12.14 TDDFT for Molecular Interactions
12.14.1 Introduction
There exist a broad class of weakly interacting molecular complexes which give rise to interesting excited-state properties that are potentially very different from those of a single chromophore. The “TDDFT for molecular interactions" or TDDFT(MI) method is designed for efficient excited-state calculations in such cases in (potentially large) systems composed of weakly-interacting but electronically-coupled monomers. 794 Liu J., Herbert J. M.
(2015), 143, pp. 034106.
, 525 Herbert J. M. et al.
Acc. Chem. Res.
(2016), 49, pp. 931.
Such systems include molecular aggregates, chromophores in explicit solvent, and even proteins, for which the traditional TDDFT method become prohibitively expensive. TDDFT(MI) starts from a ground-state SCF MI calculation, and the use of ALMOs is central to its efficiency. In addition, the excitations are confined within monomer units and the explicit charge-transfer excitations are ignored, significantly reduced the two-electron integrals cost. The method works by coupling together excitations computed individually on different molecular fragments, and the number of excited states per fragment can be increased (at very low cost) in order to increase the variational flexibility of this exciton-type basis. Thus, despite the localized nature of the basis states, TDDFT(MI) is capable of describing collective excitations that are delocalized over multiple monomer units, as for example in the case of organic semiconductors. In general, TDDFT(MI) reproduces full super-system TDDFT excitation energies to within ∼0.2 eV, but with an order or magnitude reduction in total CPU time. 794 Liu J., Herbert J. M.
Formally, the cost of the method scales as 𝒪⁢(Nfragment2⁢Nroots2⁢Nsub⁢-⁢AOx) where Nfragment is the number of monomers, Nroots is the number of excited states per monomer, and Nsub⁢-⁢AO is the number of AOs on a dimer subsystem. The exponent x (with 2≤x≤4) reflects the cost of forming the Fock-like matrices of a traditional TDDFT calculation.
An especially promising application of the TDDFT(MI) method is to study excitation energies of a single chromophore in solution using a large number of explicit, quantum-mechanical solvent molecules. In such cases, the excitations are localized on the single chromophore and we can introduce a local excitation approximation (LEA) to TDDFT(MI) in which all of the Coulomb and exchange couplings between the solvent molecules and the chromophore are neglected. 795 Liu J., Herbert J. M.
(2016), 12, pp. 157.
Following the ground-state SCF(MI) calculation, the cost of the TDDFT part of the calculation becomes essentially the same as the cost of a TDDFT calculation on the gas-phase chromophore. In addition, this approach avoids the appearance of, and mixing with, spurious charge-transfer-to-solvent states, 795 Liu J., Herbert J. M.
Acc. Chem. Res.
of the sort that are known to arise in TDDFT calculations with explicit solvent. 710 Lange A., Herbert J. M.
(2007), 3, pp. 1680.
, 577 Isborn C. M. et al.
J. Phys. Chem. B
(2013), 117, pp. 12189.
Three versions of LEA-TDDFT(MI), named LEA0, LEA-Q and LEAc, have been implemented in Q-Chem. 795 Liu J., Herbert J. M.
In the LEA0 method, ALMOs from the ground state SCF(MI) calculation are used to perform the TDDFT calculation. In LEAc, a sub-block of the TDDFT(MI) working equation localized on chromophore is extracted to calculate the excitation energies. Finally, LEA-Q is almost the same as LEAc except for some transformations to eliminate the overlap matrices. These approaches have been applied to converge solvatochromatic shifts for several aqueous chromophores. 795 Liu J., Herbert J. M.
