10.2 Wave Function Analysis
10.2.11 General Excited-State Analysis
Q-Chem features a module for extended excited-state analysis via the wavefunction analysis library libwfa. 1021 Plasser F., Krylov A. I., Dreuw A.
(2022), 12, pp. e1595.
libwfa is interfaced to the ADC, CC/EOM-CC, CIS, and TDDFT/SF-TDDFT methods. These analyses are based on the state, transition and difference density matrices of the excited states. The theoretical background for such analysis is given in Chapter 7.14. A more extended discussion of different analysis methods and classification schemes for excited states is given in Ref.  .
Descriptor Explanation
Leading SVs Largest NTO occupation numbers
Sum of SVs (Omega) Ω=∥𝜸IF∥2, sum of NTO occupation numbers
E(h) Energy of hole NTO, EI⁢(h)=∑p⁢qαp⁢I⁢Fp⁢q⁢αq⁢I
E(p) Energy of particle NTO, EI⁢(p)=∑p⁢qβp⁢I⁢Fp⁢q⁢βq⁢I
PR_NTO NTO participation ratio PRNTO
Entanglement entropy (S_HE) SH|E=-∑iλi⁢log2⁡λi
Nr of entangled states (Z_HE) ZH⁢E=2SH|E
Renormalized S_HE/Z_HE Replace λi→λi/Ω in the above two formulas
<Phe> Expec. value of the particle-hole permutation operator,
measuring de-excitations 649 Kimber P., Plasser F.
(2020), 22, pp. 6058.
<r_h> [Ang] Mean position of hole ⟨x→h⟩exc
<r_e> [Ang] Mean position of electron ⟨x→e⟩exc
|<r_e - r_h>| [Ang] Linear e/h distance d→h→e=⟨x→e-x→h⟩exc
Hole size [Ang] RMS hole size: σh=(⟨x→h 2⟩exc-⟨x→h⟩exc2)1/2
Electron size [Ang] RMS elec. size: σe=(⟨x→e 2⟩exc-⟨x→e⟩exc2)1/2
RMS electron-hole separation [Ang] dexc=(⟨|x→e-x→h|2⟩exc)1/2
Covariance(r_h, r_e) [Ang^2] COV⁢(x→h,x→e)=⟨x→h⋅x→e⟩exc-⟨x→h⟩exc⋅⟨x→e⟩exc
Correlation coefficient Re⁢h=COV⁢(x→h,x→e)/σh⋅σe
Center-of-mass size 0.5*(⟨|x→e+x→h|2⟩exc-⟨x→e+x→h⟩exc2)1/2
Table 10.1: Descriptors output by Q-Chem for transition density matrix analysis. Note that squares of the SVs, which correspond to the weights of the respective NTO pairs, are printed. Ω equals the square of the norm of the one-electron transition density matrix (1TDM).
One-electron transition-density matrix (1TDM) based analyses include the construction and export of natural transition orbitals 855 Martin R. L.
(2003), 118, pp. 4775.
(NTOs) and electron and hole densities, 1024 Plasser F., Wormit M., Dreuw A.
(2014), 141, pp. 024106.
the evaluation of charge transfer numbers, 1022 Plasser F., Lischka H.
(2012), 8, pp. 2777.
an analysis of exciton multipole moments, 67 Bäppler S. A. et al.
Phys. Rev. A
(2014), 90, pp. 052521.
, 1023 Plasser F. et al.
(2015), 36, pp. 1609.
, 881 Mewes S. A., Plasser F., Dreuw A.
(2015), 143, pp. 171101.
and quantification of electron-hole entanglement. 1025 Plasser F.
(2016), 144, pp. 194107.
NTOs are obtained by singular value decomposition (SVD) of the 1TDM:
γp⁢qIF =⟨ΨI|p†⁢q|ΨF⟩ (10.31)
𝜸 =𝜶⁢𝝈⁢𝜷†, (10.32)
where 𝝈 is diagonal matrix containing singular values and unitary matrices 𝜶 and 𝜷 contain the respective particle and hole NTOs. Note that:
∥𝜸∥2=∑p⁢qγp⁢q2=∑KσK2≡Ω (10.33)
Furthermore, the formation and export of state-averaged NTOs, and the decomposition of the excited states into transitions of state-averaged NTOs are implemented. 1024 Plasser F., Wormit M., Dreuw A.
The difference and/or state densities can be exported themselves, as well as employed to construct and export natural orbitals, natural difference orbitals, and attachment and detachment densities. 532 Herbert J. M.
(2024), 26, pp. 3755.
Furthermore, two measures of unpaired electrons are computed. 507 Head-Gordon M.
(2003), 372, pp. 508.
In addition, a Mulliken or Löwdin population analysis and an exciton analysis can be performed based on the difference/state densities. The main descriptors of the various analyses that are printed for each excited state are given in Tables 10.1 and 10.2. For a detailed description with illustrative examples, see Refs.  1020 Plasser F. et al.
(2014), 141, pp. 024107.
, and 1021 Plasser F., Krylov A. I., Dreuw A.
n_u Number of unpaired electrons nu=∑imin⁢(ni,2-ni)
n_u,nl Number of unpaired electrons nu,n⁢l=∑ini2⁢(2-ni)2
PR_NO NO participation ratio PRNO
p_D and p_A Promotion number pD and pA
PR_D and PR_A D/A participation ratio PRD and PRA
<r_h> [Ang] Mean position of detachment density d→D
<r_e> [Ang] Mean position of attachment density d→A
|<r_e - r_h>| [Ang] Linear D/A distance d→D→A=d→A-d→D
Hole size [Ang] RMS size of detachment density σD
Electron size [Ang] RMS size of attachment density σA
Table 10.2: Descriptors output by Q-Chem for difference/state density matrix analysis.
libwfa also computes descriptors for differentiating between diradical and ionic excited states, as defined within valence-bond theory. These descriptors, denoted LOC, LOCa, QT, and QTa, are zero for perfect diradical states and increase with the ionic character of the state. 319 do Monte S. A. et al.
(2023), 127, pp. 9842.
To activate any excited-state analysis STATE_ANALYSIS has to be set to TRUE. For individual analyses there is currently only a limited amount of fine grained control. The construction and export of any type of orbitals is controlled by MOLDEN_FORMAT to export the orbitals as MolDen files, and NTO_PAIRS which specifies the number of important orbitals to print (note that the same keyword controls the number of natural orbitals, the number of natural difference orbitals, and the number of NTOs to be printed). Setting MAKE_CUBE_FILES to TRUE triggers the construction and export of densities in “cube file” format , which requires the specification of the $plots section in either old or new format (see Sections 10.5.4 and 10.5.5 for details). Setting IQMOL_FCHK = TRUE (equivalently, GUI = 2) will export data to the “.fchk” formatted checkpoint file, and switches off the generation of cube files. The population analyses are controlled by POP_MULLIKEN and LOWDIN_POPULATION. Setting the latter to TRUE will enforce Löwdin population analysis to be employed for regular populations as well as CT numbers, while by default the Mulliken population analysis is used.
Any MolDen or cube files generated by the excited state analyses can be found in the directory plots in the job’s scratch directory. Their names always start with a unique identifier of the excited state (the exact form of this human readable identifier varies with the excited state method). The names of MolDen files are then followed by either _no.mo, _ndo.mo, or _nto.mo depending on the type of orbitals they contain. In case of cube files the state identifier is followed by _dens, _diff, _trans, _attach, _detach, _elec, or _hole for state, difference, transition, attachment, detachment, electron, or hole densities, respectively. All cube files have the suffix .cube. In unrestricted calculations an additional part is added to the file name before .cube which indicates α (_a) or β (_b) spin. The only exception is the state density for which _tot or _sd are added indicating the total or spin-density parts of the state density. Analysis of relaxed CIS or TDDFT densities can be triggered by CIS_RELAXED_DENSITY = TRUE. The corresponding output files are marked by _rlx. Computation of ESPs for state, transition, and electron/hole densities (see Ref.  649 Kimber P., Plasser F.
) can be triggered by setting ESP_GRID = -3. These are indicated by _esp as part of the file name.
The ctnum_*.om file created in the main directory serves as input for a charge transfer number analysis, as explained, e.g., in Refs.  1022 Plasser F., Lischka H.
, 880 Mewes S. A. et al.
(2016), 18, pp. 2548.
. Use the external TheoDORE program (theodore-qc.sourceforge.net) to create electron/hole correlation plots and to compute fragment based descriptors.
Note:  • When doing excited-state calculations from an open-shell reference, libwfa will perform the analysis for both α⁢α and β⁢β transition densities. Make sure you look at the correct one. The way to figure it out is to remember that in open-shell references Nα>Nβ, e.g., in doublet references, the unpaired electron is α and the hole is β. Thus, for transitions of the unpaired electron into the unoccupied orbitals you need α⁢α block, whereas for the transitions from doubly occupied orbitals into the singly unoccupied orbital (the hole) you need the β⁢β block. • To activate all types of analyses in CCMAN2 jobs, you have to activate CC_REF_PROP, CC_EOM_PROP, and CC_TRANS_PROP. This is shown in Example 7.10.29. • In Hermitian formalisms, γIF is a Hermitian conjugate of γFI, but in non-Hermitian approaches, such as coupled-cluster theory, the two are slightly different. While for quantitative interstate properties both γIF and γFI are computed, the qualitative trends in exciton properties derived from (γIF)† and γFI are very similar. Only one 1TDM is analyzed for EOM-CC. • In spin-restricted calculations, the libwfa module computes NTOs for the α⁢α block of transition density. Thus, when computing NTOs for the transitions between open-shell EOM-IP/EA states make sure to specify correct spin states. For example, use EOM_EA_ALPHA to visualize transitions involving the extra electron.
STATE_ANALYSIS
STATE_ANALYSIS
       Triggers the general state analysis via libwfa.
       FALSE Do not run excited state analysis. TRUE Activate excited state analysis.
       This analysis produces only minimal computational overhead (as long as no cube files are produced) and can be activated whenever some additional information about the excited state is required.
WFA_LEVEL
WFA_LEVEL
       Master variable for controlling the amount of output produced by libwfa.
       3
       1 Only perform some population analyses. 2 Also perform exciton analysis and compute natural (transition/difference) orbitals. 3 Also perform charge transfer number analysis. 4 Maximal output including cube files for NTOs (this is needed to reproduce Ref.  649 Kimber P., Plasser F.
       Reduce if you want less print-out.
NTO_PAIRS
NTO_PAIRS
       Controls how many hole/particle NTO pairs and frontier natural orbital pairs and natural difference orbital pairs are printed in the standard output.
       N Write N NTO/NO/NDO pairs per excited state.
       This controls the print-out to the standard output. Use WFA_ORB_THRESH if you want to modify the number of orbitals exported.
WFA_ORB_THRESH
WFA_ORB_THRESH
       Controls the number of hole/particle NTO pairs and frontier natural orbital pairs and natural difference orbital pairs exported to the Molden files.
       3
       N Export all NTO/NO/NDO pairs with a weight above 10-N.
WFA_REF_STATE
WFA_REF_STATE
       Controls the reference state for the transition and difference density matrices used by libwfa. This keyword works for CIS/TDDFT/SF-DTDDFT computations. Use CC_STATE_TO_OPT for EOM-CC.
       -1
       -1 Use default: ground-state for standard CIS/TDDFT computations, first response state for SF-TDDFT. 0 Reference state N Nth excited state/response state.
Example 10.6  Basic excited-state analysis example for formaldehyde at the ADC(2)/def2-SV(P) level: computation of various descriptors and output of NOs, NTOs, and NDOs in MolDen format. libwfa used in this basic mode does usually not add notable computational cost.
   C     0.000000   0.000000    0.523383
   O    -0.000000   0.000000   -0.671856
   H     0.931138   0.000000    1.11728
   H    -0.931138   0.000000    1.11728
   METHOD           adc(2)
   BASIS            def2-sv(p)
   N_FROZEN_CORE    fc
   EE_SINGLETS      [0,1,1,0]
   STATE_ANALYSIS   true
   MOLDEN_FORMAT    true
Example 10.7  Analysis of two TDDFT excited states of formaldehyde using libwfa including output of cube files. This uses the new $plots format (see Section 10.5.4.1) with grid points specified. The cubes files of HOMO and LUMO will also be generated.
  C    0.0000000   -0.0000000   -0.6133791
  O   -0.0000000    0.0000000    0.6060734
  H    0.0000000    0.9391300   -1.1555819
  H    0.0000000   -0.9391300   -1.1555819
   METHOD           PBE0
   BASIS            6-31+G(d)
   CIS_N_ROOTS      2
   CIS_TRIPLETS     false
   MAKE_CUBE_FILES  true
   PLOTS            true
   STATE_ANALYSIS   true
$plots
   grid_points                    50 50 50
   alpha_molecular_orbital        8-9
Note:  For the output of orbitals and densities it is possible to use either the MOLDEN_FORMAT = TRUE (see Example 10.2.11), MAKE_CUBE_FILES = TRUE (see Example 10.2.11), or GUI = 2 options. These options are mutually exclusive when STATE_ANALYSIS is activated.
Example 10.8  Uracil computed at the PBE0/def2-SV(P) level. Activation of extended libwfa functionality including export of NTOs and densities in cube format and computation of the ESPs of these densities. This extended libwfa mode can add significant computational cost, especially if a fine grid is chosen.
   C    1.194380    1.102510    0.000000
   C   -0.008366    1.692430    0.000000
   N   -1.169600    0.978035    0.000000
   C   -1.212060   -0.402293    0.000000
   N    0.034691   -0.979140    0.000000
   C    1.281590   -0.348737    0.000000
   O   -2.243420   -1.023750    0.000000
   O    2.299180   -0.995854    0.000000
   H   -0.123160    2.767140    0.000000
   H   -2.061440    1.444100    0.000000
   H    0.044818   -1.989990    0.000000
   H    2.104720    1.679840    0.000000
   METHOD            pbe0
   BASIS             def2-sv(p)
   CIS_N_ROOTS       4
   CIS_SINGLETS      true
   CIS_TRIPLETS      true
   RPA               false
   STATE_ANALYSIS    true
   NTO_PAIRS         3
   ESP_GRID          -3
   WFA_LEVEL         4
   WFA_ORB_THRESH    3
$plots
Write cube files for all 4 states
35  -3.5  3.5
35  -3.5  3.5
15  -1.5  1.5
0  4  0  0
1 2 3 4
Other examples of libwfa uses:
    Example 7.3.8 illustrates wave-function analysis of the SF-DFT states in para-benzyne;
    Example 7.10.8.2 illustrates wave-function analysis of XAS transitions within CVS-EOM-EE;
    Example 7.10.29 illustrates wave-function analysis for transitions between EOM-IP states;
    Example 7.10.18 illustrates wave-function analysis of complex-valued densities within CAP-EOM-CCSD.
