9.9.7 Fewest-Switches Surface Hopping
As discussed in Section 9.8, optimization of minimum-energy crossing points (MECPs) along conical seams, followed by optimization of minimum-energy pathways that connect these MECPs to other points of interest on ground- and excited-state potential energy surfaces, affords an appealing one-dimensional picture of photochemical reactivity that is analogous to the “reactant → transition state → product” picture of ground-state chemistry. Just as the ground-state reaction is not obligated to proceed exactly through the transition-state geometry, however, an excited-state reaction need not proceed precisely through the MECP and the particulars of nuclear kinetic energy can lead to deviations. This is arguably more of an issue for excited-state reactions, where the existence of multiple conical intersections can easily lead to multiple potential reaction mechanisms. AIMD potentially offers a way to sample over the available mechanisms in order to deduce which ones are important in an automated way, but must be extended in the photochemical case to reactions that involve more than one Born-Oppenheimer potential energy surface.
The most widely-used trajectory-based method for nonadiabatic simulations is Tully’s “fewest-switches” surface-hopping (FSSH) algorithm. 1286 Tully J. C.
(1990), 93, pp. 1061.
In this approach, classical trajectories are propagated on a single potential energy surface, but can undergo “hops” to a different potential surface in regions of near-degeneracy between surfaces. The probability of these stochastic hops is governed by the magnitude of the nonadiabatic coupling [Eq. (9.48)]. Considering the ensemble average of a swarm of trajectories then provides information about, e.g., branching ratios for photochemical reactions.
The FSSH algorithm, based on the AIMD code, is available in Q-Chem for any electronic structure method where analytic derivative couplings are available, which at present means CIS, TDDFT, and their spin-flip analogues (see Section 9.8.1). The nuclear dynamics component of the simulation is specified just as in an AIMD calculation. Artificial decoherence can be added to the calculation at additional cost according to the augmented FSSH (AFSSH) method, 1233 Subotnik J. E., Shenvi N.
(2011), 134, pp. 024105.
, 1236 Subotnik J. E.
(2011), 114, pp. 12083.
, 709 Landry B. R., Subotnik J. E.
(2012), 137, pp. 22A513.
which enforces stochastic wave function collapse at a rate proportional to the difference in forces between the trajectory on the active surface and position moments propagated the other surfaces. At every time step, the component of the wave function on each active surface is printed to the output file. These amplitudes, as well as the position and momentum moments (if AFSSH is requested), is also printed to a text file called SurfaceHopper located in the $QC/AIMD sub-directory of the job’s scratch directory.
In order to request a FSSH calculation, only a few additional $rem variables must be added to those necessary for an excited-state AIMD simulation. At present, FSSH calculations can only be performed using Born-Oppenheimer molecular dynamics (BOMD) method. Furthermore, the optimized velocity Verlet (OVV) integration method is not supported for FSSH calculations.
FSSH_LOWESTSURFACE
FSSH_LOWESTSURFACE
       Specifies the lowest-energy state considered in a surface hopping calculation.
       n Only states n and above are considered in a FSSH calculation.
FSSH_NSURFACES
FSSH_NSURFACES
       Specifies the number of states considered in a surface hopping calculation.
       n n states are considered in the surface hopping calculation.
       Any states which may come close in energy to the active surface should be included in the surface hopping calculation.
FSSH_INITIALSURFACE
FSSH_INITIALSURFACE
       Specifies the initial state in a surface hopping calculation.
       n An integer between FSSH_LOWESTSURFACE and FSSH_LOWESTSURFACE + FSSH_NSURFACES -1.
AFSSH
AFSSH
       Adds decoherence approximation to surface hopping calculation.
       0 Traditional surface hopping, no decoherence. 1 Use augmented fewest-switches surface hopping (AFSSH).
       AFSSH will increase the cost of the calculation, but may improve accuracy for some systems. See Refs.   1233 Subotnik J. E., Shenvi N.
for more detail.
AIMD_SHORT_TIME_STEP
       Specifies a shorter electronic time step for FSSH calculations.
       TIME_STEP
       n Specify an electronic time step duration of n/AIMD_TIME_STEP_CONVERSION a.u. If n is less than the nuclear time step variable TIME_STEP, the electronic wave function will be integrated multiple times per nuclear time step, using a linear interpolation of nuclear quantities such as the energy gradient and derivative coupling. Note that n must divide TIME_STEP evenly.
       Make AIMD_SHORT_TIME_STEP as large as possible while keeping the trace of the density matrix close to unity during long simulations. Note that while specifying an appropriate duration for the electronic time step is essential for maintaining accurate wave function time evolution, the electronic-only time steps employ linear interpolation to estimate important quantities. Consequently, a short electronic time step is not a substitute for a reasonable nuclear time step.
FSSH_CONTINUE
FSSH_CONTINUE
       Restart a FSSH calculation from a previous run, using the file 396.0. When this is enabled, the initial conditions of the surface hopping calculation will be set, including the correct wave function amplitudes, initial surface, and position/momentum moments (if AFSSH) from the final step of some prior calculation.
       0 Start fresh calculation. 1 Restart from previous run.
Example 9.40  FSSH simulation. Note that analytic derivative couplings must be requested via CALC_NAC, but it is unnecessary to include a $derivative_coupling section. The same is true for CIS_STATE_DERIV, which will be set to the initial active surface automatically. Finally, one must be careful to choose a small enough time step for systems that have energetic access to a region of large derivative coupling, hence the choice for AIMD_TIME_STEP_CONVERSION and TIME_STEP.
   C   -1.620294    0.348677   -0.008838
   C   -0.399206   -0.437493   -0.012535
   C   -0.105193   -1.296810   -1.081340
   H   -0.789110   -1.374693   -1.905080
   C    1.069016   -2.045054   -1.072304
   H    1.292495   -2.701157   -1.889686
   C    1.956240   -1.940324    0.002842
   H    2.859680   -2.517019    0.008420
   C    1.666259   -1.084065    1.071007
   H    2.348104   -1.005765    1.894140
   C    0.495542   -0.335701    1.065497
   H    0.253287    0.325843    1.871866
   O   -1.931045    1.124872    0.911738
   H   -2.269528    0.227813   -0.865645
   JOBTYPE                    aimd
   EXCHANGE                   hf
   BASIS                      3-21g
   CIS_N_ROOTS                3
   CIS_SINGLETS               false
   CIS_TRIPLETS               true
   PROJ_TRANSROT              true
   FSSH_LOWESTSURFACE         1
   FSSH_NSURFACES             3   ! hop between T1 and T2
   FSSH_INITIALSURFACE        1   ! start on T1
   AFSSH                      0   ! no decoherence
   CALC_NAC                   true
   AIMD_STEPS                 50  ! Typically more would be used
   TIME_STEP                  14
   AIMD_SHORT_TIME_STEP       2
   AIMD_TIME_STEP_CONVERSION  1   ! Do not alter time_step duration
   AIMD_PRINT                 1
   AIMD_INIT_VELOC            thermal
   AIMD_TEMP                  300 # K
   AIMD_INTEGRATION           vverlet
   FOCK_EXTRAP_ORDER          6
   FOCK_EXTRAP_POINTS         12
   INTEGRAL_SYMMETRY          off
   POINT_GROUP_SYMMETRY       false
