11.2 Chemical Solvent Models
11.2.2 Kirkwood-Onsager Multipole Expansion Method
The simplest implicit solvation model available in Q-Chem is the multipolar expansion model, 653 Kirkwood J. G.
(1934), 2, pp. 767.
, 887 Mikkelsen K. V. et al.
(1988), 89, pp. 3086.
, 529 Herbert J. M.
(2021), 11, pp. e1519.
which has also been called the Kirkwood-Onsager model or sometimes the generalized Kirkwood model. 529 Herbert J. M.
In this approach, the solute is placed inside of a spherical cavity of radius a that is surrounded by a homogeneous dielectric medium whose dielectric constant is ε, and these constitute the only parameters of the model. The term Onsager model is sometimes synonymous with a point-dipole approximation for the solute’s charge density, but Q-Chem’s version uses a single-center multipole expansion of the density (which can be extended to arbitrarily high order), in order to obtain an essentially exact description of the solute’s electrostatic potential. The model then consists of using Kirkwood’s analytic expressions for the solvation energy of each spherical harmonic function, in a spherical cavity inside of a dielectric continuum. 529 Herbert J. M.
Regarding the cavity radius a, Onsager’s original suggestion is based on the molar volume Vm of the pure solute,
a=(3⁢Vm/4⁢π⁢NA)1/3 (11.1)
where NA is Avogadro’s constant. This was later shown to be a poor choice in the context of modern quantum chemistry calculations. 529 Herbert J. M.
It is also common to add 0.5 Å to the value of a in Eq. (11.1) in order to account for the first solvation shell, 1386 Wong M. W., Frisch M. J., Wiberg K. B.
J. Am. Chem. Soc.
(1991), 113, pp. 4776.
or to set a equal to the maximum distance between the solute center of mass and the solute atoms, plus the relevant van der Waals radii. A third option is to set 2⁢a (the cavity diameter) equal to the largest solute–solvent internuclear distance, plus the van der Waals radii of the relevant atoms. Clearly, there is quite a bit of arbitrariness in this choice and solvation energies are quite sensitive to the value of a, 529 Herbert J. M.
and the PCMs that are described in Section 11.2.3 have largely made the multipolar expansion method obsolete, since the PCMs employ the exact electron density and can be used (if desired) with a spherical cavity, although the more typical choice is a molecule-shaped van der Waals cavity.
The Kirkwood-Onsager SCRF is requested by setting SOLVENT_METHOD = KIRKWOOD in the $rem section. Some additional options can be specified in the $solvent section, as described below, of which only CavityRadius is required. Energies and analytic gradients for the Kirkwood-Onsager solvent model are available for Hartree-Fock, DFT, and CCSD calculations. It is often advisable to perform a gas-phase calculation of the solute molecule first, which can serve as the initial guess for a subsequent Kirkwood-Onsager implicit solvent calculation. For coupled-cluster calculations using this model, one may set CC_SAVEAMPL = TRUE to retain the CC amplitudes from the gas-phase calculation, which will save some time in the subsequent solution-phase calculation.
Note:  For CCSD calculations the Kirkwood-Onsager model works only with CCMAN2 = FALSE.
The following job-control options belong in the $solvent section, not the $rem section. As with other parts of the Q-Chem input file, this input section is not case-sensitive.
CavityRadius
       Sets the radius of the spherical solute cavity.
INPUT SECTION: $solvent
       FLOAT
       No default.
       a Cavity radius in Å.
Dielectric
       Sets the dielectric constant of the solvent continuum.
       FLOAT
       78.39
       ε Use a (dimensionless) value of ε.
       The default value corresponds to water at 25∘C.
MultipoleOrder
       Determines the order to which the multipole expansion of the solute charge density is carried out.
       15
       ℓ Include up to ℓth order multipoles.
       Use the default. The multipole expansion is usually converged by order ℓ = 15.
Example 11.1  Multipole expansion model at the Hartree-Fock level; H2O in acetonitrile
   O       0.00000000     0.00000000     0.11722303
   H      -0.75908339     0.00000000    -0.46889211
   H       0.75908339     0.00000000    -0.46889211
   METHOD            HF
   BASIS             6-31g**
   SOLVENT_METHOD    Kirkwood
$solvent
   CavityRadius      1.8    !   1.8 Angstrom Solute Radius
   Dielectric        35.9   !   Acetonitrile
   MultipoleOrder    15     !   this is the default value
Example 11.2  Kirkwood-Onsager SCRF applied to hydrogen fluoride in water, performing a gas-phase calculation first.
   H       0.000000     0.000000    -0.862674
   F       0.000000     0.000000     0.043813
   METHOD          HF
   BASIS           6-31G*
   JOBTYPE           FORCE
   METHOD            HF
   BASIS             6-31G*
   SOLVENT_METHOD    KIRKWOOD
   SCF_GUESS         READ  ! read vacuum solution as a guess
$solvent
   CavityRadius    2.5
