10.7 Harmonic Vibrational Analysis
10.7.1 Overview
Vibrational analysis is an extremely important tool for the quantum chemist, supplying a molecular fingerprint which is invaluable for aiding identification of molecular species in many experimental studies. Q-Chem includes a vibrational analysis package that can calculate vibrational frequencies and their infrared and Raman activities. 607 Johnson B. G., Florián J.
(1995), 247, pp. 120.
Vibrational frequencies are calculated by either using an analytic Hessian (if available; see Table 9.2) or, numerical finite difference of the gradient. The default setting in Q-Chem is to use the highest analytical derivative order available for the requested theoretical method. The performance of various ab initio theories in determining vibrational frequencies has been well documented. 905 Murray C. W. et al.
(1992), 199, pp. 551.
, 610 Johnson B. G., Gill P. M. W., Pople J. A.
(1993), 98, pp. 5612.
, 1141 Scott A. P., Radom L.
J. Phys. Chem.
(1996), 100, pp. 16502.
When calculating analytic frequencies at the HF and DFT levels of theory, the coupled-perturbed SCF equations must be solved. This is the most time-consuming step in the calculation, and also consumes the most memory. The amount of memory required is 𝒪⁢(N2⁢M) where N is the number of basis functions, and M the number of atoms. This is an order more memory than is required for the SCF calculation, and is often the limiting consideration when treating larger systems analytically. Q-Chem incorporates a new approach to this problem that avoids this memory bottleneck by solving the CPSCF equations in segments. 671 Korambath P. P. et al.
Mol. Phys.
(2002), 100, pp. 1755.
Instead of solving for all the perturbations at once, they are divided into several segments, and the CPSCF is applied for one segment at a time, resulting in a memory scaling of 𝒪⁢(N2⁢M/Nseg), where Nseg is the number of segments. This option is invoked automatically by the program.
After a vibrational analysis, Q-Chem computes useful statistical thermodynamic properties at standard temperature and pressure following the rigid-rotor-harmonic-oscillator (RRHO) approach. These include the zero-point vibration energy (ZPVE) and, translational, rotational and vibrational, entropies and enthalpies. Note: in the Q-Chem output the “total enthalpy” actually means the total enthalpy correction to the internal energy. One must add this “total enthalpy” to the internal energy to obtain the total enthalpy in common sense. In addition to these thermal corrections, Q-Chem also prints the interpolated vibrational entropy and enthalpy according to the quasi-RRHO (qRRHO) approach by Head-Gordon and co-workers, 776 Li Y.-P. et al.
J. Phys. Chem. C
(2015), 119, pp. 1840.
which extends Grimme’s previous scheme 460 Grimme S.
Chem. Eur. J
(2012), 18, pp. 9955.
to address low-frequency vibrations; Section 10.7.3.
10.7.1.1 Job Control
In order to carry out a frequency analysis users must at a minimum provide a molecule within the $molecule keyword and define an appropriate level of theory within the $rem keyword using the $rem variables EXCHANGE, CORRELATION (if required) (Chapter 4) and BASIS (Chapter 8). Since the default type of job (JOBTYPE) is a single point energy (SP) calculation, the JOBTYPE $rem variable must be set to FREQ.
Users should also be aware that the quality of the quadrature grid used in DFT calculations is more important when calculating second derivatives. The default grid for some atoms has changed in Q-Chem 3.0 (see Section 5.5) and for this reason vibrational frequencies may vary slightly form previous versions. It is recommended that a grid larger than the default grid is used when performing frequency calculations.
    Vibrational frequencies.
    Raman and IR activities and intensities (requires $rem DORAMAN).
    Atomic masses.
    Zero-point vibrational energy.
    Translational, rotational, and vibrational, entropies and enthalpies.
DORAMAN
DORAMAN
       Controls calculation of Raman intensities. Requires JOBTYPE to be set to FREQ
       FALSE Do not calculate Raman intensities. TRUE Do calculate Raman intensities.
VIBMAN_PRINT
VIBMAN_PRINT
       1 Standard full information print out. If VCI is TRUE, overtones and combination bands are also printed. 3 Level 1 plus vibrational frequencies in atomic units. 4 Level 3 plus mass-weighted Hessian matrix, projected mass-weighted Hessian matrix. 6 Level 4 plus vectors for translations and rotations projection matrix.
       Use the default.
CPSCF_NSEG
CPSCF_NSEG
       0 Determine the number of segments based on the memory request and MEM_TOTAL n User-defined. Use n segments when solving the CPSCF equations.
       Use the default.
Example 10.28  EDF1/6-31+G* optimization followed by vibrational analysis. Doing the vibrational analysis at a stationary point is necessary for the results to be valid.
   C  1  co
   F  2  fc  1  fco
   H  2  hc  1  hco  3  180.0
   co  =   1.2
   fc  =   1.4
   hc  =   1.0
   fco = 120.0
   hco = 120.0
   JOBTYPE    opt
   METHOD     edf1
   BASIS      6-31+G*
   JOBTYPE    freq
   METHOD     edf1
   BASIS      6-31+G*
10.7.1.2 Interpreting the Output
Numerical values in the following discussion correspond to Example 10.7.1.1 and the referenced partition functions come from the textbook by McQuarrie & Simon. Note that Q-Chem assumes T=298.15 K and P=1.00 atm by default; see Section 10.7.2 for instructions on how to modify these choices.
The quantity listed as zero-point energy (ZPE),
Zero point vibrational energy: 12.695 kcal/mol
corresponds to ZPE=12⁢h⁢c⁢ν⁢NA. Within Q-Chem the vibrational entropy (Svib) is computed from the bottom of the well rather than from the zero-point level, and thus includes the ZPE. This corresponds to a vibrational partition function
qvib⁢(T)=∏Ke-Θν,K/2⁢T1-e-Θν,K/T (10.38)
where K indexes vibrational modes and ΘK=h⁢νK/kB is the vibrational temperature of the Kth mode. This expression can be altered by a factor of ΘK/2 to start at the first vibrational level rather than the bottom of the well. The vibrational entropy is then
Svib=kB⁢T⁢(∂⁡ln⁡qvib∂⁡T)V+kB⁢ln⁡qvib=kB⁢T⁢∑K[ΘK/Te-ΘK/T-1-ln⁡(1-e-ΘK/T)], (10.39)
and for Example 10.7.1.1 it is reported as
Vibrational Entropy: 0.620 cal/mol.K
The vibrational enthalpy,
Hvib=c⁢∑KνKeΘK/T-1, (10.40)
is reported as
Vibrational Enthalpy: 12.839 kcal/mol
The rotational and translational enthalpy are multiples of R⁢T and then then
Total Enthalpy: 15.209 kcal/mol
is given by
Htotal=Hvib+Hrot+Htrans+R⁢T, (10.41)
where the final contribution of R⁢T comes from the usual definition, H=U+P⁢V. Translational and rotational entropies can be computed from the corresponding ideal-gas partition functions; see Ref.  .
For thermochemical calculations performed in implicit solvent (using models described in Section 11.2), there is a subtle point with some controversy attached. 547 Ho J., Klamt A., Coote M. L.
(2010), 114, pp. 13442.
, 1090 Ribeiro R. F. et al.
J. Phys. Chem. B
(2011), 115, pp. 14556.
, 195 Casasnovas R. et al.
Int. J. Quantum Chem.
(2014), 114, pp. 1350.
, 529 Herbert J. M.
(2021), 11, pp. e1519.
This regards whether vibrational contributions to the free energy should be included or not. In nearly all cases, continuum solvation models are parameterized in order to reproduce experimental free energies of solvation (Δsolv⁢G∘) using rigid gas-phase geometries for the solute molecules. There is a potential double-counting problem if -T⁢Svib from a vibrational frequency calculation in implicit solvent is added, which might be avoided by instead using gas-phase harmonic frequencies for the solute. 547 Ho J., Klamt A., Coote M. L.
However, the difference between these procedures is negligible (∼0.2 kcal/mol). for the small-molecule data sets that are used to train implicit solvent models, 1090 Ribeiro R. F. et al.
J. Phys. Chem. B
and only by using solution-phase vibrational frequencies can one obtain corrections to Svib arising from solvation-induced changes in geometry, which might be significant for larger molecules. Note that Q-Chem’s harmonic frequency engine assumes a gas-phase molecule (even in the presence of continuum solvent), so that rotational and translational contributions to the free energy are printed out in every case. These should not be included in solution-phase free energy differences.
