7.10.10 Auger Spectra and Lifetimes of Core-Level States
Certain types of resonances can be described by using real-valued EOM-CC wave functions via Feshbach-Fano approach. 358 Feshbach H.
Ann. Phys.
(1962), 19, pp. 287.
, 350 Fano U.
Phys. Rev.
(1961), 124, pp. 1866.
In this section we describe the application of Feshbach-Fano approach to core-excited and core-ionized states. 1175 Skomorowski W., Krylov A. I.
(2021), 154, pp. 084124.
, 1176 Skomorowski W., Krylov A. I.
(2021), 154, pp. 084125.
Core-hole states, which are Feshbach resonances, are subject to autoionization—commonly known as Auger decay. Auger Electron Spectroscopy (AES) measures kinetic energy and intensity of ejected electrons. Theoretical description of AES can be formulated using Feshbach-Fano approach for electronic resonances. 358 Feshbach H.
Ann. Phys.
, 350 Fano U.
Phys. Rev.
The theory invokes two projection operators, Q^ and P^, which decompose the total wavefunction into bound-like and continuum-like components. In the case of core-level states this separation is enabled by invoking the CVS scheme and frozen-core approximation in the calculations of initial and final states in the Auger process (more details about CVS can be found in Section 7.10.8).
The initial (bound-like) state Ψ0 is a core-hole ionized or core-hole excited state, which can be described by CVS-EOM-CC. The final (continuum-like) state χμ,Ek is represented as an antisymmetrized product of a stable channel state Ψμ (described by an appropriate EOM-EE model) and a continuum orbital ϕk, χμ,Ek∼𝒜⁢{ϕk⁢Ψμ}. Note that Ψμ is a state with one electron less than Ψ0. Two essential parameters defining AES are the rate of the decay into a channel μ, given as
Γμ=2⁢π⁢⟨Ψ0L|H^-E0|χμ,EkR⟩⁢⟨χμ,EkL|H^-E0|Ψ0R⟩, (7.84)
and partial energy correction Δμ to the zero-order resonance position E0, defined as
Δμ=P.V.∫0∞⟨Ψ0L|H^-E0|χμ,ER⟩⁢⟨χμ,EL|H^-E0|Ψ0R⟩E0-Eμ-E⁢𝑑E. (7.85)
In the expressions above H^ is the electronic Hamiltonian, Eμ is the energy of the channel state Ψμ, Ek is the energy of the ejected electron (Ek=E0-Eμ), L/R superscripts denote left and right EOM-CCSD wavefunctions, and P.V. stands for the Cauchy principle value. Calculations of Γμ are activated with the CC_DO_FESHBACH keyword. By default, the continuum orbital ϕk is approximated with a plane wave. 1175 Skomorowski W., Krylov A. I.
It is also possible to model ϕk with a Coulomb wave by setting CC_FESHBACH_CW = 1. This option requires to include in the input an additional input section $coulomb_wave, which provides an expansion of the Coulomb wave (for the given effective charge and kinetic energy) in terms of products of a plane wave and Gaussian-type functions, as detailed in Ref.  1175 Skomorowski W., Krylov A. I.
The implementation of Feshbach widths includes numerical integration over all possible directions of the emitted electron (k-vector). This integration over the sphere is carried out using Lebedev’s quadrature, with the default order of 5. For molecules with delocalized core-hole states (e.g., benzene), higher-order quadrature may be needed. The order of the quadrature is controlled by CC_FESHBACH_INT_ORDER.
For non-resonant Auger decay, the initial state can be conveniently computed by CVS-EOM-IP-CCSD, whereas its stable decay channels can be obtained from EOM-DIP-CCSD calculations. Section of the input invoking Auger decay rates calculation for an atom can be given as:
   JOBTYPE         sp
   METHOD          eom-ccsd
   basis           6-31G*
   CVS_EOM_IP_BETA [1,0,0,0,0,0,0,0] !This is the initial core-hole state
   DIP_TRIPLETS    [0,0,0,0,0,1,1,1] !These are the final triplet decay channels
   DIP_SINGLETS    [3,1,1,1,0,1,1,1] !These are the final singlet decay channels
   CC_DO_DYSON     1                 !Needed for Feshbach-type calculations
   CC_DO_FESHBACH  1
In resonant Auger decay, the initial state can be computed by CVS-EOM-EE-CCSD, whereas the corresponding decay channels can be obtained from EOM-IP-CCSD calculations. By default, Feshbach calculations are performed for all possible state pairs that include an energetically allowed decay channel. This is not practical if, for example, the core-hole state of interest is not the lowest state in the given symmetry, or when the Coulomb wave is used to model the continuum orbital. In such a case, the user can specify pairs of states for Feshbach calculations using the $trans_prop section with d⁢y⁢s⁢o⁢n as the requested property:
$trans_prop
   state_list
   cvs_ip_beta  1 1 !state 1: CVS_IP with irrep = 1 and istate = 1
   dip_singlets 1 3 !state 2: DIP_SINGLET state with irrep = 1 and istate = 3
   dip_triplets 6 1 !state 3: DIP_TRIPLET state with irrep = 6 and istate = 1
   end_list
   state_pair_list
   1 2   ! transition 1 <-> 2
   1 3   ! transition 1 <-> 3
   end_pairs
   calc dyson
Calculations of energy correction Δμ are invoked by setting CC_DO_FESHBACH = 2, and are currently available only within the plane-wave approximation.
The integrals in Eq. (7.84) are evaluated analytically. Integration in Eq. (7.85) is done numerically, and is split into two or three intervals to bypass the singularity at E=E0-Eμ. The upper limits of those intervals are set to default values related to E0. They can also be customized (except for the first interval) by setting CC_FESHBACH_DELTA_INTB = XX and/or CC_FESHBACH_DELTA_INTC = YY where XX and/or YY are desired upper integration limits in units of eV.
A molecular orbital description of the Auger process (or other two-electron decay processes such as intermolecular Coulomb and electron-transfer-mediated decay) can be obtained from the singular-value decompostion of the two-particle Dyson amplitudes (Γμ) 594 Jayadev N. K., Skomorowski W., Krylov A. I.
J. Phys. Chem. Lett.
(2023), 14, pp. 8612.
. The procedure yields several three-orbital sets, which represent the core-vacancy state and the valence decay states. These sets, called Natural Auger Orbitals, provide the most compact description of the two-electron decay process 594 Jayadev N. K., Skomorowski W., Krylov A. I.
. The calculations of NAOs can be invoked within Feshbach calculations by adding CC_DO_NAO keyword. The NAOs are printed in the MolDen format in a subdirectory created in the working directory. The “energies” are the squares of singular values (not normalized), core-hole NAOs are assigned populations of 1, and valence decay NAOs are assigned populations of 0. The default threshold for the NAOs to be printed is 0.20. It can be controlled by the user using the WFA_ORB_THRESH keyword (see Section 10.2). This feature is illustated in examles 7.10.10.1, 7.10.10.1, and 7.10.10.1 below.
Note:  NAOs are computed using Γr⁢βp⁢α,q⁢β block of the two-body Dyson amplitude. This means that in the non-resonant Auger decay calculations, the core hole should correspond to removing β-electron.
CC_DO_FESHBACH
CC_DO_FESHBACH
       Activates calculation of resonance widths using Feshbach-Fano approach.
       0 do not invoke Feshbach-Fano calculation 1 invoke Feshbach-Fano calculation of the resonance width 2 invoke Feshbach-Fano calculation of the resonance width and resonance shift
       Initial and final states should be correctly specified.
CC_FESHBACH_CW
CC_FESHBACH_CW
       Activates Coulomb wave description of the ejected electron.
       0 Use plane wave 1 Use Coulomb wave
       Additional details need to be specified in $coulomb_wave section.
       Controls k-vector integration grid in calculations of resonance widths using Feshbach-Fano approach.
       5
       n corresponds to the Lebedev quadrature order
       Use default, unless tighter convergence is desired (16 gives fully converged widths).
       Specifies integration limits in calculation of energy shift in Feshbach-Fano calculations.
       Preset
       n corresponds to energy limit in eV
       Use default.
       Preset
       Use default.
CC_DO_NAO
CC_DO_NAO
       Activates calculation of NAOs within Feshbach–Fano calculation of the decay widths.
       0 do not compute NAOs 1 compute NAOs
7.10.10.1 Examples
Examples 7.10.10.1 and 7.10.10.1 illustrate calculation of resonant Auger decay of core-ionized water molecule. The initial state is described by CVS-EOM-IP-CCSD and the decay channels are described by EOM-DIP-CCSD. Example 7.10.10.1 uses a plane-wave representation of the ejected electron. In example 7.10.10.1, the autoionizing electron is described by the Coulomb wave, represented by a pseudo-partial wave expansion over PW-CGTO functions. Examples 7.10.10.1, 7.10.10.1, and 7.10.10.1 illustarte calculations of NAOs for regular and resonant Auger decay.
Example 7.68  Calculation of Auger decay rates of core-ionized water molecule to selected singlet and triplet final states. Continuum orbital is a plane wave.
   O         0.0000    0.000    0.0000
   H        -0.7528    0.000   -0.5917
   H         0.7528    0.000   -0.5917
   METHOD            ccsd
   BASIS             6-311+G(3df)
   CVS_EOM_IP_BETA   [1,0,0,0]
   DIP_SINGLETS      [4,1,2,2]
   DIP_TRIPLETS      [1,1,2,2]
   CC_DO_DYSON       1
   CC_DO_FESHBACH    1
Example 7.7.69  Calculation of Auger decay rates of core-ionized water molecule to selected singlet and triplet final states. Continuum orbital is approximated by a Coulomb wave.
   METHOD            ccsd
   BASIS             6-311+G(3df)
   CC_DO_DYSON       1
   CC_DO_FESHBACH    1
   CC_FESHBACH_CW    1
$trans_prop
state_list
  cvs_ip_beta  1 1
  dip_triplets 3 2
end_list
state_pair_list
end_pairs
calc dyson
$coulomb_wave
!This PW-CGTO expansion of CW is optimized for Z = 4.9 and Ek = 475.7 eV
!CW is centered on oxygen (atom #1), has Lmax = 2, and n = 4 GTOs for each L
1 2 4
!List of GTO exponents for each consecutive pseudo-partial wave from L = 0 to Lmax
33.92543607
 0.85503320
 0.03878479
 0.00464513
10.09805405
 0.75935967
 0.06727680
 0.00646507
 6.96653113
 0.94413668
 0.11599464
 0.01425085
!List of corresponding GTO contraction coefficients - real and imaginary parts
 1.15237075   -1.28233348
 0.96764647   -0.30588374
 0.94868507    0.99338435
-1.18258037   -0.06876149
-0.62304129    0.90336892
-0.14457938    0.18631218
-0.07528422    0.01001695
-0.00950295   -0.02658981
 0.22796804   -0.19298801
 0.01268528   -0.03579628
 0.00369451   -0.00318780
 0.00068338    0.00016431
Example 7.70  Calculation of Natural Auger Orbitals for regular (non-resonant) Auger decay in water for both singlet and triplet decay channels.
NAO calculation - regular Auger decay in water
jobtype              sp
method               eom-ccsd
basis                6-31g
cvs_eom_ip_beta      [1,0,0,0]  !Initial core-hole state
dip_singlets         [1,1,0,0]  !Final singlet decay channels
dip_triplets         [0,1,0,0]  !Final triplet decay channels
cc_do_dyson          1          !Needed for Feshbach-type calculations
cc_do_feshbach       1          !Needed for Feshbach-type calculations
cc_do_nao            1          !Needed for natural Auger orbitals
wfa_orb_thresh       1          !Setting the threshold for singular value dceomposition
mem_total            4000
Example 7.71  Calculation of Natural Auger Orbitals for regular (non-resonant) Auger decay in benzene for both singlet and triplet decay channels, and for several core-hole states.
NAO calculation - regular Auger decay in benzene
$molecule        0 1
  H   2.4750347531   0.0000000000   0.0000000000
  C   1.3935929418   0.0000000000   0.0000000000
  C   0.6967964709   1.2068868901   0.0000000000
  H   1.2375173766   2.1434429715   0.0000000000
  C  -0.6967964709   1.2068868901   0.0000000000
  H  -1.2375173766   2.1434429715   0.0000000000
  C  -1.3935929418   0.0000000000   0.0000000000
  H  -2.4750347531   0.0000000000   0.0000000000
  C  -0.6967964709  -1.2068868901   0.0000000000
  H  -1.2375173766  -2.1434429715   0.0000000000
  C  0.6967964709   -1.2068868901   0.0000000000
  H  1.2375173766   -2.1434429715   0.0000000000
jobtype             sp
method              ccsd
basis               6-31g
cvs_eom_ip_beta     [1,0,0,0,0,0,1,1] !Initial core-hole state
dip_singlets        [2,0,0,1,0,0,0,0] !Final singlet decay channel
dip_triplets        [1,0,0,1,0,0,0,0] !Final triplet decay channel
cc_do_nao           1                 !Needed for natural Auger orbital calculation
mem_total           8000
Example 7.72  Calculation of Natural Auger Orbitals for resonant Auger decay in water.
NAO calculation - resonant Auger decay in water
jobtype              sp
method               eom-ccsd
basis                6-31g
cvs_ee_states        [1,0,0,0]  !Initial core-hole state
ip_states            [1,0,1,0]  !Final  decay channels
mem_total            4000
