1.3 Q-Chem Features
1.3.4 New Features in Q-Chem 6.0
1.3.4.1 Features in 6.0.2
    General features and improvements:
      Enabled Molden support for the new default geometry optimizer
      Improved output for rxn path (IRC) calculations (John Herbert)
      Improved formatting of output for orbital radii of gyration (John Herbert)
      Improved error-catching for input section (John Herbert)
      Inlcuded one-electron matrices in fchk and archive
      Resolved pure and Cartesian assignment of nuclear-electronic orbital (NEO) basis (Mathew Chow, Sharon Hammes-Schiffer)
      Resolved issues with:
        AUTOSAD/I-Hirshfeld multiplicities for highly-charged transition metal atoms (Kevin Carter-Fenk)
        molden output for penalty function optimization
        calculations of the exact gradients and derivative couplings of CIS Boys diabatic states (Vishikh Athavale, Joseph Subotnik)
        immutable SOS_UFACTOR in SOS-CIS(D) calculations
        inconsistent charges and multipole moments in DUAL_BASIS_ENERGY calculations
        SCF_GUESS_MIX calculations with SAD guess (Yuezhi Mao)
    Density functional theory and self-consistent field:
      Improved algorithm for RI-JK derivatives
    Correlated methods:
      Enabled plotting of RAS-CI properties in cube, Molden and FChk files (Abel Carreras, David Casanova)
    Molecular dynamics, non-adiabatic dynamics, embedding, and solvation:
      Added printing of single-atom thermodynamic information for PCM jobs (John Herbert)
    Fragment and energy decomposition analysis improvements:
      Resolved issues with erroneous interaction energies with mixed basis sets for fragments (Yihan Shao, Yuezhi Mao)
    Miscellaneous:
      Added sample jobs for SCF_ALGORITHM options NEWTON_CG and NEWTON_MINRES (Yuezhi Mao)
      Added sample job for EDA2 calculation with external charges (Yuezhi Mao, Yihan Shao)
      Renamed sample jobs for variational PA/CTA based on GEN_SCFMAN_EDA2 (Yuezhi Mao, Hengyuan Shen)
      Added SOC-NTO analysis for TDDDFT and SF-TDDFT (Saikiran Kotaru, Anna Krylov)
1.3.4.2 Features in 6.0.1
      Restored support for IGDESP used by CHARMM (John Herbert)
      Implemented a memory-efficient GOSTSHYP algorithm (Felix Zeller)
      Enabled finite-field chemical shielding and magnetizability calculations using gauge-independent atomic orbitals (GIAOs) for HF and MP2 (Jonathan Wong, Brad Ganoe, Tim Neudecker, Adam Rettig, Xiao Liu, Joonho Lee)
        molden output for optimization in libopt3
        libopt3 Hessian calculations using PCM
        writing MO coefficients and energies to qarchive file
        cleaned up topology checking printing
        fixed printing of RMS of step size during geometry optimization
    Molecular dynamics, non-adiabatic dynamics, embedding, and solvation improvements:
      Implemented state-specific PCM with RAS-SF (Bushra Alam, Hanjie Jiang, John Herbert, Paul Zimmerman)
      Resolved issues with projection-based embedding calculations where frozen (environment) occupied orbitals are not ordered based on energies (Yuezhi Mao)
    Miscellaneous:
      Added comments to DFT SOC calculations for identifying the progress of the job (Saikiran Kotaru)
      Added warning about not having analytic Hessians for some optimization jobs
      Added printing to distinguish CPCM1 from CPCM2
1.3.4.3 Features in 6.0.0
    Changes to default behavior:
      Tightened default integral threshold (THRESH) to SCF_CONVERGENCE + 4 and used same threshold for DIIS and GDM
      Set default of FD_MAT_VEC_PROD to FALSE for VV10 functional (Yuezhi Mao)
      Turned off automatic evaluation of electrostatic potentils on a grid (Felix Plasser)
      Set finite difference as default for energy derivatives in electric field (Yuezhi Mao)
      Next-generation interface of Q-Chem with external tools (generation of archive files in the HDF5 format)
      Implemented the nuclear-electronic orbital CCSD (NEO-CCSD) method (Fabijan Pavosevic, Sharon Hammes-Schiffer)
      Implemented NEO-TDDFT analytical gradient and Hessian (Zhen (Coraline) Tao, Patrick E. Schneider, Sharon Hammes-Schiffer)
      Enabled subset selection of atoms in NMR J-coupling calculations (JOBTYPE = ISSC) via spin input section
      Disabled steepest descent in geometry optimization with fixed atoms
      Added delocalized natural internal coordinate optimization in new optimizer
      Updated geometry in the MolDen file for each step in finite difference optimizations (John Herbert)
      Stabilized density fitting for JK and MP2
      Set new optimizer as default for unconstrained optimization (GEOM_OPT_DRIVER = LIBOPT3)
      Added the minimal-augmented and heavy-augmented versions of the Karlsruhe basis sets (John Herbert)
      Removed MPI support
        incorrect Hirshfeld charges based on molecule input orders (Abdulrahman Aldossary)
        not-a-number (NAN) errors in SOC calculations
        missing nuclear repulsion energies in Fock projection (BASIS2) calculations
        removed restriction on number of atoms (MAX_ATOM) that can be included in random search and basin hopping
        ordering of localized MOs in formatted checkpoint files (Abdulrahman Aldossary)
        missing ECP for the def2-SVPD basis set
        failure to compute NMR properties with linearly dependent basis sets
        parsing input files with 100k+ lines
        character table of C3 point group
      Accelerated convergence of the SCF algorithm ADIIS and add a new combined algorithm option ADIIS_DIIS. (Yuezhi Mao)
      Enabled gauge-independent atomic orbitals (GIAOs) in SCF calculations using GEN_SCFMAN (Brad Ganoe, Tim Neudecker, Joonho Lee, Adam Rettig, Jonathan Wong)
      Disabled user setting of coefficients (via HFK_LR_COEF/HFK_SR_COEF) if using built-in range-separated functionals
      Implemented frequency calculation and analytic Hessian for the VV10 functional (Jiashu Liang)
      Enabled generation of formatted checkpoint files in CIS/TDDFT calculations with frozen occupied/virtual orbitals via GUI = 2 (Yuezhi Mao)
      Enabled STATE_ANALYSIS for the new plot section (PLOT = 1) (Yuezhi Mao)
      Performed consistency check on TDKS Fock matrices based on the SCF convergence threshold (SCF_CONVERGENCE) instead of the field amplitude (John Herbert)
      Added new energy density functionals: revSCAN, regSCAN, r++SCAN, r2SCAN, r4SCAN, TASK, mTASK, regTM, rregTM, revTM
      Enabled computing spin-orbit couplings (SOC) (1-electron and 2-electron mean-field) with TDDFT (both restricted and unrestricted) and spin-flip TDDFT (SF-TDDFT) (Saikiran Kotaru, Ana Krylov)
      Implemented analytic gradient for density-corrected DFT (DC-DFT) for self-interaction correction (Marc Coons, Bhaskar Rana, John Herbert)
        incorrect results of fractional electron SCF calculations using GEN_SCFMAN (Yuezhi Mao)
        hanging qints (USE_LIBQINTS = TRUE) jobs with large number of OpenMP threads
        non-variational initial SCF guess for ADIIS (Yuezhi Mao)
        incorrect memory estimation in TDDFT/TDA calculations
        crash of TDA excited state frequency jobs
        crash of geometry optimization with fixed atoms
        frequency calculations using basis functions with g or higher angular momenta
        sign error with TDDFT spin-orbit coupling calculations (Nicole Bellonzi)
        crash of projection-based embedding calculations (Yuezhi Mao)
        incorrect result of RPA TDDFT frequency using non-Pople basis set
        insufficient memory allocation for NMR calculations with meta-GGA functionals
        erroneous results in DC-DFT calculations using hybrid functionals with larger basis sets (Marc Coons, Bhaskar Rana, John Herbert)
        crash of excited state potential energy surface scans with CIS/TDDFT (John Herbert)
    Correlated methods:
      Implemented EOM oscillator strengths in velocity and mixed gauges (Josefine Andersen, Sonia Coriani)
      Implemented CCSD optical rotation evaluation (Josefine Andersen, Kaushik Nanda)
      Implemented the fragment charge difference (FCD) scheme in RASMAN2 (Chou-Hsun (Jeff) Yang, Aaditya Manjanath, Chao-Ping (Cherri) Hsu)
      Implemented complex-valued CC2, RI-CC2, and RI-CCSD (Cansu Utku, Garrette Paran, Thomas Jagau)
      Implemented the complex absorption potential (CAP) method in AIMD calculations (Jerryman A. Gyamfi, Thomas Jagau)
      Implemented the v2RDM-CASSCF-PDFT method using density fitted basis sets (Mohammad Mostafanejad, Run Li, A. Eugene DePrince III)
      Resolved formatting error in output of SOC calculation with RAS-CI method (Abel Carreras, David Casanova)
      Implemented projection-based embedding with complex basis functions (Valentina Parravicini, Thomas Jagau)
      Enabled user-defined permittivity grid for Poisson equation solver (PEqS) (Suranjan Paul)
      Improved PCM printing (John Herbert)
      Implemented CIS and TDDFT wavefunction overlaps including their spin-flip variants for (A)FSSH (Theta Chen, Junhan Chen, Zuxin Jin, Vishikh Athavale, Vale Cofer-Shabica, Joe Subotnik)
      Resolved issues with QM/MM optimzation not reading previous MOs as a guess for the next cycle
    Fragment and energy decomposition analysis:
      Implemented pairwise fragment excitation energy decomposition analysis (EDA) in QM/EFP calculations (Lyudmila Slipchenko)
      Increased the maximum angular momentum of basis functions to 5 for XSAPT calculations
      Implemented SPADE- and ALMO-based partitioning schemes for electric field calculations (Yuezhi Mao)
      Implemented a new MP2 EDA scheme and added a non-perturbative polarization analysis for DFT EDA (Kevin Ikeda, Hengyuan Shen)
      Enabled ALMO-CIS/TDA calculations with excitation amplitudes localized on one fragment (Yuezhi Mao)
      Enabled ALMO-CIS/TDA calculations with excitation from one fragment’s occupied orbitals to all virtuals in the system (Yuezhi Mao)
      Enabled ALMO-CIS/TDA calculations with excitation from one fragment’s occupied orbitals to another’s virtual orbitals (Yuezhi Mao)
      Enabled user-defined occupied-virtual pairs in ALMO-CIS/TDA calculations (Yuezhi Mao)
      Resolved miscellaneous issues with ALMO-CIS and excited-state ALMO-EDA calculations (Yuezhi Mao)
    Miscellaneous:
      Printed orbital kinetic energies using SCF_PRINT = 3
      Enabled EXTERNAL_CHARGES specification in an external file (Vale Cofer-Shabica, Joseph Subotnik)
      Added parameter check for many-body dispersion calculations (John Herbert)
      Restored finite difference for ωB97M-2 and the XYG series of energy functionals
      Restored finite difference banner for SA-SF-RPA
