm
  method      xdm6
  natoms_mol1 1
