7.8 Restricted Open-Shell and ΔSCF Methods
7.8.3 Restricted Open-Shell Kohn-Sham Method (ROKS)
Singly-excited states of closed-shell molecules cannot be described via a single non-aufbau filled Slater determinant as both the up and down spins are equally likely to be excited, leading to at least two configurations with equal weights. Triplet energies can nonetheless be found from a single determinant by switching from the MS=0 subspace of the ground state to MS=±1 (i.e., by having both unpaired electrons have spins pointing in the same direction instead of having one up and one down spin). This tactic however does not work on singlet excited states, with non-aufbau filled configurations where only the up (or down) spin is excited being intermediate between singlet and triplet (and thus spin contaminated). This mixed state is not unlike spin-symmetry broken, unrestricted ground state solutions. An actual singlet energy can be obtained via approximate spin-purification post SCF, by removing the triplet contribution to the energy. The triplet energy thus has to be separately estimated with a second orbital optimization.
The restricted open-shell Kohn-Sham (ROKS) method offers an alternative route to singlet excited states of this nature. The mixed non-aufbau configuration (with either the up or down spin being excited) is exactly halfway between a singlet and triplet when restricted open-shell orbitals are used, and has an energy Emix. The triplet energy ET is also computable from a single determinant within the the MS=±1 subspaces. Consequently, ROKS optimizes a set of spin-restricted orbitals {ϕROKS} such that the spin-purified singlet energy ES=2⁢Emix⁢[{ϕROKS}]-ET⁢[{ϕROKS}] is stationary. This therefore needs only one orbital optimization, in contrast to the two sets needed for the ΔSCF approach mentioned in the preceding paragraph. The structure of the ROKS Fock matrix however is more complex, by virtue of the two-determinant nature of the equations. 541 Hirao K., Nakatsuji H.
(1973), 59, pp. 1457.
, 676 Kowalczyk T. et al.
(2013), 138, pp. 164101.
It is also important to note that this excited-state method is distinct from ROKS theory for open-shell ground states, which is a single-determinant method corresponding to the high-spin state with multiple unpaired spins.
The implementation of ROKS excited states in Q-Chem largely follows the theoretical framework established by Filatov and Shaik; 361 Filatov M., Shaik S.
(1999), 304, pp. 429.
see Ref.  676 Kowalczyk T. et al.
for the case of the lowest excited singlet (S1 state) with a DIIS-based approach. An example is provided below. ROKS for higher excited states is possible using either the squared-gradient approach (Section 7.8.4), the maximum overlap method (Section 7.6), or else state-targeted energy projection (Section 7.8.5).
ROKS has been found to be significantly more accurate than TDDFT for describing charge-transfer states, 475 Hait D. et al.
(2016), 12, pp. 3353.
and preliminary evidence shows the same to hold for Rydberg states. ROKS is also extremely accurate for core excitation energies, with the SCAN functional yielding errors below 0.5 eV for both K- and L-edge excitations of small molecules. 472 Hait D., Head-Gordon M.
J. Phys. Chem. Lett.
(2020), 11, pp. 775.
Examples of using ROKS/SGM to compute core-excited states are provided in Section 7.8.4. Analytic nuclear gradients (in the excited state) are also available, enabling geometry optimization and molecular dynamics calculations as well, along with finite-difference frequency calculations. Users of the ROKS code are requested to cite Ref.  676 Kowalczyk T. et al.
, and in addition Ref.  473 Hait D., Head-Gordon M.
(2020), 16, pp. 1699.
if the SGM implementation is employed, as well as Ref.  475 Hait D. et al.
for charge-transfer states and Ref.  472 Hait D., Head-Gordon M.
for application to core excitations.
The chief limitation of ROKS is that it can only describe states with one broken electron pair. It is consequently applicable only to certain excited states of closed-shell systems: all singlet single excitations well-described by a single natural transition orbital (NTO) pair, or higher singlets where only one electron pair is broken in total (like the 1B3⁢g doubly excited state of tetrazine). Fortunately, most charge-transfer and core-excitations do not require more than one broken electron pair, and so this limitation is not a major problem in practice.
Furthermore, ROKS often suffers from an un-physical mixing between the open-shell orbitals when they belong to the same spatial symmetry, which often manifests in π⟶π* and 1⁢s⟶3⁢s excitations. 378 Friedrichs J., Damianos K., Frank I.
Chem. Phys.
(2008), 347, pp. 17.
This is associated with the inherent ambiguity in defining an effective Fock opereator for a two-determinant wave function. 541 Hirao K., Nakatsuji H.
, 378 Friedrichs J., Damianos K., Frank I.
Chem. Phys.
Convergence is often difficult for the states where this mixing manifests, and the overlap with the ground state may be significant. Two protocols can be used to alleviate this issue. The first is a level-shift technique that splits the energy between the two singly-occupied orbitals thereby supressing their mixing. 676 Kowalczyk T. et al.
It is only available with DIIS and for the ROKS implementation on the old SCF engine (GEN_SCFMAN = FALSE). The second is a total supression of the mixing between the sinlgy-occupied orbitals. While this may disregard the correct variational condition, 541 Hirao K., Nakatsuji H.
it produces excited states with much smaller overlaps with the ground state and provides smoother convergence. See 7.8.3 for a demonstration.
To perform an ROKS excited state calculation, simply set the keyword ROKS = TRUE and ensure that UNRESTRICTED = FALSE. It is recommended to perform a preliminary ground-state calculation on the system first, and then use the ground-state orbitals to construct the initial guess using SCF_GUESS = READ.
ROKS
ROKS
       Controls whether ROKS calculation will be performed.
       FALSE ROKS is not performed. TRUE ROKS will be performed.
       Set to TRUE if ROKS calculation is desired. Make sure that UNRESTRICTED is not set to TRUE.
ROKS_LEVEL_SHIFT
ROKS_LEVEL_SHIFT
       Introduce a level shift of N/100 hartree to aid DIIS convergence.
       0 No shift N level shift of N/100 hartree.
       Use in cases of problematic DIIS convergence. Only available for the ROKS implementation on the old SCF engine (GEN_SCFMAN = FALSE).
ROKS_SS_MIXING
ROKS_SS_MIXING
       Allow coupling between the two singly-occupied molecular orbitals.
       0 Supress coupling. 1 Allow coupling.
       Supress coupling when the resuling states are difficult to converge and / or overlap significantly with the ground state. Only for GDM and SGM-based solvers.
Example 7.44  RO-PBE0/6-311+G* excited state gradient of formaldehyde, using the ground state orbitals as an initial guess. This used the DIIS based implementation of Ref  676 Kowalczyk T. et al.
   ROKS excited state gradient of formaldehyde
   Use orbitals from ground state for initial guess
   EXCHANGE          pbe0
   BASIS             6-311+G*
   SCF_CONVERGENCE   9
point_group_symmetry False
   H      -0.940372    0.000000    1.268098
   H       0.940372    0.000000    1.268098
   C       0.000000    0.000000    0.682557
   O       0.000000    0.000000   -0.518752
   ROKS              true
   UNRESTRICTED      false
   EXCHANGE          pbe0
   BASIS             6-311+G*
   JOBTYPE           force
   SCF_CONVERGENCE   9
   SCF_GUESS         read
Example 7.45  ROKS calculation on the lowest π⟶π* excited state of acetone using ωB97X-D / STO-3G. To observe the mixing of the open-shells, as well as the effect of mixing supression, try running this example with ROKS_SS_MIXING set to TRUE/FALSE.
  Plain old SCF on the ground state.
  C   0.00000000      0.00000000      0.18807702
  C   0.00000000      2.42007545     -1.31764698
  C   0.00000000     -2.42007545     -1.31764698
  O   0.00000000      0.00000000      2.48269094
  H   0.00000000      4.03690733     -0.05185132
  H   0.00000000     -4.03690733     -0.05185132
  H   1.66061256      2.48420530     -2.53995285
  H  -1.66061256      2.48420530     -2.53995285
  H   1.66061256     -2.48420530     -2.53995285
  H  -1.66061256     -2.48420530     -2.53995285
  METHOD               WB97X-D
  UNRESTRICTED         FALSE
  BASIS                STO-3G
  INPUT_BOHR           TRUE
  INTEGRAL_SYMMETRY    FALSE
  POINT_GROUP_SYMMETRY TRUE
  GEN_SCFMAN           TRUE
  SCF_ALGORITHM        DIIS_GDM
  SCF_CONVERGENCE      8
  MAX_SCF_CYCLES       200
  MEM_TOTAL            1000
  MEM_STATIC           100
  THRESH               14
  Plain old SCF on the ground state with UNRESTRICTED = TRUE
  to enable TRANS_MOM_SAVE.
  METHOD               WB97X-D
  UNRESTRICTED         TRUE
  BASIS                STO-3G
  INPUT_BOHR           TRUE
  SYM_IGNORE           TRUE
  GEN_SCFMAN           TRUE
  SCF_GUESS            READ
  SCF_ALGORITHM        DIIS
  SCF_CONVERGENCE      10
  MAX_SCF_CYCLES       200
  TRANS_MOM_SAVE       1
  MEM_TOTAL            1000
  MEM_STATIC           100
  THRESH               14
  ROKS calculation targeting the \pi -> \pi^{*} state. Attempt
  to run this calculation with ROKS_SS_MIXING = TRUE to see
  what happens.
  METHOD               WB97X-D
  UNRESTRICTED         FALSE
  ROKS                 TRUE
  ROKS_SS_MIXING       FALSE
  BASIS                STO-3G
  INPUT_BOHR           TRUE
  GEN_SCFMAN           TRUE
  SCF_GUESS            READ
  SCF_ALGORITHM        GDM
  SCF_CONVERGENCE      7
  MAX_SCF_CYCLES       1000
  TRANS_MOM_READ       2
  THRESH               14
  MEM_STATIC           100
  MEM_TOTAL            1000
$reorder_mo
  1 2 3 4 5 6 7 8 9 10 11 12 13 14 16 15 17
