7.12.4 Short-Range Density Functional Correlation within RAS-CI
Alternatively, effective dynamic correlation can be introduced into the RAS-CI wave function by means of short-range density functional correlation energy. The idea relies on the different ability of wave function methods and DFT to treat non-dynamic and dynamic correlations. Concretely, the RAS-CI-s⁢rDFT (or RAS-s⁢rDFT) method 194 Casanova D.
(2018), 148, pp. 124118.
is based on the range separation of the electron-electron Coulomb operator (V^e⁢e) through the error function to describe long-range interactions,
V^e⁢el⁢r,μ=∑i<jerf⁢(μ⁢ri⁢j)ri⁢j (7.140)
V^e⁢es⁢r,μ=V^e⁢e-V^e⁢el⁢r,μ (7.141)
where ri⁢j is the inter electronic distance and the parameter μ controls the extend of short- and long-range interactions. Such splitting of V^e⁢e provides a well-defined approach to merge WFT with DFT by applying V^e⁢el⁢r,μ to RAS-CI and Ve⁢el⁢r,μ to DFT. Within the RAS-s⁢rDFT approach, the energy of an electronic state can be expressed as:
ERAS-⁢s⁢r⁢DFT=minΨμ⁡[⟨Ψμ|T^+V^n⁢e+V^e⁢el⁢r,μ|Ψμ⟩+EHs⁢r,μ⁢[ρ]+Ex⁢cs⁢r,μ⁢[ρ]] (7.142)
where ρ≡ρ⁢[Ψμ], and EHs⁢r,μ⁢[ρ] and Ex⁢cs⁢r,μ⁢[ρ] are the short-range Hartree and exchange-correlation energy functionals, respectively. The RAS-CI wave function can be combined with different short-range exchange and correlation functionals (Sections 5.3.3 and 5.3.4).
