4.9.5 Non-Hermitian SCF with complex basis functions
Metastable electronic states can be characterized by a complex Siegert energy,
E=Er-i⁢Γ/2, (4.69)
where the width, Γ, is proportional to the inverse lifetime of the state: Γ=ℏ/τ. Complex coordinate methods aim to compute this complex energy as an eigenvalue of an effective non-Hermitian Hamiltonian. One such method is the method of complex basis functions (CBFs) where a basis of Gaussians with complex exponents is used in conjunction with a symmetric (not complex-conjugated) inner product to effictively produce a finite-basis representation of a non-Hermitian operators. 872 McCurdy C. W., Recigno T. N.
Phys. Rev. A
(1978), 41, pp. 1364.
, 1354 White A. F., Head-Gordon M., McCurdy C. W.
(2015), 142, pp. 054103.
, 1355 White A. F., McCurdy C. W., Head-Gordon M.
(2015), 143, pp. 074103.
, 1353 White A. F. et al.
(2017), 146, pp. 234107.
In cases, such as temporary anions, where the decay channel is of 1-electron character, a mean-field theory can provide approximate Siegert energies for a many-electron system.
The simplest such approximation is the static-exchange approximation. In this approximation the Siegert energies of an (N+1)-electron state are computed by diagonalizing a Fock operator computed from the density of an N-electron state. 1354 White A. F., Head-Gordon M., McCurdy C. W.
This approximation neglects orbital relaxation effects which can be included by a non-Hermitian self-consistent-field (NH-SCF) procedure. 872 McCurdy C. W., Recigno T. N.
Phys. Rev. A
In practice the NH-SCF energy functional is the same as the Holomorphic Hartree-Fock energy functional (Eq. 4.65), though it is used for a different purpose. Both static-exchange and NH-SCF theories using complex basis functions (CBFs) are available in Q-Chem. Specification of the complex basis set is described in Section 8.7.
COMPLEX_EXPONENTS
COMPLEX_EXPONENTS
       Enable a non-Hermitian calculation with CBFs.
       TRUE Perform a non-Hermitian calculation with CBFs
       Set to TRUE if a non-Hermitian calculation using CBFs is desired.
COMPLEX_SPIN_STATE
COMPLEX_SPIN_STATE
       Spin state for non-Hermitian calculation
       1 Singlet
       2⁢S+1 A state of spin S
COMPLEX_N_ELECTRON
COMPLEX_N_ELECTRON
       Add electrons for non-Hermitian calculation.
       0 Perform the non-Hermitian calculation on N-electrons
       n Perform the non-Hermitian calculation on an N+n electron system
COMPLEX_STATIC_EXCHANGE
       Perform a CBF static-exchange calculation.
       TRUE Perform a static exchange calculation FALSE Do not perform a static exchange calculation
       Set to TRUE if a static-exchange calculation is desired.
COMPLEX_SCF
COMPLEX_SCF
       Perform a non-Hermitian SCF calculation with CBFs
       0 Do not perform an NH-SCF calculation 1 Perform a restricted NH-SCF calculation 2 Perform an unrestricted NH-SCF calculation 3 Perform a restricted, open-shell NH-SCF calculation
COMPLEX_METSCF
COMPLEX_METSCF
       Specify the NH-SCF solver
       0 Roothaan iterations 1 DIIS 3 ADIIS 21 Newton-MINRES
       Use the default (DIIS).
COMPLEX_SCF_GUESS
COMPLEX_SCF_GUESS
       Specify the NH-SCF guess
       0 Use a guess from a static-exchange calculation 1 Read real-basis MO coefficients 2 Read real-basis density matrix 1000 Read guess from a previous calculation
       Use a guess from a static exchange calculation. Note that for temporary anions, this requires the specification of COMPLEX_TARGET.
COMPLEX_TARGET
COMPLEX_TARGET
       Specify the orbital index to be occupied for a temporary anion
       n Orbital index (starting at zero) for the additional electron
       n should always be greater than Nocc-1.
