12.6 Second-Generation ALMO-EDA Method
12.6.3 Polarization Energy with a Well-Defined Basis Set Limit
The definition of polarization energy lowering in the original ALMO-EDA used the full AO space of each fragment as the variational degrees of freedom. This is based on the assumption that the AO basis functions are fragment-ascribable based on their atomic centers. However, this assumption becomes inappropriate when very large basis sets are used, especially those with diffuse functions (e.g. def2-QZVPPD). In such scenarios, basis functions on a given fragment tend to describe other fragments so that the “absolute localization" constraint becomes weaker and finally gets effectively removed. This is why the original ALMO-EDA scheme does not have a well-defined basis set limit for its polarization energy.
To overcome this problem, Horn and Head-Gordon 556 Horn P. R., Head-Gordon M.
(2015), 143, pp. 114111.
proposed a new definition for the POL term in the ALMO-EDA method based on fragment electrical response functions (FERFs). FERFs on a given fragment are prepared by solving CPSCF equations after its SCF solution is found:
Ha⁢i,b⁢j⁢(Δμ)b⁢j=(Mμ)a⁢i, (12.1)
where 𝐇 is SCF orbital Hessian and 𝐌μ is a component (μ) of a multipole matrix with a certain order. The resulting fragment response matrices ({Δμ}) are a set of nv×no matrices. Then, a singular value decomposition (SVD) is performed on Δμ:
(Δμ)a⁢i=(Lμ)a⁢b⁢(dμ)b⁢j⁢(RμT)j⁢i, (12.2)
and the left vectors (not including the null vectors) will be used to construct a truncated virtual space, which is used to define the variational degrees of freedom for the SCF-MI problem:
𝐕μ=𝐂vir⁢𝐋μ, (12.3)
where 𝐂vir denotes the original virtual orbitals of the given fragment.
The basic spirit of using FERFs is to obtain a subset of virtuals that is most pertinent to the electrical polarization of a given fragment, while the redundant variational degrees of freedom (which might be CT-like) are excluded. This scheme is shown to give a well-defined basis set limit for the polarization energy that relies on the SCF-MI calculation. The multipole orders dipole (D), quadrupole (Q), and octopole (O)m included on the RHS of Eq. (12.2), decide the span of FERFs on each fragment. Numerical experiments suggest that the inclusion of dipole- and quadrupole-type responses is able to long-range induced electrostatics correctly and also gives a well-defined basis set limit, which is thus recommended as the working basis of the SCF-MI problem. The full span of the polarization subspace of fragment A is thus:
𝐎A⊕span⁢{𝐕μ⁢x,𝐕μ⁢y,𝐕μ⁢z}⊕span⁢{𝐕Q⁢2,-2,𝐕Q⁢2,-1,𝐕Q⁢2,0,𝐕Q⁢2,1,𝐕Q⁢2,2}. (12.4)
Therefore, each occupied orbital will be paired with eight virtual orbitals (if the employed AO basis is large enough).
The polarization subspaces constructed as in Eq. (12.4) are non-orthogonal between fragments. Therefore, it is named as the “nDQ" model for polarization. There is another version of this method which enforces interfragment orthogonality between the polarization subspaces and it is correspondingly termed as “oDQ" (or with other multipole orders). The preparation of orthogonal FERFs is more complicated (see Ref.  556 Horn P. R., Head-Gordon M.
for the details) and usually gives less favorable polarization energies. For most general cases, we recommend the use of the “nDQ" model. Calculations using FERFs are performed using the generalized SCF-MI procedure introduced in Section 12.6.2.
CHILD_MP
CHILD_MP
       Compute FERFs for fragments and use them as the basis for SCF-MI calculations.
       FALSE Do not compute FERFs (use the full AO span of each fragment). TRUE Compute fragment FERFs.
       Use FERFs to compute polarization energy when large basis sets are used. In an “EDA2" calculation, this $rem variable is set based on the given option automatically.
CHILD_MP_ORDERS
CHILD_MP_ORDERS
       The multipole orders included in the prepared FERFs. The last digit specifies how many multipoles to compute, and the digits in the front specify the multipole orders: 2: dipole (D); 3: quadrupole (Q); 4: octopole (O). Multipole order 1 is reserved for monopole FERFs which can be used to separate the effect of orbital contraction. 763 Levine D. S., Head-Gordon M.
J. Phys. Chem. Lett.
(2017), 8, pp. 1967.
       21 D 232 DQ 2343 DQO
       Use 232 (DQ) when FERF is needed.
Example 12.13  Generalized SCF-MI calculation for the water dimer using nDQ FERFs.
   METHOD            wb97x-v
   GEN_SCFMAN        true
   BASIS             6-31+G(d)
   GEN_SCFMAN        true
   SCF_ALGORITHM     diis
   SCF_CONVERGENCE   8
   THRESH            14
   SCF_FINAL_PRINT   1
   FRGM_METHOD       stoll
   SCFMI_MODE        1 !nonortho gen scfmi
   CHILD_MP          true
   CHILD_MP_ORDERS   232 !DQ
   FD_MAT_VEC_PROD   false
   INTEGRAL_SYMMETRY false
   POINT_GROUP_SYMMETRY false
