10.7 Harmonic Vibrational Analysis
10.7.3 Treatment of Low-Frequency Vibrational Modes
Low-frequency vibrational modes usually emerge due to hindered or near-free rotations around a single bond within a molecule. The harmonic approximation is problematic for such internal rotations and yields an infinite vibrational entropy Svib in the limit of vanishing frequencies. To fix this issue, Grimme 460 Grimme S.
Chem. Eur. J
(2012), 18, pp. 9955.
proposed to enforce a finite vibrational entropy by interpolating between the entropy of the free rotor SFR and the harmonic vibrational entropy SHO as
Svib⁢(νi)=(1-ω⁢(νi))⁢SFR⁢(νi)+ω⁢(νi)⁢SHO⁢(νi), (10.42)
where
ω⁢(νi)=11+(ν0/νi)α (10.43)
is the damping function of Chai and Head-Gordon, 207 Chai J.-D., Head-Gordon M.
(2008), 10, pp. 6615.
with α and ν0 as fixed parameters. It is used as a weighting function and allows for a smooth transition from the free rotor entropy at small frequencies to the harmonic vibrational entropy for frequencies νi above the cutoff ν0. This was later extended to interpolate the vibrational enthalpy contributions between a free rotor HFR and a harmonic oscillator HHO with zero-point vibrational energy HZPVE, as 776 Li Y.-P. et al.
J. Phys. Chem. C
(2015), 119, pp. 1840.
Hvib⁢(νi)=[1-ω⁢(νi)]⁢HFR⁢(νi)+ω⁢(νi)⁢[HHO⁢(νi)+HZPVE⁢(νi)]. (10.44)
This again reduces the error associated with treating translational and rotational degrees of freedom as low-frequency vibrations, which is especially important for the adsorption or association of larger molecules. This procedure is known as the quasi-rigid-rotor-harmonic-oscillator (qRRHO) approach.
The qRRHO scheme is the default in Q-Chem, and all thermodynamic quantities are printed for the RRHO (without interpolations) and qRRHO schemes at standard temperature and pressure (298.15 K and 1.00 atm). To change the latter, the user can specify an $isotopes section (see examples and Section 10.7.2 for details). α and ω0 for both interpolator functions can be modified through QRRHO_ALPHA and QRRHO_OMEGA_CUTOFF respectively.
QRRHO_ALPHA
QRRHO_ALPHA
       Specifies the exponent in the damping function of Chai and Head-Gordon, used for interpolating the vibrational enthalpy and entropy in the qRRHO scheme. Specify MRRHO_ALPHA to change the exponent for the entropy interpolation separately.
       4
       α Dimensionless interpolator exponent used in the qRRHO scheme.
       Use the default.
QRRHO_OMEGA_CUTOFF
QRRHO_OMEGA_CUTOFF
       Sets the frequency cutoff in the Chai-Head-Gordon damping function for interpolating the vibrational enthalpy and entropy in the qRRHO scheme. Specify MRRHO_OMEGA_CUTOFF to change the frequency cutoff for the entropy interpolation separately.
       100
       ω0 Interpolator cutoff frequency used in the qRRHO scheme in cm-1.
       Use the default.
Example 10.31  Harmonic vibrational analysis at the HF/3-21G level of theory, where the thermodynamic properties for RRHO and qRRHO are printed at 298.15 K and 1.00 atm.
C     1.682185104800      0.240320237000      0.000000000000
O     0.894276382600      1.089998584000      0.000000000000
O     2.480949717100     -0.590833069200      0.000000000000
C    -1.682185094800     -0.240320333400      0.000000000000
O    -0.894276273900     -1.089998812500      0.000000000000
O    -2.480949835800      0.590833394100      0.000000000000
JOBTYPE         opt
METHOD          hf
BASIS           3-21G
INTEGRAL_SYMMETRY    false
POINT_GROUP_SYMMETRY false
JOBTYPE         freq
METHOD          hf
BASIS           3-21G
Example 10.32  Harmonic vibrational analysis at the HF/3-21G level of theory, where the thermodynamic properties for RRHO and qRRHO are printed at standard temperature and pressure as well as two additional temperatures (273.15 K and 313.15 K). Please see Section 10.7.2 for further details on the $isotopes section.
JOBTYPE         opt
METHOD          hf
BASIS           3-21G
JOBTYPE         freq
METHOD          hf
BASIS           3-21G
ISOTOPES        true
$isotopes
2 1
0 273.15 1.0
0 313.15 1.0
