6.20 Incremental Correlation Methods
6.20.2 Theory
Electronic energy is retrieved by iFCI using an n-body expansion of the form
E=Eref+EC=Eref+∑iϵi+∑j<iϵi⁢j+∑k<j<iϵi⁢j⁢k+⋯ (6.76)
where each ϵX term denotes an increment of correlation energy and i,j,k refer to bodies of the expansion. Incremental correlation energies are defined as
ϵi = EC⁢(i) (6.77)
ϵi⁢j = EC⁢(i⁢j)-ϵi-ϵj (6.78)
ϵi⁢j⁢k = EC⁢(i⁢j⁢k)-ϵi⁢j-ϵi⁢k-ϵj⁢k-ϵi-ϵj-ϵk (6.79)
where terms n>1 subtract lower-order increments to avoid double counting. Terms represent n-body additions to the correlation energy from 2⁢n electrons in the mean field of the remaining 2⁢(N-n) electrons, where each ϵX value is computed by solving CAS-CI for 2⁢n electrons in Nv+n orbitals. For example, n=1 performs CAS(2,Nv+1)-CI to give the value of EC⁢(i)=E⁢(CAS⁢(2,Nv+1)). Proceeding likewise for higher n, CAS(2⁢n,Nv+n)-CI produces each EC⁢(X).
Heat-bath CI (HBCI) is utilized to solve each CAS-CI Hamiltonian, performing selected CI computations according to determinants, j, coupled to the CI wave function in the form |Hi⁢j⁢ci|>εi, where εi is the energy cutoff and ci are determinants in the HBCI subspace.
Truncation of incremental terms is performed by considering natural orbital (NO) occupancy cutoffs, η(m), where
ϵi(m) = EC⁢(i;η(m)) (6.80)
ϵi⁢j(m) = EC⁢(i⁢j;η(m))-ϵi(m)-ϵj(m) (6.81)
Doing so reduces the size of the virtual space by only including virtual orbitals with sufficiently large NO eigenvalues. Convergence for each iFCI increment is reached when
ζ>|ϵ(m+1)-ϵm| (6.82)
with units of 10-ζ Eh. Further truncation in n≥3 can be performed by utilizing the ζ parameter and a screening cutoff, 𝒞n, in the form
𝒞n=10-ζ×𝒮n (6.83)
where 𝒞n is in Eh and 𝒮n is a scalar. This screening is performed by selecting n-1 body correlation energy contributions that are above 𝒞n. See Ref.  1073 Rask A. E., Zimmerman P. M.
(2021), 125, pp. 1598.
for more details. 𝒮n is a parameter in the input.
iFCI requires a high-spin perfect pairing (PP) reference, where NOs are localized as local bonding-antibonding pairs, or geminals.
