4.6.8 occ-RI-K Exchange Algorithm
The occupied orbital RI-K (occ-RI-K) algorithm 834 Manzer S. et al.
(2015), 143, pp. 024113.
is a new scheme for building the exchange matrix (K) partially in the MO basis using the RI approximation. occ-RI-K typically matches current alternatives in terms of both the accuracy (energetics identical to standard RI-K) and convergence (essentially unchanged relative to conventional methods). On the other hand, this algorithm exhibits significant speedups over conventional integral evaluation (14x) and standard RI-K (3.3x) for a test system, a graphene fragment (C68H22) using cc-pVQZ basis set (4400 basis functions), whereas the speedup increases with the size of the AO basis set. Thus occ-RI-K helps to make larger basis set hybrid DFT calculations more feasible, which is quite desirable for achieving improved accuracy in DFT calculations with modern functionals.
The idea of the occ-RI-K formalism comes from a simple observation that the exchange energy EK and its gradient can be evaluated from the diagonal elements of the exchange matrix in the occupied-occupied block Ki⁢i, and occupied-virtual block Ki⁢a, respectively, rather than the full matrix in the AO representation, Kμ⁢ν. Mathematically,
EK = -∑μ⁢νPμ⁢ν⁢Kμ⁢ν (4.53)
= -∑μ⁢νcμ⁢i⁢Kμ⁢ν⁢cν⁢i
= -∑iKi⁢i
and
∂⁡EK∂⁡Δa⁢i=2⁢Ka⁢i (4.54)
where Δ is a skew-symmetric matrix used to parameterize the unitary transformation U, which represents the variations of the MO coefficients as follows:
U=e(Δ-ΔT). (4.55)
From Eq. 4.53 and 4.54 it is evident that the exchange energy and gradient need just Ki⁢ν rather than Kμ⁢ν.
In regular RI-K one has to compute two quartic terms, 1340 Weigend F.
(2002), 4, pp. 4285.
whereas there are three quartic terms for the occ-RI-K algorithm. The speedup of the latter with respect to former can be explained from the following ratio of operations; refer to Ref.  834 Manzer S. et al.
for details.
# of RI-K quartic operations# of occ-RI-K quartic operations=o⁢N⁢X2+o⁢N2⁢Xo2⁢X2+o2⁢N⁢X+o2⁢N⁢X=N⁢(X+N)o⁢(X+2⁢N) (4.56)
With a conservative approximation of X≈2⁢N, the speedup is 34⁢(N/o). The occ-RI-K algorithm also involves some cubic steps which should be negligible in the very large molecule limit. Tests in the Ref.  834 Manzer S. et al.
suggest that occ-RI-K for small systems with large basis will gain less speed than a large system with small basis, because the cubic terms will be more dominant for the former than the latter case.
In the course of SCF iteration, the occ-RI-K method does not require us to construct the exact Fock matrix explicitly. Rather, ki⁢ν contributes to the Fock matrix in the mixed MO and AO representations (Fi⁢ν) and yields orbital gradient and DIIS error vectors for converging SCF. On the other hand, since occ-RI-K does not provide exactly the same unoccupied eigenvalues, the diagonalization updates can differ from the conventional SCF procedure. In Ref.  834 Manzer S. et al.
, occ-RI-K was found to require, on average, the same number of SCF iterations to converge and to yield accurate energies.
The occ-RI-K can be invoked by either setting OCC_RI_K to be true, or (since Q-Chem 5.2) specifying auxiliary basis set for K using AUX_BASIS_K.
OCC_RI_K
OCC_RI_K
       Controls the use of the occ-RI-K approximation for constructing the exchange matrix
       False Do not use occ-RI-K.
       True Use occ-RI-K.
       Larger the system, better the performance
4.6.8.1 occ-RI-K for exchange energy gradient evaluation
A very attractive feature of occ-RI-K framework is that one can compute the exchange energy gradient with respect to nuclear coordinates with the same leading quartic-scaling operations as the energy calculation.
The occ-RI-K formulation yields the following formula for the gradient of exchange energy in global Coulomb-metric RI:
EKx = (i⁢j|i⁢j)x (4.57)
= ∑μ⁢ν⁢P∑i⁢jcμ⁢i⁢cν⁢j⁢Ci⁢jP⁢(μ⁢ν|P)x-∑R⁢S∑i⁢jCi⁢jR⁢Ci⁢jS⁢(R|S)x.
The superscript x represents the derivative with respect to a nuclear coordinate. Note that the derivatives of the MO coefficients cμ⁢i are not included here, because they are already included in the total energy derivative calculation by Q-Chem via the derivative of the overlap matrix.
In Eq. 4.57, the construction of the density fitting coefficients (Cμ⁢νP) has the worst scaling of 𝒪⁢(M4) because it involves MO to AO back transformations:
Cμ⁢νP=∑i⁢jcμ⁢i⁢cν⁢j⁢Ci⁢jP (4.58)
where the operation cost is o2⁢N⁢X+o⁢[NB2]⁢X.
RI_K_GRAD
RI_K_GRAD
       Turn on the nuclear gradient calculations
       FALSE Do not invoke occ-RI-K based gradient
       TRUE Use occ-RI-K based gradient
       Use "RI_J false"
Example 4.21  Q-Chem input for a energy and gradient calculations with occ-RI-K method.
   C    0.0000000    0.3057430    5.7138876
   C    0.0000000   -0.5442831    4.4256275
   C    0.0000000    0.3675825    3.1787857
   C    0.0000000   -0.4853210    1.8908707
   C    0.0000000    0.4264823    0.6439435
   C    0.0000000   -0.4264823   -0.6439435
   C    0.0000000    0.4853210   -1.8908707
   C    0.0000000   -0.3675825   -3.1787857
   C    0.0000000    0.5442831   -4.4256275
   C    0.0000000   -0.3057430   -5.7138876
   H    0.8973039    0.9418895    5.7433715
   H   -0.8973039    0.9418895    5.7433715
   H   -0.8965960   -1.1827891    4.4155828
   H    0.8965960   -1.1827891    4.4155828
   H    0.8966512    1.0057416    3.1940146
   H   -0.8966512    1.0057416    3.1940146
   H   -0.8966512   -1.1234851    1.8761493
   H    0.8966512   -1.1234851    1.8761493
   H    0.8966507    1.0646443    0.6587590
   H   -0.8966507    1.0646443    0.6587590
   H   -0.8966507   -1.0646443   -0.6587590
   H    0.8966507   -1.0646443   -0.6587590
   H    0.8966512    1.1234851   -1.8761493
   H   -0.8966512    1.1234851   -1.8761493
   H   -0.8966512   -1.0057416   -3.1940146
   H    0.8966512   -1.0057416   -3.1940146
   H    0.8965960    1.1827891   -4.4155828
   H   -0.8965960    1.1827891   -4.4155828
   H    0.8973039   -0.9418895   -5.7433715
   H    0.0000000    0.3580832   -6.5913113
   H   -0.8973039   -0.9418895   -5.7433715
   H    0.0000000   -0.3580832    6.5913113
   JOBTYPE         force
   EXCHANGE        HF
   BASIS           cc-pVTZ
   AUX_BASIS       cc-pVTZ-JK
   OCC_RI_K        1
   RI_K_GRAD       1
   INCFOCK         0
   PURECART        1111
