11.8 Polarizable Embedding Model
11.8.2 Job Control
The PE job control is accomplished in two sections, $rem and $pe. To enabling PE-ADC, specification of the ADC method and other ADC job control parameters (thresholds, max. iterations etc.) should be set in the $rem section. PE-ADC supports the excited state analysis (STATE_ANALYSIS) carried out by the libwfa module.
PE
PE
       Turns PE on.
       False
       True Perform a PE calculation. False Don’t perform a PE calculation.
       Set the $rem variable PE to TRUE to start a PE calculation.
Note:  Turning PE on disables symmetry by setting POINT_GROUP_SYMMETRY to FALSE.
Note:  Setting the REM variables USE_LIBQINTS and GEN_SCFMAN to TRUE is required to run PE.
The PE-specific options can be set in the $pe input section. The format of the $pe section requires key and value pairs separated by a space character:
$pe
   <keyword>  <parameter>
Note:  The following job control variables belong only in the $pe section. Do not place them in the $rem section.
POTFILE
       Path of the potential file.
INPUT SECTION: $pe
       potfile.pot
       Provide the path/name of the potential file.
DIIS
       Use DIIS acceleration to obtain induced moments.
INPUT SECTION: $pe
       TRUE Turns DIIS acceleration on. FALSE Turns DIIS acceleration off (normal Jacobi solver is used).
CONVERGENCE_INDUCED
       Threshold for induced moments convergence. Converge induced moments to a residual norm of 10-CONVERGENCE_INDUCED.
INPUT SECTION: $pe
       8 Corresponding to 10-8
       n≤12 Corresponding to 10-n
       Use the default unless higher accuracy is desired.
MAXITER
       Maximum number of iterations for induced moments.
INPUT SECTION: $pe
       50
       n≥1
       Use the default. If more iterations are required to converge the induced moments, there might be an error in the system setup.
BORDER
       Activate border redistribution/removal options for sites in proximity to the QM/MM border.
INPUT SECTION: $pe
       TRUE Enable border options. FALSE Disable border options.
BORDER_TYPE
       Remove or redistribute multipole moments/polarizabilities.
INPUT SECTION: $pe
       REMOVE
       REMOVE remove multipole moments/polarizabilities. REDIST redistribute multipole moments/polarizabilities.
BORDER_RMIN
       Minimum distance from QM atoms to MM sites to be taken into account for removal/redistribution
INPUT SECTION: $pe
       FLOAT
       2.2 (AU)
       r>0 (Unit depends on BORDER_RMIN_UNIT)
BORDER_RMIN_UNIT
       Unit of BORDER_RMIN, default is atomic units (AU)
INPUT SECTION: $pe
       AU
       AU Use atomic units. AA Use Angstrom.
BORDER_REDIST_ORDER
       Order from which on moments are removed. For example, if set to 1 (default), only charges are redistributed and all higher order moments are removed.
INPUT SECTION: $pe
       n=0,1,2,3,…
BORDER_N_REDIST
       Number of neighbor sites to redistribute multipole moments/polarizabilities to. The default (-1) redistributes to all sites which are not in the border region.
INPUT SECTION: $pe
       -1
       n=-1,1,2,3,…,number of MM sites
       Use the default value.
BORDER_REDIST_POL
       Redistribute polarizabilities? If set to FALSE, polarizabilities are removed.
INPUT SECTION: $pe
       TRUE Redistribute polarizabilities. FALSE Remove polarizabilities.
Example 11.44  Input for a PE-HF calculation of 4-Nitroaniline in presence of six water molecules
The potential file \texttt{gen\_scfman\_pe\_potfile.pot} can be
found in the samples folder.
   C      8.64800        1.07500       -1.71100
   C      9.48200        0.43000       -0.80800
   C      9.39600        0.75000        0.53800
   C      8.48200        1.71200        0.99500
   C      7.65300        2.34500        0.05500
   C      7.73200        2.03100       -1.29200
   H     10.18300       -0.30900       -1.16400
   H     10.04400        0.25200        1.24700
   H      6.94200        3.08900        0.38900
   H      7.09700        2.51500       -2.01800
   N      8.40100        2.02500        2.32500
   N      8.73400        0.74100       -3.12900
   O      7.98000        1.33100       -3.90100
   O      9.55600       -0.11000       -3.46600
   H      7.74900        2.71100        2.65200
   H      8.99100        1.57500        2.99500
   METHOD               HF
   BASIS                STO-3G
   PE                   TRUE
point_group_symmetry False
   USE_LIBQINTS         TRUE
$pe
   potfile  gen_scfman_pe_potfile.pot
