10.7 Harmonic Vibrational Analysis
10.7.7 Vibrationally-Resolved Electronic and Resonance Raman Spectra
Optical spectroscopy is the study of the interaction between the light and matter, and the study that encompasses a wide range of physical and chemical behavior, which can be directly recorded by the spectrometers. Contemporary spectroscopic techniques have been applied to widespread research fields and have served as a popular tool to obtain the information of structural and dynamical features of the matter. However, the experimentally-measured spectra can’t straightforwardly give the microscopic information of the matter. The theoretical calculations of the spectra can serve as a supplementary tool to the experimental measurements and provide a deeper understanding on the underlying physical and chemical phenomena. 986 Pedone A., Biczysko M., Barone V.
ChemPhysChem
(2010), 11, pp. 1812.
, 70 Barone V., Biczysko M., Brancato G.
Adv. Quantum Chem.
(2010), 59, pp. 17.
, 69 Barone V. et al.
(2012), 14, pp. 12404.
One can easily determine geometrical, electronic and dynamical features of matters through a comparison between the experimental results and the calculated values. Moreover, the role of different effects in spectroscopic properties can also be quantified by the calculations.
Vibrationally-resolved one-photon absorption (OPA) and emission (OPE) spectra and resonance Raman scattering (RRS) spectra, each of which involves simultaneous changes in the vibrational and electronic states of a molecule, can reveal a reliable molecular structure–property relationship. Theoretical prediction of these spectra needs to combine both the electronic structure theories and quantum dynamics methods to obtain the structure parameters and describe quantum dynamics, respectively. 1201 Spiro T. G., Stein P.
Annu. Rev. Phys. Chem.
(1977), 28, pp. 501.
, 1333 Warshel A.
Annu. Rev. Biophys. Bioeng.
(1977), 6, pp. 273.
, 219 Champion P. M., Albrecht A. C.
(1982), 33, pp. 353.
, 908 Myers A. B.
Chem. Rev.
(1996), 96, pp. 911.
, 909 Myers A. B.
Acc. Chem. Res.
(1997), 30, pp. 519.
, 1322 Wächtler M. et al.
Coord. Chem. Rev.
(2012), 256, pp. 1479.
For RRS simulation using the IMDHO model (which neglects Duschinsky rotation), see Section 10.7.6.
10.7.7.1 Time-dependent approach to simulating spectra
On the basis of perturbation theory, the transition rate of one- or two-photon transition processes from the initial state |I⟩ to the final state |F⟩ is proportional to kI⁢F=|⟨F|M^|I⟩|2⁢δ⁢(Δ⁢ω), where δ⁢(Δ⁢ω) is the line shape function with Δ⁢ω=ωi-ωF⁢I for a one-photon transition and Δ⁢ω=ω1+ω2-ωF⁢I for a two-photon process. Here ωi, ω1, and ω2 denote the incident photon frequencies and the operator M^ is given by
M^={μ^(one-photon transition)∑L[μ⋅e^2⁢|L⟩⁢⟨L|⁢μ⋅e^1(ω1-ωL⁢I)+μ⋅e^1⁢|L⟩⁢⟨L|⁢μ⋅e^2(ω2-ωL⁢I)](two-photon transition). (10.53)
In the two-photon case there are intermediate or “virtual” states |L⟩.
Raman scattering is a two-photon process. In this process, one photon with the frequency ωi is absorbed, another photon with the frequency ωS is emitted, and the transition from the initial to the final vibrational states takes place. Based on perturbation theory, the transition rate of the Raman process is proportional to S⁢(ωi,ωS)=|⟨F|M^|I⟩|2⁢δ⁢(Δ⁢ω), where
M^=∑L[μ⋅e^2⁢|L⟩⁢⟨L|⁢μ⋅e^1(ωi-ωL⁢I)-μ⋅e^1⁢|L⟩⁢⟨L|⁢μ⋅e^2(ωS+ωL⁢I)] (10.54)
and Δ⁢ω=ωS-ωi+ωF⁢I. The differential photon scattering cross section is given by 35 Albrecht A. C.
(1961), 34, pp. 1476.
σ⁢(ωi,ωS)∝4⁢ωi⁢ωS39⁢c4⁢S⁢(ωi,ωS). (10.55)
RRS spectroscopy is a type of vibrational Raman spectroscopy in which the incident laser frequency is close to an electronic transition of the molecule or crystal studied. As the adiabatic energy gap ωL⁢I between the L state and the initial I state is close to the laser frequency ωi, the intermediate L state will make the dominant contribution to RRS. Under the “resonant” condition, the contributions from the non-resonant electronic states can be neglected.
One may evaluate MI⁢F=⟨ΦF|M^|ΦI⟩ by making use of the Herzberg-Teller (HT) expansion, i.e., one expands the integrals about the nuclear equilibrium configuration Q=0. Writing the pure-spin Born–Oppenheimer (psBO) functions as products of an electronic wavefunction Ψ and a vibrational wavefunction Λ
Φn⁢(q,Q)=Ψn⁢(q,Q)⁢Λn⁢(Q), (10.56)
we have
Ψn⁢(q,Q)=Ψn⁢(q,0)+[∂⁡Ψn⁢(q,0)/∂⁡Q]Q=0⁢Q+⋯,MI⁢F=MI⁢F(Q=0)+[∂MI⁢F/∂Q]Q=0Q+⋯. (10.57)
The second term in Eq. (10.57) origins from the HT expansion. If we truncate the expansions after the lowest-order non-vanishing term, MI⁢F can be written as
MI⁢F =⟨ΨF⁢(q,0)|M^|ΨI⁢(q,0)⟩⁢⟨ΛF⁢(Q′)|ΛI⁢(Q)⟩
  +[(∂/∂⁡Q)⁢⟨ΨF⁢(q,0)|M^|ΨI⁢(q,0)⟩]Q=0⁢⟨ΛF⁢(Q′)|Q|ΛI⁢(Q)⟩. (10.58)
If the first term, the direct transition, vanishes, this process is orbitally forbidden.
To evaluate the vibrational terms in the remaining part of the vibronic matrix elements, we can use the harmonic oscillator approximation. Then the vibrational part of the wave function is written as Λn=∏k=1Nχk(n)⁢(νn), where N is the total number of normal modes χk and νn the vibrational quantum number associated with mode k in state |n⟩.
The delta function δ⁢(Δ⁢ω) can be expressed as the Fourier integral
δ⁢(Δ⁢ω)=12⁢π⁢ℏ⁢∫-∞+∞e(i⁢Δ⁢ω)⁢t/ℏ⁢𝑑t, (10.59)
and then the transition rate from the initial state to the final state becomes
kI⁢F=∫-∞+∞exp⁡[i⁢(ω0+Ei-Ef)⁢t/ℏ-γ⁢t]⁢Ci⁢(t)⁢𝑑t (10.60)
where γ is a damping factor and
Ci⁢(t)=tr[e-β⁢H^iei⁢H^i⁢t/ℏM^e-i⁢Hf⁢t/ℏM^)tr⁢[e-β⁢H^i]. (10.61)
Here β=1/kB⁢T, ω0=ωi in one-photon absorption and emission processes, ω0=ωi-ωS in Raman scattering process. The notation tr⁢(⋯) represents a trace over nuclear and electronic degrees of freedom, and M^=|Λi⟩⁢MI⁢F⁢⟨Λf|+|Λf⟩⁢MF⁢I⁢⟨Λi|. The quantities H^i and H^f denote the nuclear Hamiltonians of electronic ground and excited states, respectively.
The Hamiltonian of vibrational motions on the ground and excited states can be written as
Hg =12⁢∑jN[(Pg,i)2+(ωjg⁢Qg,j)2], (10.62a)
He =12⁢∑jN[(Pe,i)2+(ωje⁢Qe,j)2], (10.62b)
where P and Q are the momenta and coordinates of vibrational normal modes, respectively. The normal mode coordinates of ground and excited states are correlated by the Duschinsky rotation matrix D¯, with Qe=D¯⁢Qg+Δ¯. The quantity Δ¯ is the displacement of normal mode coordinates between ground and excited states, i.e., the same quantity that appears in the IMDHO theory of Section 10.7.6, Eq. (10.47). The dimensionless forms are correspondingly Δj=(ωje)1/2⁢Δ¯j and Di⁢j=(ωie/ωjg)1/2⁢D¯i⁢j. From the above, the transition rate can be calculated directly in the time domain using the correlation function approach. This time-dependent approach has been implemented to calculate vibronic spectra. 820 Ma H., Liu J., Liang W.
(2012), 8, pp. 4474.
, 781 Liang W. et al.
J. Phys. Chem. B
(2006), 110, pp. 9908.
, 821 Ma H., Zhao Y., Liang W.
(2014), 140, pp. 094107.
, 778 Liang W. et al.
Int. J. Quantum Chem.
(2015), 115, pp. 550.
It is obvious that ground and excited electronic states have different potential energy surfaces leading to different vibrational frequencies and normal modes. The relation between mass-weighted Cartesian displacement coordinates x and normal mode coordinates Q is given by
xg-x0g=Lg⁢Qg,xe-x0e=Le⁢Qe, (10.63)
where x0g and x0e are the equilibrium structures of ground and excited states. For an ideal N-dimensional harmonic oscillator, the normal mode coordinates of ground and excited states are related by
Qe=(Le)⊤⁢Lg⁢Qg+(Le)⊤(x0g-x0e)=D¯⁢Qg+Δ¯. (10.64)
The minimum points on the potential surface and the Hessian matrix are required to calculate the Duschinsky rotation matrix and displacement vector. It can be time-consuming to calculate the excited-state potential surface, especially for large molecules, and often problematic due to state crossings. The linear coupling model (LCM), which is also known as the vertical gradient (VG) approximation, has been proposed to avoid this issue. 202 Cederbaum L. S., Domcke W.
(1976), 64, pp. 603.
Assuming that the excited-state potential surface is approximated by a shift in the ground state PES, namely ωje=ωjg and Le=Lg, the displacement of Qj can be calculated by the excited-state energy gradient (∂⁡E/∂⁡Q)j and ΔVG can be written as
ΔjVG=(ωjg)-3/2⁢(∂⁡E∂⁡Q)j=∑i(ωjg)-3/2⁢(∂⁡E∂⁡xi)⁢Lgi⁢j. (10.65)
The VG approximation is equivalent to the IMDHO approximation that is discussed in Section 10.7.6. 628 Kane K. A., Jensen L.
J. Phys. Chem. C
(2010), 114, pp. 5540.
, 467 Guthmuller J.
(2016), 144, pp. 064106.
Generally, the Franck-Condon (FC) approximation is accurate enough for strongly one- or two-photon allowed transitions, while it breaks down for forbidden or weakly allowed transitions, and the FC term becomes nearly zero. In this situation, a correction to this deviation should be introduced by including the Herzberg-Teller (HT) or non-Condon effect. 785 Lin S. H., Eyring H.
Proc. Natl. Acad. Sci. USA
(1974), 71, pp. 3802.
, 957 Orlandi G., Siebrand W.
(1973), 58, pp. 4513.
, 35 Albrecht A. C.
, 34 Albrecht A. C., Hutley M. C.
(1971), 55, pp. 4438.
, 1189 Small G. J.
(1971), 54, pp. 3300.
HT-type vibronic coupling comes from the normal mode-coordinate dependence of the transition moments. When these quantities are expanded in terms of the normal mode coordinates, the contribution of the linear-coordinate-dependent terms is commonly called HT effect. 35 Albrecht A. C.
Many works, whether or not they account for the mode-mixing or Duschinsky rotation (DR) effect or not, have shown the importance of the HT effect in OPA, OPE, and RRS spectra. 778 Liang W. et al.
To predict OPA, OPE and RRS spectra, electronic structure calculations on ground and excited states should be performed. The necessary jobs at different level of approximation are summarized in the following:
    FC. This is available for OPA, OPE, and RRS spectra.
    1. 1.
      x0g≠x0e, Lg=Le, and ωg=ωe. Geometry optimization on excited state potential surface is performed, followed by ground state optimization and frequency analysis.
    2. 2.
      x0g≠x0e, Lg≠Le, and ωg≠ωe. Geometry optimization and frequency calculation are needed on both ground and excited states.
    FCHT. This is available for OPA, OPE, and RRS spectra.
      x0g≠x0e, Lg≠Le, and ωg≠ωe. It is similar to the second kind of FC calculation, in which transition dipole derivative is obtained via frequency calculation on excited state. Geometry optimization and frequency calculation are needed on both ground and excited states.
    VG. This is available for OPA and RRS spectra.
      x0g=x0e, Lg=Le, and ωg=ωe. Only the geometry optimization and frequency calculation of the ground state is involved. Frequencies and normal modes of excited state are assumed to be the same as ground state. The displacement vector is approximated by Eq. (10.65), in which the gradient of excited state potential surface is produced by excited state force job. Of course VG model has only contribution from FC term.
10.7.7.2 Job Control
Since both ground state and excited state parameters are required, the routines to predict vibronic spectra are designed to have two steps. Firstly excited state calculation is performed and information about excited state will be saved in $QCSCRATCH/savename. Then the vibronic spectra utility is called to simulate the requested spectra after frequency analysis on ground state. POINT_GROUP_SYMMETRY should be set to FALSE in order to prevent the molecular geometry being transformed to the standard orientation. Therefore the vibronic spectra job input can be set up in two ways. First, the multiple jobs can be separated by the string @@@ as described in Section 3.5. Or, jobs can be separated into individual inputs using $QCSCRATCH/savename as described below and given as examples 10.7.7.3 and 10.7.7.3.
qchem infile_excited_state outfile_excited_state savename
qchem infile_ground_state outfile_ground_state savename
There are two $rem variables and one section $vibronic involved in vibronic spectra calculations.
SAVE_VIBRONIC_PARAMS
       Save information about excited state which is requested in vibronic spectra simulation.
VIBRONIC_SPECTRA
VIBRONIC_SPECTRA
       Specifies which type of vibronic spectra will be predicted. Should be used in a frequency job (jobtype = Freq).
       0 No vibronic spectra is predicted. 1 OPA spectra is calculated. 2 OPE spectra is calculated. 3 RRS spectra is calculated.
       Use the default.
Variables in the $vibronic section:
MODEL
       Specifies which kind of model will be used to simulate the vibronic spectra.
INPUT SECTION: $vibronic
       -1
       1 FC. 2 FCHT. 3 VG.
       User defined
TEMPERATURE
       Specifies the temperature in the vibronic spectra simulation.
       FLOAT
       298.15
       t temperature, in K.
       User defined
FREQ_RANGE
       Specifies the frequency range of vibronic spectra.
       FLOAT
       1.0 40000.0 10.0
       νmin⁢νmax⁢δ⁢ν minimum, maximum and step size, in cm-1.
       User defined
TIME_RANGE
       Specifies the step size and the number of steps in time domain propagation.
       FLOAT and INTEGER
       1.0 40000
       δ⁢t⁢nstep time step size in a.u., and the number of steps.
       User defined
DAMPING
       Specifies the damping factor.
       FLOAT
       300.0
       γ damping factor, in cm-1.
       User defined
FREQ_SCALE_FACTOR
       Specifies the frequency scale factors.
       FLOAT
       1.0 1.0 1.0 1.0
       λHg⁢λHe⁢λZPEg⁢λZPEe scale factor for ground state harmonic frequency, for excited state harmonic frequency, for ground state zero-point energy, and for excited state zero-point energy
       User defined
EPSILON
       Specifies the spectral broadening factor. It is available only for RRS spectra simulation.
       FLOAT
       25.0
       ε broadening factor, in cm-1.
       User defined
10.7.7.3 Vibronic Job Examples
Example 10.35  Input files for OPA spectra in the FCHT approximation of formaldehyde corresponding to the S0→S1 transition. In the first step, frequency analysis at the S1 equilibrium geometry. Then run a ground state frequency analysis on the S0 ground state optimized structure.
  O    -0.0367447359    -0.0007590817     0.6963163574
  C     0.1461299638     0.0026846285    -0.5839700302
  H    -0.0732270514     0.9340547891    -1.1138640182
  H    -0.0391581765    -0.9359803358    -1.1140167891
  JOBTYPE                freq
  METHOD                 b3lyp
  BASIS                  def2-TZVP
  CIS_STATE_DERIV        1
  CIS_SINGLETS           true
  CIS_TRIPLETS           false
  CIS_N_ROOTS            10
point_group_symmetry False
  SAVE_VIBRONIC_PARAMS   true ! enables saving information of S1 state
   O    0.0000000000     0.0000000000     0.6637077571
   C    0.0000000000     0.0000000000    -0.5351027012
   H    0.0000000000     0.9394749352    -1.1220697679
   H    0.0000000000    -0.9394749352    -1.1220697679
   JOBTYPE            freq
   METHOD             b3lyp
   BASIS              def2-TZVP
   VIBRONIC_SPECTRA   1 !enables vibronic_spectra and reads saved information
$vibronic
   model        2
   freq_range   20000. 60000. 10.
   time_range   1. 40000
   damping      40.
Example 10.36  Vibrationally resolved fluorescence, i.e., OPE with the first kind of FC model, is calculated as following. The emission from D1 to D0 of p-fluorobenzyl radical is used as an example. This is the first job of the total vibronic spectra simulation, by running the excited state geometry optimization retaining information in $QCSCRATCH/savename. Information from this job will be needed to complete the simulation in Example 10.7.7.3.
   C         1.4840482200    0.0000338155    0.0000000000
   C         0.7160497031    0.0000524901   -1.2119311870
   C        -0.7159596058    0.0000542629   -1.2126930961
   C        -1.4043236629    0.0000543088    0.0000000000
   C        -0.7159596058    0.0000542629    1.2126930961
   C         0.7160497031    0.0000524901    1.2119311870
   C         2.8748450131    0.0000120580    0.0000000000
   H         1.2370230923    0.0000896598   -2.1693859212
   H        -1.2717579173    0.0000412967   -2.1497435961
   H        -1.2717579173    0.0000412967    2.1497435961
   H         1.2370230923    0.0000896598    2.1693859212
   H         3.4346492051    0.0000003003   -0.9330758768
   H         3.4346492051    0.0000003003    0.9330758768
   F        -2.7508602624    0.0000394216    0.0000000000
   JOBTYPE                opt
   METHOD                 b3lyp
   BASIS                  def2-SVP
   CIS_STATE_DERIV        1
   CIS_N_ROOTS            10
   SAVE_VIBRONIC_PARAMS   true !saved into $QCSCRATCH/savename
Example 10.37  The final job for obtaining vibrationally resolved fluorescence of the D1 to D0 transition of p-fluorobenzyl radical using OPE with the first kind of FC model from Example 10.7.7.3.
   C       1.4578807306     0.0130092784     0.0000000000
   C       0.7102753558     0.0082793447    -1.2194714816
   C      -0.6772053823    -0.0007923729    -1.2210832164
   C      -1.3603507249    -0.0052928605     0.0000000000
   C      -0.6772053834    -0.0007923730     1.2210832170
   C       0.7102753546     0.0082793447     1.2194714789
   C       2.8669152234     0.0219746232     0.0000000000
   H       1.2502372081     0.0119050313    -2.1697312391
   H      -1.2498963812    -0.0045285858    -2.1510495277
   H      -1.2498963822    -0.0045285858     2.1510495285
   H       1.2502372136     0.0119050313     2.1697312323
   H       3.4299577819     0.0255536038    -0.9358170827
   H       3.4299577814     0.0255536038     0.9358170860
   F      -2.7010161586    -0.0142661666     0.0000000000
   JOBTYPE            freq
   METHOD             b3lyp
   BASIS              def2-SVP
   VIBRONIC_SPECTRA   2
$vibronic
   model        1
   temperature  0.
   freq_range   1. 40000. 10.
   time_range   1. 40000
   damping      20.
Example 10.38  RRS spectra of phenoxyl radical (D0→D3 transition) with the VG approximation. Therefore the first job calculates the D3 state force at the ground state optimized geometry, followed by the ground state frequency analysis. The excited state forces and ground state frequencies are calculated in the ground state equilibrium geometry.
   C       0.0000000000     1.2271514002    -1.0879472096
   C       0.0000000000     0.0000408897    -1.7873074655
   C       0.0000000000    -1.2270324440    -1.0880160727
   C       0.0000000000    -1.2409681161     0.2924435676
   C       0.0000000000    -0.0000313560     1.0551142042
   C       0.0000000000     1.2409428316     0.2924458686
   H       0.0000000000     2.1656442172    -1.6487551860
   H       0.0000000000    -0.0001767539    -2.8803293768
   H       0.0000000000    -2.1655968771    -1.6487220344
   H       0.0000000000    -2.1715667156     0.8648121894
   H       0.0000000000     2.1714692701     0.8649813475
   O       0.0000000000     0.0001236541     2.3063351676
   JOBTYPE                force
   METHOD                 b3lyp
   BASIS                  def2-SVP
   CIS_STATE_DERIV        3
   CIS_N_ROOTS            10
   read !VG approximation uses the same geometry for ground and excited state
   JOBTYPE            freq
   METHOD             b3lyp
   BASIS              def2-SVP
   VIBRONIC_SPECTRA   3
$vibronic
   MODEL         3
   TEMPERATURE   0.
   FREQ_RANGE    1. 4000. 1.
   TIME_RANGE    1. 40000
   DAMPING       100.
   EPSILON       25.
